cs_wall_distance.cpp File Reference
#include <float.h>
#include <stdarg.h>
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "base/cs_dispatch.h"
#include "alge/cs_blas.h"
#include "base/cs_boundary_conditions_set_coeffs.h"
#include "alge/cs_convection_diffusion.h"
#include "base/cs_equation_iterative_solve.h"
#include "alge/cs_face_viscosity.h"
#include "mesh/cs_mesh.h"
#include "base/cs_reducers.h"
#include "base/cs_wall_distance.h"
+ Include dependency graph for cs_wall_distance.cpp:
void cs_wall_distance (int iterns)
 Compute distance to wall by solving a 3d diffusion equation. Solve. More...
void cs_wall_distance_yplus (cs_real_t visvdr[])
 Compute the dimensionless distance to the wall solving a steady transport equation. More...
void cs_wall_distance_geometric (void)
 Computes distance to wall by a brute force geometric approach (serial only) More...
cs_wall_distance_options_t * cs_get_glob_wall_distance_options (void)
 Provide read/write access to cs_glob_wall_distance. More...
static bool _initialized = false
static cs_lnum_t n_wall = 0
static cs_wall_distance_options_t _wall_distance_options
const cs_wall_distance_options_t * cs_glob_wall_distance_options = &_wall_distance_options
Compute distance to wall.
◆ cs_get_glob_wall_distance_options()
cs_wall_distance_options_t * cs_get_glob_wall_distance_options ( void  )
pointer to global wall distance structure
◆ cs_wall_distance()
void cs_wall_distance ( int  iterns)
\[ -\divs ( \grad \varia ) = 1 \]
with:
  • $ \varia_|b = 0 $ at the wall
  • $ \grad \varia \cdot \vect{n} = 0 $ elsewhere The wall distance is then equal to:
 d \simeq -|\grad \varia |
 + \sqrt{ \grad \varia \cdot \grad \varia +2 \varia }
[in]iternsiteration number on Navier-Stokes equations
◆ cs_wall_distance_geometric()
void cs_wall_distance_geometric ( void  )
Compute distance to wall by a brute force geometric approach (serial only)
◆ cs_wall_distance_yplus()
void cs_wall_distance_yplus ( cs_real_t  visvdr[])
This function solves the following steady pure convection equation on $ \varia $:
\divs \left( \varia \vect{V} \right)
    - \divs \left( \vect{V} \right) \varia = 0
where the vector field $ \vect{V} $ is defined by:
 \vect{V} = \dfrac{ \grad y }{\norm{\grad y} }
The boundary conditions on $ \varia $ read:
 \varia = \dfrac{u_\star}{\nu} \textrm{ on walls}
 \dfrac{\partial \varia}{\partial n} = 0 \textrm{ elsewhere}
Then the dimensionless distance is deduced by:
 y^+ = y \varia
Then, Imposition of an amortization of Van Driest type for the LES. $ \nu_T $ is absorbed by $ (1-\exp(\dfrac{-y^+}{d^+}))^2 $ where $ d^+ $ is set at 26.
[in]visvdrdynamic viscosity in edge cells after driest velocity amortization
◆ _initialized
static
◆ _wall_distance_options
static
Initial value:
.need_compute = 0,
.is_up_to_date = 0,
.method = 1
◆ cs_glob_wall_distance_options
const cs_wall_distance_options_t* cs_glob_wall_distance_options = &_wall_distance_options
◆ n_wall
static
