cs_atmo_chemistry_t Struct Reference
#include <cs_atmo_chemistry.h>
+ Collaboration diagram for cs_atmo_chemistry_t:
Public Attributes
int model
int n_species
int n_reactions
int chemistry_sep_mode
bool chemistry_with_photolysis
cs_atmo_aerosol_type_t aerosol_model
bool frozen_gas_chem
bool init_gas_with_lib
bool init_aero_with_lib
int n_layer
int n_size
char * spack_file_name
int * species_to_field_id
int * species_profiles_to_field_id
cs_real_t * molar_mass
int * chempoint
cs_real_t * conv_factor_jac
cs_real_t * reacnum
cs_real_t * dlconc0
char * aero_file_name
char * chem_conc_file_name
char * aero_conc_file_name
int nt_step_profiles
int n_z_profiles
int n_species_profiles
cs_real_t * conc_profiles
cs_real_t * z_conc_profiles
cs_real_t * t_conc_profiles
cs_real_t * x_conc_profiles
cs_real_t * y_conc_profiles
cs_real_t dt_chemistry_max
Member Data Documentation
◆ aero_conc_file_name
char* aero_conc_file_name
Name of the file used to initialize and to apply boundary conditions on aerosol species
◆ aero_file_name
char* aero_file_name
Name of the file used to initialize the aerosol shared library
◆ aerosol_model
Choice of the aerosol model
  • CS_ATMO_AEROSOL_OFF —> no aerosol model
  • CS_ATMO_AEROSOL_SSH —> external library SSH-aerosol
◆ chem_conc_file_name
char* chem_conc_file_name
Name of the file used to initialize and to apply boundary conditions on chemical species
◆ chemistry_sep_mode
split (=1) or semi-coupled (=2, pu-sun) resolution of chemistry
◆ chemistry_with_photolysis
◆ chempoint
int* chempoint
◆ conc_profiles
cs_real_t* conc_profiles
concentration profiles
◆ conv_factor_jac
cs_real_t* conv_factor_jac
conversion factors for reaction rates Jacobian matrix
◆ dlconc0
cs_real_t* dlconc0
Initial gaseous and particulate concentrations and aerosol number read in file
◆ dt_chemistry_max
maximal time step for chemistry resolution
◆ frozen_gas_chem
Flag to deactivate gaseous chemistry when using aerosols
◆ init_aero_with_lib
Flag to initialize aerosols species with the aerosol library
◆ init_gas_with_lib
Flag to initialize gaseous species with the aerosol library
◆ model
int model
Choice of chemistry resolution scheme
  • 0 --> no atmospheric chemistry
  • 1 --> quasi steady equilibrium NOx scheme with 4 species and 5 reactions
  • 2 --> scheme with 20 species and 34 reactions
  • 3 --> CB05 scheme with 52 species and 155 reactions
  • 4 --> user defined schema from SPACK
◆ molar_mass
cs_real_t* molar_mass
Molar mass of the chemical species (g/mol)
◆ n_layer
int n_layer
Number of layers within each aerosol
◆ n_reactions
int n_reactions
◆ n_size
int n_size
Number of aerosols
◆ n_species
int n_species
◆ n_species_profiles
number of initialized chemical species in the concentration profiles file
◆ n_z_profiles
int n_z_profiles
number of altitudes for the concentration profiles file
◆ nt_step_profiles
number of time steps for the concentration profiles file
◆ reacnum
cs_real_t* reacnum
kinetics constants
◆ spack_file_name
char* spack_file_name
◆ species_profiles_to_field_id
int* species_profiles_to_field_id
◆ species_to_field_id
int* species_to_field_id
◆ t_conc_profiles
cs_real_t* t_conc_profiles
time steps of the concentration profiles
◆ x_conc_profiles
cs_real_t* x_conc_profiles
X coordinates of concentration profiles
◆ y_conc_profiles
cs_real_t* y_conc_profiles
Y coordinates of concentration profiles
◆ z_conc_profiles
cs_real_t* z_conc_profiles
altitudes of the concentration profiles
