cs_iter_algo_aac_t Struct Reference
Context structure for the algorithm called Anderson acceleration. More...
#include <cs_iter_algo.h>
+ Collaboration diagram for cs_iter_algo_aac_t:
Public Attributes
cs_iter_algo_param_aac_t param
cs_sles_convergence_state_t cvg_status
double normalization
double tol
double prev_res
double res
double res0
int n_algo_iter
int n_inner_iter
int last_inner_iter
cs_lnum_t n_elts
Work quantities (temporary)
int n_dir
cs_real_t * fold
cs_real_t * df
cs_real_t * gold
cs_real_t * dg
cs_real_t * Q
cs_sdm_t * R
cs_real_t * gamma
Set of parameters and arrays to manage the Anderson acceleration
Member Data Documentation
◆ cvg_status
cvg_status
Converged, iterating or diverged status
◆ df
df
Difference between the current and previous values of f
◆ dg
dg
Difference between the current and previous values of g
◆ fold
fold
Previous values for f
◆ gamma
gamma
Coefficients used to define the linear combination
◆ gold
gold
Previous values for g
◆ last_inner_iter
last_inner_iter
Last number of iterations for the inner solver
◆ n_algo_iter
n_algo_iter
Current number of iterations for the algorithm (outer iterations)
◆ n_dir
n_dir
Number of directions currently at stake
◆ n_elts
cs_lnum_t n_elts
◆ n_inner_iter
n_inner_iter
Curent cumulated number of inner iterations (sum over the outer iterations)
◆ normalization
normalization
Value of the normalization for the relative tolerance.
The stopping criterion is such that res < rtol * normalization. By default, the normalization is set to 1.
◆ param
param
Set of parameters driving the behavior of the Anderson acceleration
◆ prev_res
prev_res
Value of the previous residual achieved during the iterative process
◆ Q
Q
Matrix Q in the Q.R factorization (seen as a bundle of vectors)
◆ R
R
Matrix R in the Q.R factorization (small dense matrix)
◆ res
res
Value of the residual for the iterative algorithm
◆ res0
res0
Value of the first residual of the iterative process. This is used for detecting the divergence of the algorithm.
◆ tol
tol
Tolerance computed as tol = max(atol, normalization*rtol) where atol and rtol are respectively the absolute and relative tolerance associated to the algorithm
