cs_atmo_1d_rad_t Struct Reference
#include <cs_atmo_1d_rad.h>
+ Collaboration diagram for cs_atmo_1d_rad_t:
Public Attributes
int radiative_model_1d
int nvert
int nlevels
int nlevels_max
int frequency
cs_real_t * xy
cs_real_t * z
cs_real_t * acinfe
cs_real_t * dacinfe
cs_real_t * aco2
cs_real_t * aco2s
cs_real_t * daco2
cs_real_t * daco2s
cs_real_t * acsup
cs_real_t * acsups
cs_real_t * dacsup
cs_real_t * dacsups
cs_real_t * tauzq
cs_real_t * tauz
cs_real_t * zq
cs_real_t * ir_div
cs_real_t * sol_div
cs_real_t * iru
cs_real_t * ird
cs_real_t * solu
cs_real_t * sold
cs_real_t * qw
cs_real_t * ql
cs_real_t * qv
cs_real_t * nc
cs_real_t * fn
cs_real_t * aerosols
cs_real_t * albedo0
cs_real_t * emissi0
cs_real_t * temp0
cs_real_t * theta0
cs_real_t * qw0
cs_real_t * p0
cs_real_t * rho0
Member Data Documentation
◆ acinfe
cs_real_t* acinfe
absorption for CO2 + 03
◆ aco2
cs_real_t* aco2
absorption for CO2 only
◆ aco2s
cs_real_t* aco2s
◆ acsup
cs_real_t* acsup
as acinfe, downwing flux
◆ acsups
cs_real_t* acsups
◆ aerosols
cs_real_t* aerosols
1D profiles of aerosols along each vertical
◆ albedo0
cs_real_t* albedo0
Value of ground albedo for each vertical
◆ dacinfe
cs_real_t* dacinfe
differential absorption for CO2 + 03
◆ daco2
cs_real_t* daco2
differential absorption for CO2 only
◆ daco2s
cs_real_t* daco2s
◆ dacsup
cs_real_t* dacsup
◆ dacsups
cs_real_t* dacsups
◆ emissi0
cs_real_t* emissi0
Value of ground emissivity for each vertical
◆ fn
cs_real_t* fn
1D profiles of nebulosity along each vertical
◆ frequency
int frequency
1D radiative model pass frequency (1 valu bu default)
◆ ir_div
cs_real_t* ir_div
flux divergence of IR radiation
◆ ird
cs_real_t* ird
◆ iru
cs_real_t* iru
Upward and downward radiative fluxes (infrared, solar) along each vertical
◆ nc
cs_real_t* nc
1D profiles of number of droplets along each vertical
◆ nlevels
int nlevels
1-D radiative model: number of levels (up to the top of the domain)
◆ nlevels_max
int nlevels_max
1-D radiative model: number of levels (up to 11000 m) (automatically computed)
◆ nvert
int nvert
1-D radiative model: number of vertical arrays
◆ p0
cs_real_t* p0
Value of ground pressure for each vertical
◆ ql
cs_real_t* ql
1D profiles of liquid water mass fraction along each vertical
◆ qv
cs_real_t* qv
1D profiles of vapor water mass fraction along each vertical
◆ qw
cs_real_t* qw
1D profiles of total water mass fraction along each vertical
◆ qw0
cs_real_t* qw0
Value of ground total water mass fraction for each vertical
◆ radiative_model_1d
1-D radiative model (0 off, 1 on)
◆ rho0
cs_real_t* rho0
Value of ground density for each vertical
◆ sol_div
cs_real_t* sol_div
flux divergence of solar radiation
◆ sold
cs_real_t* sold
◆ solu
cs_real_t* solu
◆ tauz
cs_real_t* tauz
internal variable for 1D radiative model
◆ tauzq
cs_real_t* tauzq
◆ temp0
cs_real_t* temp0
Value of ground temperature for each vertical
◆ theta0
cs_real_t* theta0
Value of ground potential temperature for each vertical
◆ xy
cs_real_t* xy
horizontal coordinates of the vertical grid
◆ z
vertical grid for 1D radiative scheme
◆ zq
cs_real_t* zq
vertical grid for 1D radiative scheme (staggered grid associated to faces)
