cs_turbulence_rij.cpp File Reference
#include <chrono>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "base/cs_base.h"
#include "alge/cs_blas.h"
#include "base/cs_dispatch.h"
#include "cdo/cs_domain.h"
#include "base/cs_equation_iterative_solve.h"
#include "cdo/cs_equation_param.h"
#include "alge/cs_face_viscosity.h"
#include "base/cs_field.h"
#include "alge/cs_gradient.h"
#include "lagr/cs_lagr.h"
#include "base/cs_log_iteration.h"
#include "base/cs_mass_source_terms.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "base/cs_reducers.h"
#include "base/cs_rotation.h"
#include "base/cs_solid_zone.h"
#include "base/cs_timer.h"
#include "base/cs_turbomachinery.h"
#include "turb/cs_turbulence_bc.h"
#include "base/cs_volume_mass_injection.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_wall_functions.h"
#include "turb/cs_turbulence_rij.h"
+ Include dependency graph for cs_turbulence_rij.cpp:
void cs_turbulence_rij (int phase_id)
 Solve the $ R_{ij} - \epsilon $ for incompressible flows or slightly compressible flows for one time step. More...
void cs_turbulence_rij_solve_alpha (int f_id, int phase_id, cs_real_t c_durbin_l)
 Solve the equation on alpha in the framework of the Rij-EBRSM model. More...
void cs_turbulence_rij_init_by_ref_quantities (cs_real_t uref, cs_real_t almax)
 Initialize Rij-epsilon variables based on reference quantities. More...
void cs_turbulence_rij_clip (int phase_id, cs_lnum_t n_cells)
 Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version). More...
void cs_turbulence_rij_mu_t (int phase_id)
 Compute the turbulent viscosity for the Reynolds Stress model. More...
void cs_turbulence_rij_anisotropic_mu_t (const cs_mesh_quantities_t *mq, cs_lnum_t n_cells, int phase_id, bool idfm, bool iggafm, bool iebdfm)
 Compute anisotropic turbulent viscosity for RSM models. More...
void cs_turbulence_rij_compute_rusanov (void)
 Compute Rusanov equivalent diffusivity of the model. ! More...
◆ cs_turbulence_rij()
void cs_turbulence_rij ( int  phase_id)
Please refer to the $ R_{ij} - \epsilon $ model section of the theory guide for more informations, as well as the turrij section.
[in]phase_idturbulent phase id (-1 for single phase flow) !
◆ cs_turbulence_rij_anisotropic_mu_t()
void cs_turbulence_rij_anisotropic_mu_t ( const cs_mesh_quantities_t *  mq,
cs_lnum_t  n_cells,
int  phase_id,
bool  idfm,
bool  iggafm,
bool  iebdfm
[in]mqmesh quantities
[in]n_cellsnumber of cells
[in]idfmuse DFM model ?
[in]iggafmuse AFM model ?
[in]iebdfmuse EBDFM model ?
◆ cs_turbulence_rij_clip()
void cs_turbulence_rij_clip ( int  phase_id,
cs_lnum_t  n_cells
◆ cs_turbulence_rij_compute_rusanov()
void cs_turbulence_rij_compute_rusanov ( void  )
◆ cs_turbulence_rij_init_by_ref_quantities()
void cs_turbulence_rij_init_by_ref_quantities ( cs_real_t  uref,
cs_real_t  almax
If uref is not provided (0 or negative), values are set at a large negative value (-cs_math_big_r) to allow for later checks.
[in]urefcharacteristic flow velocity
[in]almaxcharacteristic macroscopic length of the domain
◆ cs_turbulence_rij_mu_t()
void cs_turbulence_rij_mu_t ( int  phase_id)
◆ cs_turbulence_rij_solve_alpha()
void cs_turbulence_rij_solve_alpha ( int  f_id,
int  phase_id,
Also called for alpha of scalars for EB-DFM.
[in]f_idfield id of alpha variable
[in]c_durbin_lconstant for the Durbin length !
