cs_timer.cpp File Reference
#include "base/cs_config.h"
#include <time.h>
#include "base/cs_timer.h"
+ Include dependency graph for cs_timer.cpp:
double cs_timer_wtime (void)
 Return Wall clock time. More...
double cs_timer_cpu_time (void)
 Return CPU time. More...
void cs_timer_cpu_times (double *user_time, double *system_time)
 Return separate user and system CPU times. More...
cs_timer_t cs_timer_time (void)
 Return a timer's value. More...
cs_timer_counter_t cs_timer_diff (const cs_timer_t *t0, const cs_timer_t *t1)
 Compute the difference between 2 timers. More...
const char * cs_timer_wtime_method (void)
 Return method used to return wall clock time. More...
const char * cs_timer_cpu_time_method (void)
 Return method used to return CPU time. More...
◆ cs_timer_cpu_time()
double cs_timer_cpu_time ( void  )
Return CPU time.
Note that in the rare case that only the minimal C library clock() method is available (see cs_timer_cpu_time_method()), at least one of the cs_timer_...() functions (possibly this one) must be called upon program start for this function to be used. In addition, in this case, time may "loop" back to 0 every multiple of 2^size_t / CLOCKS_PER_SEC seconds.
current CPU time usage, or -1 if unable to compute.
◆ cs_timer_cpu_time_method()
const char * cs_timer_cpu_time_method ( void  )
short description of method used to return CPU time.
◆ cs_timer_cpu_times()
void cs_timer_cpu_times ( double *  user_time,
double *  system_time
Note that in the rare case that only the minimal C library clock() method is available, this function will return -1 values.
[out]user_timecurrent user CPU usage.
[out]system_timecurrent system CPU usage.
◆ cs_timer_diff()
cs_timer_counter_t cs_timer_diff ( const cs_timer_t *  t0,
const cs_timer_t *  t1
[in]t0oldest timer value
[in]t1most recent timer value
last - first timer value.
◆ cs_timer_time()
cs_timer_t cs_timer_time ( void  )
timer structure.
◆ cs_timer_wtime()
double cs_timer_wtime ( void  )
elapsed time from first call of a function of the cs_timer_...() series, or -1 if unable to compute.
◆ cs_timer_wtime_method()
const char * cs_timer_wtime_method ( void  )
short description of method used to return wall clock time.
