cs_physical_constants.h File Reference
+ Include dependency graph for cs_physical_constants.h:
Classes
struct  cs_physical_constants_t
 Physical constants descriptor. More...
struct  cs_fluid_properties_t
 Fluid properties descriptor. More...
cs_physical_constants_t * cs_get_glob_physical_constants (void)
cs_fluid_properties_t * cs_get_glob_fluid_properties (void)
void cs_physical_constants_log_setup (void)
void cs_fluid_properties_log_setup (void)
const double cs_physical_constants_r
const double cs_physical_constants_kb
const double cs_physical_constants_celsius_to_kelvin
const double cs_physical_constants_stephan
const double cs_physical_constants_avogadro
const cs_physical_constants_t * cs_glob_physical_constants
const cs_fluid_properties_t * cs_glob_fluid_properties
◆ cs_fluid_properties_log_setup()
void cs_fluid_properties_log_setup ( void  )
◆ cs_get_glob_fluid_properties()
cs_fluid_properties_t * cs_get_glob_fluid_properties ( void  )
◆ cs_get_glob_physical_constants()
cs_physical_constants_t * cs_get_glob_physical_constants ( void  )
◆ cs_physical_constants_log_setup()
void cs_physical_constants_log_setup ( void  )
◆ cs_glob_fluid_properties
const cs_fluid_properties_t* cs_glob_fluid_properties
extern
◆ cs_glob_physical_constants
const cs_physical_constants_t* cs_glob_physical_constants
extern
◆ cs_physical_constants_avogadro
extern
Avogadro constant (mole definition) $N_A$ in $mol^{-1}$
◆ cs_physical_constants_celsius_to_kelvin
extern
Conversion from Celsius to Kelvin: 275.15
◆ cs_physical_constants_kb
extern
Boltzmann constant ( $J.K^{-1}$)
◆ cs_physical_constants_r
extern
Ideal gas constant ( $J.mol^{-1}.K^{-1}$)
◆ cs_physical_constants_stephan
extern
Stephan constant for the radiative module $\sigma$ in $W.m^{-2}.K^{-4}$
