1#ifndef CS_ENFORCEMENT_H
2#define CS_ENFORCEMENT_H
Definition: cs_defs.h:332
Definition: cs_defs.h:325
cs_real_t * cs_enforcement_define_at_faces(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for face-based scheme.
Definition: cs_enforcement.cpp:494
void cs_enforcement_param_log(const char *eqname, const cs_enforcement_param_t *efp)
Log a cs_enforcement_param_t structure.
Definition: cs_enforcement.cpp:275
cs_enforcement_selection_t
Type of entities used to define the selection where the enforcement takes place.
Definition: cs_enforcement.h:59
@ CS_ENFORCEMENT_SELECTION_VERTICES
Definition: cs_enforcement.h:64
@ CS_ENFORCEMENT_SELECTION_EDGES
Definition: cs_enforcement.h:63
@ CS_ENFORCEMENT_SELECTION_CELLS
Definition: cs_enforcement.h:61
@ CS_ENFORCEMENT_SELECTION_FACES
Definition: cs_enforcement.h:62
cs_real_t * cs_enforcement_define_at_edges(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for edge-based scheme.
Definition: cs_enforcement.cpp:623
cs_enforcement_param_t * cs_enforcement_param_create(cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
Create and define a cs_enforcement_param_t structure.
Definition: cs_enforcement.cpp:105
void cs_enforcement_param_free(cs_enforcement_param_t **p_efp)
Free a cs_enforcement_param_t structure.
Definition: cs_enforcement.cpp:248
void cs_enforcement_param_reset(cs_enforcement_param_t *efp, cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
Reset an existing cs_enforcement_param_t structure.
Definition: cs_enforcement.cpp:166
cs_enforcement_param_t * cs_enforcement_param_copy(const cs_enforcement_param_t *ref)
Copy a cs_enforcement_param_t structure.
Definition: cs_enforcement.cpp:222
Describe the way the values to enforce are defined.
Definition: cs_enforcement.h:73
@ CS_ENFORCEMENT_BY_DOF_VALUES
Definition: cs_enforcement.h:76
@ CS_ENFORCEMENT_BY_CONSTANT
Definition: cs_enforcement.h:75
cs_real_t * cs_enforcement_define_at_vertices(const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
Build a cs_enforcement_t structure for vertex-based scheme.
Definition: cs_enforcement.cpp:365
bool cs_enforcement_dofs_cw(const cs_real_t *forced_values, cs_cell_sys_t *csys, cs_real_t *cw_forced_values)
Build the cell-wise value to enforce.
Definition: cs_enforcement.cpp:752
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_local.h:163
Set of data defining an enforcement.
Definition: cs_enforcement.h:85
int stride
Definition: cs_enforcement.h:92
Definition: cs_enforcement.h:88
cs_real_t * values
Definition: cs_enforcement.h:93
cs_lnum_t n_elts
Definition: cs_enforcement.h:90
cs_enforcement_selection_t selection_type
Definition: cs_enforcement.h:87
cs_lnum_t * elt_ids
Definition: cs_enforcement.h:91
