cs_tree.cpp File Reference
#include <ctype.h>
#include <errno.h>
#include "base/cs_mem.h"
#include "base/cs_tree.h"
+ Include dependency graph for cs_tree.cpp:
cs_tree_node_t * cs_tree_node_create (const char *name)
 Create an empty node. More...
void cs_tree_node_free (cs_tree_node_t **pnode)
 Free a branch in a tree starting from a node. More...
void cs_tree_node_set_name (cs_tree_node_t *node, const char *name)
 Name or rename a node. More...
cs_tree_node_t * cs_tree_node_get_child (cs_tree_node_t *node, const char *name)
 Return a child node with a given name. More...
cs_tree_node_t * cs_tree_node_get_next_of_name (cs_tree_node_t *node)
 Return the next sibling node with the same name (type) as a given node. More...
const char * cs_tree_node_get_tag (cs_tree_node_t *node, const char *tag)
 Search for a child node (used as a tag) with a given name, and return its associated string value. More...
void cs_tree_node_set_tag (cs_tree_node_t *node, const char *tag, const char *tag_str)
 Assign a tag to a given node. More...
const char * cs_tree_node_get_value_str (cs_tree_node_t *node)
 Return a character string value associated to a node if present. More...
void cs_tree_node_set_value_str (cs_tree_node_t *node, const char *val)
 Assign a character string value to a node. More...
const bool * cs_tree_node_get_values_bool (cs_tree_node_t *node)
 Return array of boolean values associated to a node if present. More...
void cs_tree_node_set_values_bool (cs_tree_node_t *node, int n, const bool *val)
 Assign an array of boolean values to node. More...
const int * cs_tree_node_get_values_int (cs_tree_node_t *node)
 Return an array of integer values associated to a node if present. More...
void cs_tree_node_set_values_int (cs_tree_node_t *node, int n, const int *val)
 Assign an array of integer values to a node. More...
const cs_real_t * cs_tree_node_get_values_real (cs_tree_node_t *node)
 Return an array of real values associated to a node if present. More...
void cs_tree_node_set_values_real (cs_tree_node_t *node, int n, const cs_real_t *val)
 Assign an array of real values to a node. More...
const char * cs_tree_node_get_child_value_str (cs_tree_node_t *node, const char *child_name)
 Return a string value associated to a child node if present. More...
const bool * cs_tree_node_get_child_values_bool (cs_tree_node_t *node, const char *child_name)
 Return array of boolean values associated to a child node if present. More...
const int * cs_tree_node_get_child_values_int (cs_tree_node_t *node, const char *child_name)
 Return an array of integer values associated to a child node if present. More...
const cs_real_t * cs_tree_node_get_child_values_real (cs_tree_node_t *node, const char *child_name)
 Return an array of real values associated to a child node if present. More...
cs_tree_node_t * cs_tree_node_get_sibling_with_tag (cs_tree_node_t *node, const char *tag, const char *tag_value)
 Retrieve the pointer to a node with a child having a given (character string) tag value. More...
void cs_tree_node_dump (cs_log_t log, int depth, const cs_tree_node_t *node)
 Dump a cs_tree_node_t structure. More...
cs_tree_node_t * cs_tree_add_node (cs_tree_node_t *node, const char *path)
 Add a node to a tree. More...
cs_tree_node_t * cs_tree_get_node (cs_tree_node_t *node, const char *path)
 Retrieve the pointer to a node matching a given path. More...
int cs_tree_get_node_count (cs_tree_node_t *node, const char *path)
 Count number of nodes sharing a given path. More...
cs_tree_node_t * cs_tree_add_child (cs_tree_node_t *parent, const char *name)
 Create and add a node in a tree below the given parent node. More...
cs_tree_node_t * cs_tree_add_sibling (cs_tree_node_t *sibling, const char *name)
 Create and add a node in a tree at the right of the given node. More...
cs_tree_node_t * cs_tree_find_node (cs_tree_node_t *root, const char *sub_path)
 Retrieve the pointer to a node matching a given sub-path. More...
cs_tree_node_t * cs_tree_find_node_next (cs_tree_node_t *root, cs_tree_node_t *current, const char *sub_path)
 Retrieve the pointer to the next node matching a given sub-path and following a given node in a depth-first order. More...
cs_tree_node_t * cs_tree_find_node_simple (cs_tree_node_t *root, const char *name)
 Retrieve the pointer to a node's descendants matching a given name. More...
cs_tree_node_t * cs_tree_find_node_next_simple (cs_tree_node_t *root, cs_tree_node_t *current, const char *name)
 Retrieve the pointer to the next node with a given name and following a given node in a depth-first order. More...
int cs_tree_get_sub_node_count (cs_tree_node_t *root, const char *sub_path)
 Count a node's descendants matching a given sub-path. More...
int cs_tree_get_sub_node_count_simple (cs_tree_node_t *root, const char *name)
 Count a node's descendants with a given name. More...
void cs_tree_dump (cs_log_t log, int depth, const cs_tree_node_t *node)
 Dump a cs_tree_node_t structure starting from the node "root". More...
Tree structure used to store data and settings.
◆ cs_tree_add_child()
cs_tree_node_t * cs_tree_add_child ( cs_tree_node_t *  parent,
const char *  name
Create and add a node in a tree below the given node.
[in,out]parentpointer to the parent node to handle.
[in]namename of the node to add
pointer to the new node in the tree structure
◆ cs_tree_add_node()
cs_tree_node_t * cs_tree_add_node ( cs_tree_node_t *  node,
const char *  path
This node is located at "path" from the given node, with the path separator indicated by a "/".
Exits on error if a node already exists on this path.
[in,out]nodepointer to the node where we start searching
[in]pathstring describing the path access
◆ cs_tree_add_sibling()
cs_tree_node_t * cs_tree_add_sibling ( cs_tree_node_t *  sibling,
const char *  name
[in,out]siblingpointer to the sibling node to handle
◆ cs_tree_dump()
void cs_tree_dump ( cs_log_t  log,
int  depth,
const cs_tree_node_t *  node
Dump a cs_tree_node_t structure starting from a given node.
[in]logindicate which log file to use
[in]depthstarting depth in the tree
[in]nodepointer to a cs_tree_node_t to dump
◆ cs_tree_find_node()
cs_tree_node_t * cs_tree_find_node ( cs_tree_node_t *  root,
const char *  sub_path
This node is located at "path" from the given node or one of its descendants, with the path separator indicated by a "/".
In case of multiple nodes sharing the given path, the first such node is returned, using a depth-first search.
[in]rootpointer to the root node where we start searching
[in]sub_pathstring describing the path access
pointer to the first matching node, or null if not found
◆ cs_tree_find_node_next()
cs_tree_node_t * cs_tree_find_node_next ( cs_tree_node_t *  root,
cs_tree_node_t *  current,
If current is nullptr, this function behaves as cs_tree_find_node.
[in]currentpointer to the current node
pointer to the next matching node, or null if not found
◆ cs_tree_find_node_next_simple()
cs_tree_node_t * cs_tree_find_node_next_simple ( cs_tree_node_t *  root,
const char *  name
This function is similar to cs_tree_find_node_next, but is simpler (as it assumes a simple name instead of a more general path) and should thus be faster.
[in]namenode name searched for
◆ cs_tree_find_node_simple()
cs_tree_node_t * cs_tree_find_node_simple ( cs_tree_node_t *  root,
const char *  name
This function is similar to cs_tree_find_node, but is simpler (as it assumes a simple name instead of a more general path) and should thus be faster.
◆ cs_tree_get_node()
cs_tree_node_t * cs_tree_get_node ( cs_tree_node_t *  node,
const char *  path
In case of multiple nodes sharing the given path, the first such node is returned.
[in]nodepointer to the node where we start searching
pointer to the node, or null if not found
◆ cs_tree_get_node_count()
int cs_tree_get_node_count ( cs_tree_node_t *  node,
const char *  path
number of nodes sharing path
◆ cs_tree_get_sub_node_count()
int cs_tree_get_sub_node_count ( cs_tree_node_t *  root,
These nodes are located at "path" from the given node or one of its descendants, with the path separator indicated by a "/".
number of matching nodes
◆ cs_tree_get_sub_node_count_simple()
int cs_tree_get_sub_node_count_simple ( cs_tree_node_t *  root,
const char *  name
This function is similar to cs_tree_get_sub_node_count, but is simpler (as it assumes a simple name instead of a more general path) and should thus be faster.
◆ cs_tree_node_create()
cs_tree_node_t * cs_tree_node_create ( const char *  name)
Only the name is assigned if given
[in]namename of the node, or nullptr
pointer to a new allocated cs_tree_node_t structure
◆ cs_tree_node_dump()
void cs_tree_node_dump ( cs_log_t  log,
int  depth,
[in]depthshift to apply when printing
◆ cs_tree_node_free()
void cs_tree_node_free ( cs_tree_node_t **  pnode)
If the node is the root of the tree, the whole tree is freed.
[in,out]pnodepointer to a pointer to a cs_tree_node_t to free
◆ cs_tree_node_get_child()
cs_tree_node_t * cs_tree_node_get_child ( cs_tree_node_t *  node,
const char *  name
The child node must be located directly under the given node (i.e. it is a child, not a grand-child or beyond).
This function is similar to cs_tree_get_node, but is simpler (albeit more restricted in scope) and may be faster in cases where one level of the tree is searched at a time.
In case of multiple children sharing the given name, the first such node is returned.
[in]nodepointer to the given node
[in]namename of child node
string value associated to tag if found, or nullptr
◆ cs_tree_node_get_child_value_str()
const char * cs_tree_node_get_child_value_str ( cs_tree_node_t *  node,
const char *  child_name
The behavior is similar to that of cs_tree_node_get_value_str.
[in]nodepointer to a cs_tree_node_t to access, or nullptr
[in]child_namename of child node
pointer to associated values, or nullptr
◆ cs_tree_node_get_child_values_bool()
const bool * cs_tree_node_get_child_values_bool ( cs_tree_node_t *  node,
The behavior is similar to that of cs_tree_node_get_values_bool.
◆ cs_tree_node_get_child_values_int()
const int * cs_tree_node_get_child_values_int ( cs_tree_node_t *  node,
The behavior is similar to that of cs_tree_node_get_values_int.
pointer to associated array, or nullptr
◆ cs_tree_node_get_child_values_real()
const cs_real_t * cs_tree_node_get_child_values_real ( cs_tree_node_t *  node,
The behavior is similar to that of cs_tree_node_get_values_real.
◆ cs_tree_node_get_next_of_name()
cs_tree_node_t * cs_tree_node_get_next_of_name ( cs_tree_node_t *  node)
The first node of a series is obtained using cs_tree_get_node.
[in]nodepointer to the starting node
pointer to next sibling node with same name, or nullptr
◆ cs_tree_node_get_sibling_with_tag()
cs_tree_node_t * cs_tree_node_get_sibling_with_tag ( cs_tree_node_t *  node,
const char *  tag,
const char *  tag_value
This node is searched for among siblings of a given node sharing the same path (i.e. the same name).
Using the following example tree:
/ section1 section2 entry label (value = a) entry label (value = b)
Using cs_tree_get_node(node, "section2/entry") will return the first node with path "section2/entry" (which has a child named "label" with value a).
Using cs_tree_node_get_sibling_with_tag(node, "label", "a") from that node will return the same node, while cs_tree_node_get_sibling_with_tag(node, "label", "b") will return the second "section2/entry" node.
This function can be called from any sibling (not necessarily the first).
[in]tagname of the required "tag" child
[in]tag_valuevalue of the required "tag" child
◆ cs_tree_node_get_tag()
const char * cs_tree_node_get_tag ( cs_tree_node_t *  node,
const char *  tag
If the child "tag" node does not exist, nullptr is returned.
The CS_TREE_NODE_TAG flag is set for child nodes accessed by this function. It is currently only relevant for possible mapping to XML.
[in]tagname of child node used as tag
◆ cs_tree_node_get_value_str()
const char * cs_tree_node_get_value_str ( cs_tree_node_t *  node)
If the node was never accessed before and the value type was not defined, it is set to CS_TREE_NODE_CHAR. If it was previously converted to a different type, an error is returned.
associated string, or nullptr
◆ cs_tree_node_get_values_bool()
const bool * cs_tree_node_get_values_bool ( cs_tree_node_t *  node)
If the value type was not defined, or defined as a string, values are converted and the type flag set to CS_TREE_NODE_BOOL. If it was previously accessed (and converted) using a different type, an error is returned.
The following strings (case-independent) are converted to "true": "true", "yes", "on", "1". All other strings are converted to "false".
◆ cs_tree_node_get_values_int()
const int * cs_tree_node_get_values_int ( cs_tree_node_t *  node)
If the value type was not defined, or defined as a string, values are converted and the type flag set to CS_TREE_NODE_INT. If it was previously accessed (and converted) using a different type, an error is returned.
◆ cs_tree_node_get_values_real()
const cs_real_t * cs_tree_node_get_values_real ( cs_tree_node_t *  node)
If the value type was not defined, or defined as a string, values are converted and the type flag set to CS_TREE_NODE_REAL. If it was previously accessed (and converted) using a different type, an error is returned.
◆ cs_tree_node_set_name()
void cs_tree_node_set_name ( cs_tree_node_t *  node,
const char *  name
[in,out]nodepointer to a cs_tree_node_t to modify
[in]namename to set
◆ cs_tree_node_set_tag()
void cs_tree_node_set_tag ( cs_tree_node_t *  node,
const char *  tag,
const char *  tag_str
A tag is simply a string-valued child node.
The CS_TREE_NODE_TAG flag is also set for this child. It is currently only relevant for possible mapping to XML.
[in,out]nodepointer to the given node
[in]tag_strcharacter string to be copied to tag
◆ cs_tree_node_set_value_str()
void cs_tree_node_set_value_str ( cs_tree_node_t *  node,
const char *  val
The assigned string is copied to the node.
[in]valpointer to character string
◆ cs_tree_node_set_values_bool()
void cs_tree_node_set_values_bool ( cs_tree_node_t *  node,
int  n,
const bool *  val
[in]nnumber of elements in val
[in]valarray of boolean
◆ cs_tree_node_set_values_int()
void cs_tree_node_set_values_int ( cs_tree_node_t *  node,
int  n,
const int *  val
The array values are copied to the node.
[in]valarray of integers
◆ cs_tree_node_set_values_real()
void cs_tree_node_set_values_real ( cs_tree_node_t *  node,
int  n,
const cs_real_t *  val
[in]valarray of real values
