cs_volume_zone.h File Reference
#include "base/cs_base.h"
#include "base/cs_zone.h"
+ Include dependency graph for cs_volume_zone.h:
Macros
#define CS_VOLUME_ZONE_INITIALIZATION   (1 << 0)
#define CS_VOLUME_ZONE_POROSITY   (1 << 1)
#define CS_VOLUME_ZONE_HEAD_LOSS   (1 << 2)
#define CS_VOLUME_ZONE_SOURCE_TERM   (1 << 3)
#define CS_VOLUME_ZONE_MASS_SOURCE_TERM   (1 << 4)
#define CS_VOLUME_ZONE_GWF_SOIL   (1 << 5)
#define CS_VOLUME_ZONE_SOLID   (1 << 6)
#define CS_VOLUME_ZONE_PHYSICAL_PROPERTIES   (1 << 7)
void cs_volume_zone_initialize (void)
 Initialize volume zone structures. More...
void cs_volume_zone_finalize (void)
 Free all volume zone structures. More...
int cs_volume_zone_n_zones (void)
 Return number of volume zones defined. More...
int cs_volume_zone_n_zones_time_varying (void)
 Return number of volume zones which may vary in time. More...
void cs_volume_zone_build_all (bool mesh_modified)
 Update association of volume zones with a mesh. More...
int cs_volume_zone_define (const char *name, const char *criteria, int type_flag)
 Define a new volume zone using a selection criteria string. More...
int cs_volume_zone_define_by_func (const char *name, cs_mesh_location_select_t *func, void *input, int type_flag)
 Define a new mesh location with an associated selection function. More...
const cs_zone_t * cs_volume_zone_by_id (int id)
 Return a pointer to a volume zone based on its id. More...
const cs_zone_t * cs_volume_zone_by_name (const char *name)
 Return a pointer to a volume zone based on its name if present. More...
const cs_zone_t * cs_volume_zone_by_name_try (const char *name)
int cs_volume_zone_id_by_name (const char *z_name)
 Retrieve the volume zone id from its zone name. If the zone name is equal to NULL or has an empty length, then the default zone id (=0) corresponding to all entities is returned. More...
void cs_volume_zone_set_type (int id, int type_flag)
 Set type flag for a given volume zone. More...
void cs_volume_zone_set_time_varying (int id, bool time_varying)
 Set time varying behavior for a given volume zone. More...
void cs_volume_zone_set_overlay (int id, bool allow_overlay)
 Set overlay behavior for a given volume zone. More...
const int * cs_volume_zone_cell_zone_id (void)
 Return pointer to zone id associated with each cell. More...
void cs_volume_zone_log_info (const cs_zone_t *z)
 Print info relative to a given volume zone to log file. More...
void cs_volume_zone_log_setup (void)
 Log setup information relative to defined volume zones. More...
int cs_volume_zone_n_type_zones (int type_flag)
 Return number of volume zones associated with a given zone flag. More...
cs_lnum_t cs_volume_zone_n_type_cells (int type_flag)
 Return number of volume zone cells associated with a given zone flag. More...
void cs_volume_zone_select_type_cells (int type_flag, cs_lnum_t cell_ids[])
 Select cells associated with volume zones of a given type. More...
void cs_volume_zone_tag_cell_type (int zone_type_flag, int tag_value, int tag[])
 Tag cells of a given zone type. More...
void cs_volume_zone_print_info (void)
 Print volume zones information to listing file. More...
◆ cs_volume_zone_build_all()
void cs_volume_zone_build_all ( bool  mesh_modified)
[in]mesh_modifiedindicate if mesh has been modified
◆ cs_volume_zone_by_id()
const cs_zone_t * cs_volume_zone_by_id ( int  id)
This function requires that a volume zone of the given id is defined.
[in]idzone id
pointer to the volume zone structure
◆ cs_volume_zone_by_name()
const cs_zone_t * cs_volume_zone_by_name ( const char *  name)
This function requires that a volume zone of the given name is defined.
[in]namevolume zone name
pointer to (read-only) zone structure
◆ cs_volume_zone_by_name_try()
const cs_zone_t * cs_volume_zone_by_name_try ( const char *  name)
If no volume zone of the given name is defined, returned pointer is null.
pointer to (read only) zone structure, or NULL
If no volume zone of the given name is defined, nullptr is returned.
pointer to (read only) zone structure, or nullptr
◆ cs_volume_zone_cell_zone_id()
const int * cs_volume_zone_cell_zone_id ( void  )
In case of overlayed zones, the highest zone id associated with a given cell is given.
◆ cs_volume_zone_define()
int cs_volume_zone_define ( const char *  name,
const char *  criteria,
int  type_flag
[in]namename of location to define
[in]criteriaselection criteria for associated elements
[in]type_flagmask of zone category values
id of newly defined volume zone
◆ cs_volume_zone_define_by_func()
int cs_volume_zone_define_by_func ( const char *  name,
cs_mesh_location_select_t *  func,
void *  input,
int  type_flag
[in]funcpointer to selection function for associated elements
[in,out]inputpointer to optional (untyped) value or structure.
id of newly defined created mesh location
◆ cs_volume_zone_finalize()
void cs_volume_zone_finalize ( void  )
◆ cs_volume_zone_id_by_name()
int cs_volume_zone_id_by_name ( const char *  z_name)
[in]z_namename of the zone or NULL or ""
the id of the volume zone
[in]z_namename of the zone or nullptr or ""
◆ cs_volume_zone_initialize()
void cs_volume_zone_initialize ( void  )
This defines a default volume zone. This is the first function of the volume zone handling functions which should be called, and it should only be called after cs_mesh_location_initialize.
◆ cs_volume_zone_log_info()
void cs_volume_zone_log_info ( const cs_zone_t *  z)
[in]zpointer to volume zone structure
◆ cs_volume_zone_log_setup()
void cs_volume_zone_log_setup ( void  )
◆ cs_volume_zone_n_type_cells()
cs_lnum_t cs_volume_zone_n_type_cells ( int  type_flag)
Note that in the case of overlapping zones, a cell may be accounted for multiple times.
[in]type_flagflag to compare to zone type
number of cells in zones matching the given type flag
◆ cs_volume_zone_n_type_zones()
int cs_volume_zone_n_type_zones ( int  type_flag)
number of zones matching the given type flag
◆ cs_volume_zone_n_zones()
int cs_volume_zone_n_zones ( void  )
◆ cs_volume_zone_n_zones_time_varying()
int cs_volume_zone_n_zones_time_varying ( void  )
number of zones which may vary in time
◆ cs_volume_zone_print_info()
void cs_volume_zone_print_info ( void  )
◆ cs_volume_zone_select_type_cells()
void cs_volume_zone_select_type_cells ( int  type_flag,
[out]cell_idsids of selected cells (size: given by cs_volume_zone_n_type_cells)
◆ cs_volume_zone_set_overlay()
void cs_volume_zone_set_overlay ( int  id,
bool  allow_overlay
[in]idvolume zone id
[in]allow_overlaytrue if the zone may be overlayed by another
◆ cs_volume_zone_set_time_varying()
void cs_volume_zone_set_time_varying ( int  id,
bool  time_varying
[in]time_varyingtrue if the zone's definition varies in time
◆ cs_volume_zone_set_type()
void cs_volume_zone_set_type ( int  id,
int  type_flag
[in]type_flagvolume zone type flag
◆ cs_volume_zone_tag_cell_type()
void cs_volume_zone_tag_cell_type ( int  zone_type_flag,
int  tag_value,
int  tag[]
The tag array should be initialized. The given tag_value is associted to cells of the given zone type using a logical "or", so multiple flag bits can be handled using the same array if necessary.
[in]zone_type_flagzone types to tag
[in]tag_valuetag value to add to cells of matching zones
[in,out]tagtag value for each cell
