cs_matrix_petsc_priv.h
1#ifndef CS_MATRIX_PETSC_PRIV_H
2#define CS_MATRIX_PETSC_PRIV_H
5 * Private types for sparse matrix representation and operations using PETSc.
31 * PETSc headers
34#include <petscvec.h>
35#include <petscmat.h>
36
37/*----------------------------------------------------------------------------
38 * Local headers
39 *----------------------------------------------------------------------------*/
41#include "base/cs_defs.h"
45/*----------------------------------------------------------------------------*/
46
48
51/*============================================================================
52 * Macro definitions
53 *============================================================================*/
54
55/*============================================================================
56 * Type definitions
58
59/* Note that most types are declared in cs_matrix_priv.h.
60 only those only handled here are declared here. */
61
62/* Adapter coefficients stucture for PETSc */
63
64typedef struct _cs_matrix_coeffs_petsc_t {
65
66 PetscInt l_range[2]; /* Local rows range
67 (block range if block size > 1) */
68
69 Mat hm; /* PETSc matrix */
70 Vec hx; /* x (input) vector */
71 Vec hy; /* y (output) vector */
72
73 int matrix_state; /* Matrix state:
74 0: not created
75 1: created and assembled */
76
77 char *matype_r; /* requested PETSc matrix type */
78 MatType matype; /* actual PETSc matrix type */
79
80} cs_matrix_coeffs_petsc_t;
81
82/*=============================================================================
83 * Semi-private function prototypes
84 *============================================================================*/
85
86/*----------------------------------------------------------------------------*/
95
96cs_matrix_coeffs_petsc_t *
97cs_matrix_petsc_get_coeffs(const cs_matrix_t *matrix);
98
101/*----------------------------------------------------------------------------*/
102
104
105#endif /* CS_MATRIX_PETSC_PRIV_H */
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Definition: cs_matrix.h:108
