cs_param_saddle_context_block_krylov_t Struct Reference
#include <cs_param_saddle.h>
+ Collaboration diagram for cs_param_saddle_context_block_krylov_t:
Public Attributes
double augmentation_scaling
int n_stored_directions
cs_param_sles_t * xtra_sles_param
Member Data Documentation
◆ augmentation_scaling
Value of the scaling coefficient in front of the augmented system. This is only useful when a GKB algorithm is used. By default, there is no augmentation.
◆ n_stored_directions
n_stored_directions
Number of iterations to perform before restarting the solver. This quantity is useful when a GCR or FMGRES is used.
◆ xtra_sles_param
xtra_sles_param
Set of parameters only used in some situations such as the need to solve approximately the A.x = 1 linear system (A is the (1,1)-block matrix). This is a complementary step in the approximation of the Schur complement.
By default, this is a copy of the block11_sles_param with less restrictive convergence criteria
