cs_xdef.cpp File Reference
Functions to handle extended definitions of quantities thanks to the cs_xdef_t structures. More...
#include "base/cs_mem.h"
#include "base/cs_array.h"
#include "base/cs_field.h"
#include "cdo/cs_flag.h"
#include "base/cs_log.h"
#include "cdo/cs_xdef.h"
+ Include dependency graph for cs_xdef.cpp:
Macros
#define CS_XDEF_DBG   0
cs_xdef_t * cs_xdef_volume_create (cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context)
 Allocate and initialize a new cs_xdef_t structure based on volumic elements. More...
cs_xdef_t * cs_xdef_boundary_create (cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context)
 Allocate and initialize a new cs_xdef_t structure based on boundary elements. More...
cs_xdef_t * cs_xdef_timestep_create (cs_xdef_type_t type, cs_flag_t state, cs_flag_t meta, void *context)
 Allocate and initialize a new cs_xdef_t structure for setting the time step. More...
cs_xdef_t * cs_xdef_free (cs_xdef_t *d)
 Free a cs_xdef_t structure. More...
cs_xdef_t * cs_xdef_copy (cs_xdef_t *src)
 copy a cs_xdef_t structure More...
void cs_xdef_set_input_context (cs_xdef_t *d, void *input)
 In the case of a definition by an analytic function, a time function or a function relying on degrees of freedom (DoFs), this function allows one to set a more or less complex input data structure. This call should be done before the first evaluation of the associated cs_xdef_t structure. More...
void cs_xdef_set_free_input_function (cs_xdef_t *d, cs_xdef_free_input_t *free_input)
 In case of a definition by an analytic function, a time function or a function relying on degrees of freedom (DoFs). One can set a function to free a complex input data structure (please refer to cs_xdef_free_input_t) for more details. More...
void cs_xdef_set_quadrature (cs_xdef_t *d, cs_quadrature_type_t qtype)
 Set the type of quadrature to use for evaluating the given description. More...
cs_quadrature_type_t cs_xdef_get_quadrature (const cs_xdef_t *d)
 Get the type of quadrature to use for evaluating the given description. More...
cs_xdef_type_t cs_xdef_get_type (const cs_xdef_t *d)
 Retrieve the flag dedicated to the state. More...
cs_flag_t cs_xdef_get_state_flag (const cs_xdef_t *d)
void cs_xdef_log_setup (const char *prefix, const cs_xdef_t *d)
 Output the settings related to a cs_xdef_t structure in the setup logging file. More...
void cs_xdef_log (cs_log_t log_type, const char *prefix, const cs_xdef_t *d)
 Output the settings related to a cs_xdef_t structure. More...
const char * cs_xdef_type_get_name (cs_xdef_type_t xdef_type)
 Retrieve a pointer to the cs_xdef_type's name string. More...
void cs_xdef_array_set_values (cs_xdef_t *d, bool is_owner, cs_real_t *values)
 In case of definition by array, set the array values after having added this definition. More...
void cs_xdef_array_set_zone_id (cs_xdef_t *d, int z_id)
 In case of definition by array, set the zone id related to the size of the array. By default, the zone id is the same as the zone id related to the definition so that there is no need to call this function. More...
void cs_xdef_array_build_full2subset (const cs_xdef_t *d)
 In case of definition by array, build the full2subset array. The direct members of the cs_xdef_t structure are not modified but the context dedicated to definition by array is updated. d is declared as const to avoid a compiler warning. More...
void cs_xdef_array_set_adjacency (cs_xdef_t *d, const cs_adjacency_t *adj)
 In case of definition by array, set the optional adjacency structure. More...
void cs_xdef_array_set_sublist (cs_xdef_t *d, cs_lnum_t n_elts, const cs_lnum_t elt_ids[])
 In case of definition by array, set the optional sub-list of elements used to link elements in the partial view and in the full-length view. More...
cs_real_t * cs_xdef_field_get_values (cs_xdef_t *def)
 Get the current field values in case of definition by field. More...
static const char * _xdef_type_name []
◆ CS_XDEF_DBG
◆ cs_xdef_array_build_full2subset()
void cs_xdef_array_build_full2subset ( const cs_xdef_t *  d)
[in,out]dpointer to a cs_xdef_t structure
◆ cs_xdef_array_set_adjacency()
void cs_xdef_array_set_adjacency ( cs_xdef_t *  d,
const cs_adjacency_t *  adj
[in]adjpointer to the adjacency structure
◆ cs_xdef_array_set_sublist()
void cs_xdef_array_set_sublist ( cs_xdef_t *  d,
cs_lnum_t  n_elts,
[in]n_eltsnumber of elements in the sub-list
[in]elt_idslist of element ids constituting the sub-list
◆ cs_xdef_array_set_values()
void cs_xdef_array_set_values ( cs_xdef_t *  d,
bool  is_owner,
cs_real_t *  values
[in]is_ownermanage or not the lifecycle of the array values
[in]valuesarray of values
◆ cs_xdef_array_set_zone_id()
void cs_xdef_array_set_zone_id ( cs_xdef_t *  d,
int  z_id
[in]z_idzone id associated to the array size
◆ cs_xdef_boundary_create()
cs_xdef_t * cs_xdef_boundary_create ( cs_xdef_type_t  type,
int  dim,
int  z_id,
cs_flag_t  state,
cs_flag_t  meta,
void *  context
[in]typetype of definition
[in]dimdimension of the values to define
[in]z_idvolume zone id
[in]stateflag to know if this uniform, cellwise, steady...
[in]metametadata associated to this description
[in]contextpointer to a structure
a pointer to the new cs_xdef_t structure
◆ cs_xdef_copy()
cs_xdef_t * cs_xdef_copy ( cs_xdef_t *  src)
[in]srcpointer to a cs_xdef_t structure to copy
a pointer to a new allocated cs_xdef_t structure
◆ cs_xdef_field_get_values()
cs_real_t * cs_xdef_field_get_values ( cs_xdef_t *  def)
[in]defpointer to a cs_xdef_t structure
the pointer to the current field values
◆ cs_xdef_free()
cs_xdef_t * cs_xdef_free ( cs_xdef_t *  d)
nullptr
◆ cs_xdef_get_quadrature()
cs_quadrature_type_t cs_xdef_get_quadrature ( const cs_xdef_t *  d)
[in]dpointer to a cs_xdef_t structure
◆ cs_xdef_get_state_flag()
cs_flag_t cs_xdef_get_state_flag ( const cs_xdef_t *  d)
the value of the flag
◆ cs_xdef_get_type()
cs_xdef_type_t cs_xdef_get_type ( const cs_xdef_t *  d)
◆ cs_xdef_log()
void cs_xdef_log ( cs_log_t  log_type,
const char *  prefix,
const cs_xdef_t *  d
[in]log_typerelated log file to consider
[in]prefixoptional string
◆ cs_xdef_log_setup()
void cs_xdef_log_setup ( const char *  prefix,
const cs_xdef_t *  d
◆ cs_xdef_set_free_input_function()
void cs_xdef_set_free_input_function ( cs_xdef_t *  d,
cs_xdef_free_input_t *  free_input
[in]free_inputpointer to a function which free the input structure
◆ cs_xdef_set_input_context()
void cs_xdef_set_input_context ( cs_xdef_t *  d,
void *  input
[in]inputpointer to an input structure
◆ cs_xdef_set_quadrature()
void cs_xdef_set_quadrature ( cs_xdef_t *  d,
[in]qtypetype of quadrature
◆ cs_xdef_timestep_create()
cs_xdef_t * cs_xdef_timestep_create ( cs_xdef_type_t  type,
cs_flag_t  state,
cs_flag_t  meta,
void *  context
[in]contextpointer to a structure storing the parameters (cast on-the-fly according to the type of definition)
◆ cs_xdef_type_get_name()
const char * cs_xdef_type_get_name ( cs_xdef_type_t  xdef_type)
[in]xdef_typetype to query
a pointer to mathing name string
◆ cs_xdef_volume_create()
cs_xdef_t * cs_xdef_volume_create ( cs_xdef_type_t  type,
int  dim,
int  z_id,
cs_flag_t  state,
cs_flag_t  meta,
void *  context
◆ _xdef_type_name
const char* _xdef_type_name[]
static
Initial value:
= {"CS_XDEF_BY_ANALYTIC_FUNCTION",
"CS_XDEF_BY_ARRAY",
"CS_XDEF_BY_DOF_FUNCTION",
"CS_XDEF_BY_FIELD",
"CS_XDEF_BY_FUNCTION",
"CS_XDEF_BY_QOV",
"CS_XDEF_BY_SUB_DEFINITIONS",
"CS_XDEF_BY_TIME_FUNCTION",
"CS_XDEF_BY_VALUE",
"out of range"}
