cs_time_step.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_log.h"
#include "base/cs_map.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
+ Include dependency graph for cs_time_step.cpp:
cs_time_step_t * cs_get_glob_time_step (void)
 Provide read/write access to cs_glob_time_step. More...
cs_time_step_options_t * cs_get_glob_time_step_options (void)
 Provide read/write access to cs_glob_time_step_options. More...
void cs_time_step_define_variable (int is_variable)
 Define whether time step is variable or not. More...
void cs_time_step_define_local (int is_local)
 Define whether time step is local in space or not. More...
void cs_time_step_define_nt_max (int nt_max)
 Define maximum time step number. More...
void cs_time_step_define_t_max (double t_max)
 Define maximum time value. More...
void cs_time_step_define_prev (int nt_prev, double t_prev)
 Set time values from previous (usually restarted) calculations. More...
void cs_time_step_increment (double dt)
 Increment the global time step. More...
void cs_time_step_update_dt (double dt)
 Update global time step value for a time step in progress. More...
void cs_time_step_redefine_cur (int nt_cur, double t_cur)
 Redefine the current time values. More...
void cs_time_step_log_setup (void)
 Print the time stepping options to setup.log. More...
base time step data.
◆ cs_get_glob_time_step()
cs_time_step_t * cs_get_glob_time_step ( void  )
pointer to global time step structure
◆ cs_get_glob_time_step_options()
cs_time_step_options_t * cs_get_glob_time_step_options ( void  )
pointer to global time step options structure
◆ cs_time_step_define_local()
void cs_time_step_define_local ( int  is_local)
[in]is_local0 if time step is uniform in space, 1 if it is local
◆ cs_time_step_define_nt_max()
void cs_time_step_define_nt_max ( int  nt_max)
[in]nt_maxmaximum time step number (unlimited if negative)
◆ cs_time_step_define_prev()
void cs_time_step_define_prev ( int  nt_prev,
double  t_prev
[in]nt_prevprevious time step number
[in]t_prevprevious physical time
◆ cs_time_step_define_t_max()
void cs_time_step_define_t_max ( double  t_max)
[in]t_maxmaximum time value (unlimited if negative)
◆ cs_time_step_define_variable()
void cs_time_step_define_variable ( int  is_variable)
[in]is_variable0 if time step is variable in time, 1 if it is fixed
◆ cs_time_step_increment()
void cs_time_step_increment ( double  dt)
[in]dttime step value to increment
◆ cs_time_step_log_setup()
void cs_time_step_log_setup ( void  )
◆ cs_time_step_redefine_cur()
void cs_time_step_redefine_cur ( int  nt_cur,
double  t_cur
Remarks
Using cs_time_step_increment is preferred, but this function may be required for reverting to a previous time step.
[in]nt_curcurrent time step number
[in]t_curcurrent physical time
◆ cs_time_step_update_dt()
void cs_time_step_update_dt ( double  dt)
This is useful when using an adaptive time step, which is incremented earlier based on an estimated time step but needs to be updated.
[in]dttime step value to update
