cs_time_control.h File Reference
#include <stdarg.h>
+ Include dependency graph for cs_time_control.h:
Classes
struct  cs_time_control_t
Typedefs
typedef bool() cs_time_control_func_t(const cs_time_step_t *ts, void *input)
 Function pointer to a time control function. More...
Enumerations
enum  cs_time_control_type_t { CS_TIME_CONTROL_TIME_STEP , CS_TIME_CONTROL_TIME , CS_TIME_CONTROL_FUNCTION }
bool cs_time_control_is_active (cs_time_control_t *tc, const cs_time_step_t *ts)
void cs_time_control_init_by_time_step (cs_time_control_t *tc, int nt_start, int nt_end, int nt_interval, bool at_start, bool at_end)
void cs_time_control_init_by_time (cs_time_control_t *tc, double t_start, double t_end, double t_interval, bool at_start, bool at_end)
void cs_time_control_init_by_func (cs_time_control_t *tc, cs_time_control_func_t *control_func, void *control_input, bool at_start, bool at_end)
void cs_time_control_get_description (const cs_time_control_t *tc, char *desc, size_t desc_size)
void cs_time_control_copy (const cs_time_control_t *src, cs_time_control_t *dst)
 Copy contents of a cs_time_control to another instance. More...
void cs_time_control_copy_from_default (cs_time_control_t *tc)
 Copy contents of the default cs_time_control to another instance. More...
Typedef Documentation
◆ cs_time_control_func_t
Each function of this sort may be used to determine whether a given set of operations (such as variable or property updates) should be done at the current time step.
Remarks
: if the input pointer is non-null, it must point to valid data when the control function is called, so that value or structure should not be temporary (i.e. local);
[in]tscurrent time step structure
[in]inputpointer to optional (untyped) value or structure, or NULL.
true if active at given time step, false otherwise
◆ cs_time_control_type_t
Enumerator
control based on time step
control based on simulated time
control based on function
◆ cs_time_control_copy()
void cs_time_control_copy ( const cs_time_control_t *  src,
cs_time_control_t *  dst
[in]srcInstance to copy data from
[out]dstInstance to copy data to
◆ cs_time_control_copy_from_default()
void cs_time_control_copy_from_default ( cs_time_control_t *  tc)
[out]tcInstance to copy data to
◆ cs_time_control_get_description()
void cs_time_control_get_description ( const cs_time_control_t *  tc,
char *  desc,
size_t  desc_size
◆ cs_time_control_init_by_func()
void cs_time_control_init_by_func ( cs_time_control_t *  tc,
cs_time_control_func_t *  control_func,
void *  control_input,
bool  at_start,
bool  at_end
◆ cs_time_control_init_by_time()
void cs_time_control_init_by_time ( cs_time_control_t *  tc,
double  t_start,
double  t_end,
double  t_interval,
bool  at_start,
bool  at_end
◆ cs_time_control_init_by_time_step()
void cs_time_control_init_by_time_step ( cs_time_control_t *  tc,
int  nt_start,
int  nt_end,
int  nt_interval,
bool  at_start,
bool  at_end
◆ cs_time_control_is_active()
bool cs_time_control_is_active ( cs_time_control_t *  tc,
const cs_time_step_t *  ts
