fvm_nodal.h File Reference
#include "mesh/cs_mesh.h"
#include "fvm/fvm_defs.h"
#include "fvm/fvm_group.h"
#include "fvm/fvm_io_num.h"
+ Include dependency graph for fvm_nodal.h:
fvm_nodal_t * fvm_nodal_create (const char *name, int dim)
fvm_nodal_t * fvm_nodal_destroy (fvm_nodal_t *this_nodal)
fvm_nodal_t * fvm_nodal_copy (const fvm_nodal_t *this_nodal)
void fvm_nodal_reduce (fvm_nodal_t *this_nodal, int del_vertex_num)
void fvm_nodal_change_parent_id (fvm_nodal_t *this_nodal, const cs_lnum_t new_parent_id[], int entity_dim)
void fvm_nodal_remove_parent_id (fvm_nodal_t *this_nodal, int entity_dim)
void fvm_nodal_init_io_num (fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_numbers[], int entity_dim)
void fvm_nodal_transfer_vertex_io_num (fvm_nodal_t *this_nodal, fvm_io_num_t **io_num)
void fvm_nodal_set_tag (fvm_nodal_t *this_nodal, const int tag[], int entity_dim)
void fvm_nodal_remove_tag (fvm_nodal_t *this_nodal, int entity_dim)
void fvm_nodal_define_vertex_list (fvm_nodal_t *this_nodal, cs_lnum_t n_vertices, cs_lnum_t parent_vertex_id[])
void fvm_nodal_set_shared_vertices (fvm_nodal_t *this_nodal, const cs_coord_t vertex_coords[])
cs_coord_t * fvm_nodal_transfer_vertices (fvm_nodal_t *this_nodal, cs_coord_t vertex_coords[])
void fvm_nodal_make_vertices_private (fvm_nodal_t *this_nodal)
void fvm_nodal_set_group_class_set (fvm_nodal_t *this_nodal, const fvm_group_class_set_t *gc_set)
void fvm_nodal_transfer_global_vertex_labels (fvm_nodal_t *this_nodal, char *g_labels[])
const char * fvm_nodal_get_name (const fvm_nodal_t *this_nodal)
int fvm_nodal_get_dim (const fvm_nodal_t *this_nodal)
int fvm_nodal_get_max_entity_dim (const fvm_nodal_t *this_nodal)
cs_lnum_t fvm_nodal_get_n_entities (const fvm_nodal_t *this_nodal, int entity_dim)
cs_gnum_t fvm_nodal_get_n_g_vertices (const fvm_nodal_t *this_nodal)
cs_gnum_t fvm_nodal_get_n_g_elements (const fvm_nodal_t *this_nodal, fvm_element_t element_type)
cs_lnum_t fvm_nodal_get_n_elements (const fvm_nodal_t *this_nodal, fvm_element_t element_type)
void fvm_nodal_get_parent_id (const fvm_nodal_t *this_nodal, int entity_dim, cs_lnum_t parent_id[])
const char ** fvm_nodal_get_global_vertex_labels (const fvm_nodal_t *this_nodal)
const cs_mesh_t * fvm_nodal_get_parent (const fvm_nodal_t *this_nodal)
void fvm_nodal_set_parent (fvm_nodal_t *this_nodal, const cs_mesh_t *parent)
void fvm_nodal_tesselate (fvm_nodal_t *this_nodal, fvm_element_t type, cs_lnum_t *error_count)
fvm_nodal_t * fvm_nodal_copy_edges (const char *name, const fvm_nodal_t *this_nodal)
void fvm_nodal_dump (const fvm_nodal_t *this_nodal)
const int fvm_nodal_n_vertices_element []
◆ fvm_nodal_change_parent_id()
void fvm_nodal_change_parent_id ( fvm_nodal_t *  this_nodal,
int  entity_dim
◆ fvm_nodal_copy()
fvm_nodal_t * fvm_nodal_copy ( const fvm_nodal_t *  this_nodal)
◆ fvm_nodal_copy_edges()
fvm_nodal_t * fvm_nodal_copy_edges ( const char *  name,
◆ fvm_nodal_create()
fvm_nodal_t * fvm_nodal_create ( const char *  name,
int  dim
◆ fvm_nodal_define_vertex_list()
void fvm_nodal_define_vertex_list ( fvm_nodal_t *  this_nodal,
◆ fvm_nodal_destroy()
fvm_nodal_t * fvm_nodal_destroy ( fvm_nodal_t *  this_nodal)
◆ fvm_nodal_dump()
void fvm_nodal_dump ( const fvm_nodal_t *  this_nodal)
◆ fvm_nodal_get_dim()
int fvm_nodal_get_dim ( const fvm_nodal_t *  this_nodal)
◆ fvm_nodal_get_global_vertex_labels()
const char ** fvm_nodal_get_global_vertex_labels ( const fvm_nodal_t *  this_nodal)
◆ fvm_nodal_get_max_entity_dim()
int fvm_nodal_get_max_entity_dim ( const fvm_nodal_t *  this_nodal)
◆ fvm_nodal_get_n_elements()
cs_lnum_t fvm_nodal_get_n_elements ( const fvm_nodal_t *  this_nodal,
◆ fvm_nodal_get_n_entities()
cs_lnum_t fvm_nodal_get_n_entities ( const fvm_nodal_t *  this_nodal,
int  entity_dim
◆ fvm_nodal_get_n_g_elements()
cs_gnum_t fvm_nodal_get_n_g_elements ( const fvm_nodal_t *  this_nodal,
◆ fvm_nodal_get_n_g_vertices()
cs_gnum_t fvm_nodal_get_n_g_vertices ( const fvm_nodal_t *  this_nodal)
◆ fvm_nodal_get_name()
const char * fvm_nodal_get_name ( const fvm_nodal_t *  this_nodal)
◆ fvm_nodal_get_parent()
const cs_mesh_t * fvm_nodal_get_parent ( const fvm_nodal_t *  this_nodal)
◆ fvm_nodal_get_parent_id()
void fvm_nodal_get_parent_id ( const fvm_nodal_t *  this_nodal,
int  entity_dim,
◆ fvm_nodal_init_io_num()
void fvm_nodal_init_io_num ( fvm_nodal_t *  this_nodal,
int  entity_dim
◆ fvm_nodal_make_vertices_private()
void fvm_nodal_make_vertices_private ( fvm_nodal_t *  this_nodal)
◆ fvm_nodal_reduce()
void fvm_nodal_reduce ( fvm_nodal_t *  this_nodal,
int  del_vertex_num
◆ fvm_nodal_remove_parent_id()
void fvm_nodal_remove_parent_id ( fvm_nodal_t *  this_nodal,
int  entity_dim
◆ fvm_nodal_remove_tag()
void fvm_nodal_remove_tag ( fvm_nodal_t *  this_nodal,
int  entity_dim
◆ fvm_nodal_set_group_class_set()
void fvm_nodal_set_group_class_set ( fvm_nodal_t *  this_nodal,
const fvm_group_class_set_t *  gc_set
◆ fvm_nodal_set_parent()
void fvm_nodal_set_parent ( fvm_nodal_t *  this_nodal,
const cs_mesh_t *  parent
◆ fvm_nodal_set_shared_vertices()
void fvm_nodal_set_shared_vertices ( fvm_nodal_t *  this_nodal,
◆ fvm_nodal_set_tag()
void fvm_nodal_set_tag ( fvm_nodal_t *  this_nodal,
const int  tag[],
int  entity_dim
◆ fvm_nodal_tesselate()
void fvm_nodal_tesselate ( fvm_nodal_t *  this_nodal,
fvm_element_t  type,
cs_lnum_t *  error_count
◆ fvm_nodal_transfer_global_vertex_labels()
void fvm_nodal_transfer_global_vertex_labels ( fvm_nodal_t *  this_nodal,
char *  g_labels[]
◆ fvm_nodal_transfer_vertex_io_num()
void fvm_nodal_transfer_vertex_io_num ( fvm_nodal_t *  this_nodal,
fvm_io_num_t **  io_num
◆ fvm_nodal_transfer_vertices()
cs_coord_t * fvm_nodal_transfer_vertices ( fvm_nodal_t *  this_nodal,
◆ fvm_nodal_n_vertices_element
const int fvm_nodal_n_vertices_element[]
extern
