cs_range_set.h File Reference
#include "fvm/fvm_group.h"
#include "fvm/fvm_selector.h"
#include "fvm/fvm_periodicity.h"
#include "base/cs_base.h"
#include "base/cs_halo.h"
#include "base/cs_interface.h"
#include "base/cs_numbering.h"
#include "mesh/cs_mesh_builder.h"
+ Include dependency graph for cs_range_set.h:
Classes
struct  cs_range_set_t
void cs_range_set_define (const cs_interface_set_t *ifs, const cs_halo_t *halo, cs_lnum_t n_elts, bool balance, int tr_ignore, cs_gnum_t g_id_base, cs_gnum_t l_range[2], cs_gnum_t *g_id)
 Define global ids and a partitioning of data based on local ranges for elements which may be shared across ranks or have halo elements. More...
cs_range_set_t * cs_range_set_create (const cs_interface_set_t *ifs, const cs_halo_t *halo, cs_lnum_t n_elts, bool balance, int tr_ignore, cs_gnum_t g_id_base)
 Create a range set (with associated range and global ids) for the partitioning of data based on local ranges for elements which may be shared across ranks or have halo elements. More...
cs_range_set_t * cs_range_set_create_from_shared (const cs_interface_set_t *ifs, const cs_halo_t *halo, cs_lnum_t n_elts, cs_gnum_t l_range[2], cs_gnum_t *g_id)
 Create a range set (with associated range and global ids) from an existing partition of data based on local ranges for elements which may be shared across ranks or have halo elements. More...
void cs_range_set_destroy (cs_range_set_t **rs)
 Destroy a range set structure. More...
void cs_range_set_zero_out_of_range (const cs_range_set_t *rs, cs_datatype_t datatype, cs_lnum_t stride, void *val)
 Set values of a given array to zero for indexes of elements outside the local range. More...
void cs_range_set_sync (const cs_range_set_t *rs, cs_datatype_t datatype, cs_lnum_t stride, void *val)
 Synchronize values elements associated with a range set, using either a halo or an interface set. More...
void cs_range_set_gather (const cs_range_set_t *rs, cs_datatype_t datatype, cs_lnum_t stride, const void *src_val, void *dest_val)
 Gather element values associated with a range set to a compact set. More...
void cs_range_set_scatter (const cs_range_set_t *rs, cs_datatype_t datatype, cs_lnum_t stride, const void *src_val, void *dest_val)
 Scatter element values associated with a range set to the full set. More...
◆ cs_range_set_create()
cs_range_set_t * cs_range_set_create ( const cs_interface_set_t *  ifs,
const cs_halo_t *  halo,
cs_lnum_t  n_elts,
bool  balance,
int  tr_ignore,
cs_gnum_t  g_id_base
Global id ranges are assigned to each rank of the interface set's associated communicator, and global ids are defined by a parallel scan type operation counting elements on parallel interfaces only once. Each element will appear inside one rank's range and outside the range of all other ranks. Ranges across different ranks are contiguous.
Elements and their periodic matches will have identical or distinct global ids depending on the tr_ignore argument.
The range set maintains pointers to the optional interface set and halo structures, but does not copy them, so those structures should have a lifetime at least as long as the returned range set.
[in]ifspointer to interface set structure, or nullptr
[in]halopointer to halo structure, or nullptr
[in]n_eltsnumber of elements
[in]balancetry to balance shared elements across ranks? (for elements shared across an interface set)
[in]tr_ignore0: periodic elements will share global ids > 0: ignore periodicity with rotation; > 1: ignore all periodic transforms
[in]g_id_baseglobal id base index (usually 0, but 1 could be used to generate an IO numbering)
pointer to created range set structure
◆ cs_range_set_create_from_shared()
cs_range_set_t * cs_range_set_create_from_shared ( const cs_interface_set_t *  ifs,
cs_lnum_t  n_elts,
cs_gnum_t *  g_id
The optional interface set, halo, and global element id array are only shared by the range set, not copied, so they should have a lifetime at least as long as the returned range set.
[in]l_rangeglobal id range assigned to local rank: [start, past-the-end[
[in]g_idglobal id assigned to elements
◆ cs_range_set_define()
void cs_range_set_define ( const cs_interface_set_t *  ifs,
cs_lnum_t  n_elts,
bool  balance,
int  tr_ignore,
cs_gnum_t *  g_id
This is a utility function, allowing a similar call for cases where matching elements or parallel ranks are identified using an interface set (for elements which may be on rank boundaries, such as vertices or faces), elements with an associated a halo (such as for cells), or neither (in the single-rank case).
Global id ranges are assigned to each rank, and global ids are defined by a parallel scan type operation counting elements on parallel interfaces only once. Each element will appear inside one rank's range and outside the range of all other ranks. Ranges across different ranks are contiguous.
This allows building distribution information such as that used in many external libraries, such as PETSc, HYPRE, and may also simplify many internal operations, where it is needed that elements have a unique owner rank, and are ghosted on others (such as linear solvers operating on elements which may be on parallel boundaries, such as vertices, edges, and faces).
[in]balancetry to balance shared elements across ranks ? (for elements shared across an interface set)
[out]l_rangeglobal id range assigned to local rank: [start, past-the-end[
[out]g_idglobal id assigned to elements
◆ cs_range_set_destroy()
void cs_range_set_destroy ( cs_range_set_t **  rs)
[in,out]rspointer to pointer to structure to destroy
◆ cs_range_set_gather()
void cs_range_set_gather ( const cs_range_set_t *  rs,
cs_lnum_t  stride,
const void *  src_val,
void *  dest_val
[in]rspointer to range set structure, or nullptr
[in]datatypetype of data considered
[in]stridenumber of values per entity (interlaced)
[in]src_valsource values buffer
[out]dest_valdestination values buffer (may be identical to src_val, in which case operation is "in-place")
◆ cs_range_set_scatter()
void cs_range_set_scatter ( const cs_range_set_t *  rs,
cs_lnum_t  stride,
void *  dest_val
This includes parallel synchronization when the range set is associated with a halo or interface set structure.
◆ cs_range_set_sync()
void cs_range_set_sync ( const cs_range_set_t *  rs,
cs_lnum_t  stride,
void *  val
[in,out]valvalues buffer
◆ cs_range_set_zero_out_of_range()
void cs_range_set_zero_out_of_range ( const cs_range_set_t *  rs,
cs_lnum_t  stride,
void *  val
If an interface set used to define the range set is available, it may be used to accelerate this operation, as only elements on that interface need to be checked.
[in,out]valpointer to array values
