cs_turbulence_ke.cpp File Reference
#include <errno.h>
#include <stdarg.h>
#include <float.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "alge/cs_balance.h"
#include "alge/cs_blas.h"
#include "alge/cs_convection_diffusion.h"
#include "base/cs_boundary_conditions_set_coeffs.h"
#include "base/cs_dispatch.h"
#include "cdo/cs_equation.h"
#include "base/cs_equation_iterative_solve.h"
#include "alge/cs_face_viscosity.h"
#include "base/cs_field.h"
#include "base/cs_mem.h"
#include "alge/cs_gradient.h"
#include "lagr/cs_lagr.h"
#include "base/cs_log.h"
#include "base/cs_log_iteration.h"
#include "base/cs_mass_source_terms.h"
#include "base/cs_math.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "base/cs_reducers.h"
#include "base/cs_rotation.h"
#include "base/cs_solid_zone.h"
#include "turb/cs_turbulence_rotation.h"
#include "base/cs_volume_mass_injection.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_wall_functions.h"
#include "atmo/cs_at_data_assim.h"
#include "atmo/cs_atprke.h"
#include "turb/cs_turbulence_ke.h"
void cs_turbulence_ke (int phase_id, cs_real_t *prdv2f)
 Solve the k-epsilon equations. More...
void cs_turbulence_ke_clip (int phase_id, cs_lnum_t n_cells, int iclip)
 Clipping of the turbulent kinetic energy and turbulent dissipation. More...
void cs_turbulence_ke_mu_t (int phase_id)
 Calculation of turbulent viscosity for the K-epsilon model. More...
void cs_turbulence_ke_q_mu_t (int phase_id)
 Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al. (2005) More...
void cs_turbulence_ke_q (int phase_id, cs_real_6_t rij[])
 Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al.) More...
Solve the $ k - \varepsilon $ for incompressible flows or slightly compressible flows for one time step.
◆ cs_turbulence_ke()
void cs_turbulence_ke ( int  phase_id,
cs_real_t *  prdv2f
[in]phase_idturbulent phase id (-1 for single phase flow)
[out]prdv2fv2f production term
◆ cs_turbulence_ke_clip()
void cs_turbulence_ke_clip ( int  phase_id,
cs_lnum_t  n_cells,
int  iclip
[in]n_cellsnumber of cells
[in]iclipindicator = 0 if viscl0 is used otherwise viscl is used.
◆ cs_turbulence_ke_mu_t()
void cs_turbulence_ke_mu_t ( int  phase_id)
◆ cs_turbulence_ke_q()
void cs_turbulence_ke_q ( int  phase_id,
cs_real_6_t  rij[]
[out]rijnon linear terms of quadratic Boussinesq approximation
◆ cs_turbulence_ke_q_mu_t()
void cs_turbulence_ke_q_mu_t ( int  phase_id)
