fvm_box.h File Reference
#include "fvm/fvm_defs.h"
#include "fvm/fvm_morton.h"
+ Include dependency graph for fvm_box.h:
Typedefs
typedef struct _fvm_box_distrib_t fvm_box_distrib_t
fvm_box_set_t * fvm_box_set_create (int dim, int normalize, int allow_projection, cs_lnum_t n_boxes, const cs_gnum_t *box_gnum, const cs_coord_t *box_extents)
void fvm_box_set_destroy (fvm_box_set_t **boxes)
int fvm_box_set_get_dim (const fvm_box_set_t *boxes)
cs_lnum_t fvm_box_set_get_size (const fvm_box_set_t *boxes)
cs_gnum_t fvm_box_set_get_global_size (const fvm_box_set_t *boxes)
const cs_coord_t * fvm_box_set_get_extents (fvm_box_set_t *boxes)
const cs_gnum_t * fvm_box_set_get_g_num (fvm_box_set_t *boxes)
void fvm_box_set_build_morton_index (const fvm_box_set_t *boxes, fvm_box_distrib_t *distrib, cs_lnum_t n_leaves, fvm_morton_code_t *leaf_codes, cs_lnum_t *weight)
void fvm_box_set_redistribute (const fvm_box_distrib_t *box_distrib, fvm_box_set_t *boxes)
void fvm_box_set_dump (const fvm_box_set_t *boxes, int verbosity)
Typedef Documentation
◆ fvm_box_distrib_t
◆ fvm_box_set_build_morton_index()
void fvm_box_set_build_morton_index ( const fvm_box_set_t *  boxes,
fvm_box_distrib_t *  distrib,
cs_lnum_t  n_leaves,
fvm_morton_code_t *  leaf_codes,
cs_lnum_t *  weight
◆ fvm_box_set_create()
fvm_box_set_t * fvm_box_set_create ( int  dim,
int  normalize,
cs_lnum_t  n_boxes,
const cs_gnum_t *  box_gnum,
const cs_coord_t *  box_extents
◆ fvm_box_set_destroy()
void fvm_box_set_destroy ( fvm_box_set_t **  boxes)
◆ fvm_box_set_dump()
void fvm_box_set_dump ( const fvm_box_set_t *  boxes,
int  verbosity
◆ fvm_box_set_get_dim()
int fvm_box_set_get_dim ( const fvm_box_set_t *  boxes)
◆ fvm_box_set_get_extents()
const cs_coord_t * fvm_box_set_get_extents ( fvm_box_set_t *  boxes)
◆ fvm_box_set_get_g_num()
const cs_gnum_t * fvm_box_set_get_g_num ( fvm_box_set_t *  boxes)
◆ fvm_box_set_get_global_size()
cs_gnum_t fvm_box_set_get_global_size ( const fvm_box_set_t *  boxes)
◆ fvm_box_set_get_size()
cs_lnum_t fvm_box_set_get_size ( const fvm_box_set_t *  boxes)
◆ fvm_box_set_redistribute()
void fvm_box_set_redistribute ( const fvm_box_distrib_t *  box_distrib,
