cs_gui_mesh.h
1#ifndef CS_GUI_MESH_H
2#define CS_GUI_MESH_H
5 * Management of the GUI parameters file: mesh related options
31 * Local headers
34#include "base/cs_base.h"
35#include "mesh/cs_mesh.h"
36
37/*============================================================================
38 * Public function prototypes for Fortran API
39 *============================================================================*/
41/*============================================================================
42 * Public function prototypes
43 *============================================================================*/
45/*-----------------------------------------------------------------------------
46 * Determine the mesh restart mode.
47 *----------------------------------------------------------------------------*/
48
49void
51
52/*-----------------------------------------------------------------------------
53 * Determine whether warped faces should be cut.
54 *----------------------------------------------------------------------------*/
55
56void
58
59/*-----------------------------------------------------------------------------
60 * Define joinings using a GUI-produced XML file.
61 *----------------------------------------------------------------------------*/
62
63void
65
66/*-----------------------------------------------------------------------------
67 * Define periodicities using a GUI-produced XML file.
68 *----------------------------------------------------------------------------*/
69
70void
72
73/*----------------------------------------------------------------------------
74 * Mesh smoothing.
75 *
76 * parameters:
77 * mesh <-> pointer to mesh structure to smoothe
78 *----------------------------------------------------------------------------*/
79
80void
82
83/*----------------------------------------------------------------------------
84 * Define user thin wall through the GUI.
85 *----------------------------------------------------------------------------*/
86
87void
89
90/*----------------------------------------------------------------------------
91 * Define user mesh extrude through the GUI.
92 *----------------------------------------------------------------------------*/
93
94void
96
97/*----------------------------------------------------------------------------
98 * Define mesh save behavior trough the GUI.
99 *----------------------------------------------------------------------------*/
100
101void
103
104/*----------------------------------------------------------------------------
105 * Read cartesian mesh parameters defined with GUI.
106 *----------------------------------------------------------------------------*/
107
108void
110
111/*----------------------------------------------------------------------------*/
112
113#endif /* CS_GUI_MESH_H */
void cs_gui_mesh_restart_mode(void)
Definition: cs_gui_mesh.cpp:292
void cs_gui_mesh_save_if_modified(cs_mesh_t *mesh)
Definition: cs_gui_mesh.cpp:674
void cs_gui_mesh_extrude(cs_mesh_t *mesh)
Definition: cs_gui_mesh.cpp:616
void cs_gui_mesh_define_periodicities(void)
Definition: cs_gui_mesh.cpp:427
void cs_gui_mesh_warping(void)
Definition: cs_gui_mesh.cpp:337
void cs_gui_mesh_define_joinings(void)
Definition: cs_gui_mesh.cpp:375
void cs_gui_mesh_smoothe(cs_mesh_t *mesh)
Definition: cs_gui_mesh.cpp:525
void cs_gui_mesh_cartesian_define(void)
Definition: cs_gui_mesh.cpp:703
void cs_gui_mesh_boundary(cs_mesh_t *mesh)
Definition: cs_gui_mesh.cpp:576
Definition: mesh.f90:26
Definition: cs_mesh.h:85
