cs_user_fluid_structure_interaction.cpp File Reference
User-defined functions dedicated to Fluid-Structure interaction modeling. More...
#include "cs_headers.h"
+ Include dependency graph for cs_user_fluid_structure_interaction.cpp:
void cs_user_fsi_structure_define (int is_restart, int n_structs, int *plot, cs_time_control_t *plot_time_control, cs_real_t *aexxst, cs_real_t *bexxst, cs_real_t *cfopre, cs_real_t xstr0[][3], cs_real_t vstr0[][3], cs_real_t xstreq[][3])
 Definition of internal mobile structures and corresponding initial conditions (initial displacement and velocity ). More...
void cs_user_fsi_structure_values (int n_structs, const cs_time_step_t *ts, const cs_real_t xstreq[][3], const cs_real_t xstr[][3], const cs_real_t vstr[][3], cs_real_t xmstru[][3][3], cs_real_t xcstru[][3][3], cs_real_t xkstru[][3][3], cs_real_t forstr[][3], cs_real_t dtstr[])
 Time-based settings for internal mobile structures. More...
void cs_user_fsi_structure_num (cs_domain_t *domain, int structure_num[], cs_mobile_structure_type_t structure_typ[])
 Define structure numbers for faces associated with internal or external (code_aster) structures. More...
void cs_user_fsi_external_displacement (const cs_domain_t *domain, const cs_real_3_t *b_stress, cs_real_3_t *disaple)
 Compute displacement fluid boundary for the external structures (code_aster excluded). More...
void cs_user_fsi_external_cvg (const cs_domain_t *domain, const cs_real_t epsilon, int *cvg_status, cs_real_t *residual)
 Compute convergence state of the external structures (code_aster excluded). More...
◆ cs_user_fsi_external_cvg()
void cs_user_fsi_external_cvg ( const cs_domain_t *  domain,
int *  cvg_status,
cs_real_t *  residual
Compute converge status and residual of the external coupling Convergence status: 0 - external coupling has not converged 1 - external coupling has converged
[in]domainpointer to a cs_domain_t structure
[in]epsilonconvergence criterion
[out]cvg_statusconvergence status
[out]residualvalue of the residual
◆ cs_user_fsi_external_displacement()
void cs_user_fsi_external_displacement ( const cs_domain_t *  domain,
const cs_real_3_t *  b_stress,
cs_real_3_t *  disaple
[in]b_stresspointer to boundary stress array
[in,out]disaplepointer to mesh_displacement array
◆ cs_user_fsi_structure_define()
void cs_user_fsi_structure_define ( int  is_restart,
int  n_structs,
int *  plot,
cs_time_control_t *  plot_time_control,
cs_real_t *  aexxst,
cs_real_t *  bexxst,
cs_real_t *  cfopre,
[in]is_restartindicate if computation is restarted
[in]n_structsnumber of mobile structures
[in,out]plot;monitoring format mask 0: no plot 1: plot to text (.dat) format 2: plot to .csv format 3: plot to both formats
[in,out]plot_time_controlplot time output frequency control
[in,out]aexxstcoefficient for predicted displacement
[in,out]bexxstcoefficient for predicted displacement
[in,out]cfoprecoefficient for predicted force
[in,out]xstr0initial displacement per structure
[in,out]vstr0initial velocity per structure
[in,out]xstreqdisplacement of initial mesh relative to structures position at equilibrium
◆ cs_user_fsi_structure_num()
void cs_user_fsi_structure_num ( cs_domain_t *  domain,
Structure numbers associated to a given face have the following values:
  • -i where coupled to i-th (1-to n) external (code_aster) structure.
  • 0 where not coupled with an internal or external structure.
  • i where coupled to i-th (1-to n) internal (mass-spring) structure.
[in,out]structure_numstructure id associated to each face
[in,out]structure_typstructure type associated to each face
◆ cs_user_fsi_structure_values()
void cs_user_fsi_structure_values ( int  n_structs,
const cs_time_step_t *  ts,
cs_real_t  dtstr[]
[in]tstime step structure
[in]xstreqdisplacement of initial mesh rel. to equilibrium
[in]xstrstructural displacement
[in]vstrstructural velocity
[in,out]xmstrumatrix of structural mass
[in,out]xcstrumatrix of structural friction
[in,out]xkstrumatrix of structural stiffness
[in,out]forstrforces acting on structures (take forces)
[in,out]dtstrstructural time step
