cs_sles_hypre.cpp File Reference
handling of HYPRE-based linear solvers More...
#include <stdarg.h>
#include <HYPRE_config.h>
#include <HYPRE_krylov.h>
#include <HYPRE_parcsr_ls.h>
#include <HYPRE_utilities.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_base_accel.h"
#include "base/cs_dispatch.h"
#include "base/cs_log.h"
#include "base/cs_fp_exception.h"
#include "base/cs_halo.h"
#include "base/cs_mem.h"
#include "alge/cs_matrix.h"
#include "alge/cs_matrix_default.h"
#include "alge/cs_matrix_hypre.h"
#include "alge/cs_matrix_hypre_priv.h"
#include "base/cs_timer.h"
#include "alge/cs_sles.h"
#include "alge/cs_sles_hypre.h"
+ Include dependency graph for cs_sles_hypre.cpp:
Macros
#define HYPRE_RELEASE_NUMBER   0
cs_sles_hypre_t * cs_sles_hypre_define (int f_id, const char *name, cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context)
 Define and associate a HYPRE linear system solver for a given field or equation name. More...
cs_sles_hypre_t * cs_sles_hypre_create (cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context)
 Create HYPRE linear system solver info and context. More...
void cs_sles_hypre_destroy (void **context)
 Destroy iterative sparse linear system solver info and context. More...
void * cs_sles_hypre_copy (const void *context)
 Create HYPRE sparse linear system solver info and context based on existing info and context. More...
bool cs_sles_hypre_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
 Error handler for HYPRE solver. More...
void cs_sles_hypre_log (const void *context, cs_log_t log_type)
 Log sparse linear equation solver info. More...
void cs_sles_hypre_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup iterative sparse linear equation solver. More...
cs_sles_convergence_state_t cs_sles_hypre_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call HYPRE linear equation solver. More...
void cs_sles_hypre_free (void *context)
 Free HYPRE linear equation solver setup context. More...
void cs_sles_hypre_set_n_max_iter (cs_sles_hypre_t *context, int n_max_iter)
 Set the max. number of iterations associated to the given HYPRE contrext. More...
void cs_sles_hypre_set_host_device (cs_sles_hypre_t *context, int use_device)
 Define whether the solver should run on the host or accelerated device. More...
int cs_sles_hypre_get_host_device (const cs_sles_hypre_t *context)
 Query whether the solver should run on the host or accelerated device. More...
void cs_sles_hypre_library_info (cs_log_t log_type)
 Print information on hypre library. More...
◆ HYPRE_RELEASE_NUMBER
◆ cs_sles_hypre_copy()
void * cs_sles_hypre_copy ( const void *  context)
[in]contextpointer to reference info and context (actual type: cs_sles_hypre_t *)
pointer to newly created solver info object. (actual type: cs_sles_hypre_t *)
◆ cs_sles_hypre_create()
cs_sles_hypre_t * cs_sles_hypre_create ( cs_sles_hypre_type_t  solver_type,
cs_sles_hypre_setup_hook_t *  setup_hook,
void *  context
[in]solver_typeHYPRE solver type
[in]precond_typeHYPRE preconditioner type
[in]setup_hookpointer to optional setup epilogue function
[in]contextpointer to optional (untyped) value or structure for setup_hook, or nullptr
pointer to newly created linear system object.
◆ cs_sles_hypre_define()
cs_sles_hypre_t * cs_sles_hypre_define ( int  f_id,
const char *  name,
void *  context
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_petsc_create.
The associated solver required that the matrix passed to it is a HYPRE matrix (see cs_matrix_set_type_hypre).
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
[in]nameassociated name if f_id < 0, or nullptr
[in,out]contextpointer to optional (untyped) value or structure for setup_hook, or nullptr
pointer to newly created iterative solver info object.
◆ cs_sles_hypre_destroy()
void cs_sles_hypre_destroy ( void **  context)
[in,out]contextpointer to iterative solver info and context (actual type: cs_sles_hypre_t **)
◆ cs_sles_hypre_error_post_and_abort()
bool cs_sles_hypre_error_post_and_abort ( cs_sles_t *  sles,
const cs_matrix_t *  a,
const cs_real_t *  rhs,
cs_real_t *  vx
In case of divergence or breakdown, this error handler outputs an error message It does nothing in case the maximum iteration count is reached.
[in,out]slespointer to solver object
[in]stateconvergence state
[in]amatrix
[in]rhsright hand side
[in,out]vxsystem solution
false (do not attempt new solve)
◆ cs_sles_hypre_free()
void cs_sles_hypre_free ( void *  context)
[in,out]contextpointer to iterative solver info and context (actual type: cs_sles_hypre_t *)
◆ cs_sles_hypre_get_host_device()
int cs_sles_hypre_get_host_device ( const cs_sles_hypre_t *  context)
[in,out]contextpointer to HYPRE linear solver info
0 for host, 1 for device (GPU)
◆ cs_sles_hypre_library_info()
void cs_sles_hypre_library_info ( cs_log_t  log_type)
[in]log_typelog type
◆ cs_sles_hypre_log()
void cs_sles_hypre_log ( const void *  context,
cs_log_t  log_type
[in]contextpointer to iterative solver info and context (actual type: cs_sles_hypre_t *)
◆ cs_sles_hypre_set_host_device()
void cs_sles_hypre_set_host_device ( cs_sles_hypre_t *  context,
int  use_device
If no device is available, this setting is ignored.
[in]use_device0 for host, 1 for device (GPU)
◆ cs_sles_hypre_set_n_max_iter()
void cs_sles_hypre_set_n_max_iter ( cs_sles_hypre_t *  context,
int  n_max_iter
[in]n_max_itermax. number of iterations
◆ cs_sles_hypre_setup()
void cs_sles_hypre_setup ( void *  context,
const char *  name,
int  verbosity
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_sles_hypre_solve()
cs_sles_convergence_state_t cs_sles_hypre_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residual,
cs_real_t *  vx_ini,
cs_real_t *  vx,
size_t  aux_size,
void *  aux_vectors
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[out]residualresidual
[in]vx_iniinitial system solution (vx if nonzero, nullptr if zero)
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if nullptr)
convergence state
