cs_paramedmem_remapper.cxx File Reference
#include <stdarg.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_connect.h"
#include "base/cs_parall.h"
#include "base/cs_selector.h"
#include "base/cs_timer.h"
#include "fvm/fvm_defs.h"
#include "fvm/fvm_nodal_from_desc.h"
#include "cs_medcoupling_mesh.hxx"
#include "base/cs_paramedmem_remapper.h"
+ Include dependency graph for cs_paramedmem_remapper.cxx:
cs_paramedmem_remapper_t * cs_paramedmem_remapper_create (char *name, const char *sel_criteria, char *file_name, char *mesh_name, cs_real_t center[3], cs_real_t radius)
 Creates a new cs_paramedmem_remapper_t instance. More...
cs_paramedmem_remapper_t * cs_paramedmem_remapper_by_name_try (const char *name)
 get a remapper by its name More...
cs_real_t * cs_paramedmem_remap_field_one_time (cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int dt, int it)
 Remaps a field from the med file to the local mesh for a given time. More...
cs_real_t * cs_paramedmem_remap_field (cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int time_choice, double tval)
 Interpolate a given field on the local mesh for a given time. More...
void cs_paramedmem_remapper_translate (cs_paramedmem_remapper_t *r, cs_real_t translation[3])
 translate the mesh using a given vector More...
void cs_paramedmem_remapper_rotate (cs_paramedmem_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
 Rotate the mesh using a center point, axis and angle. More...
void cs_paramedmem_remapper_destroy_all (void)
 Destroy all remappers. More...
◆ cs_paramedmem_remap_field()
cs_real_t * cs_paramedmem_remap_field ( cs_paramedmem_remapper_t *  r,
char *  field_name,
int  time_choice,
double  tval
[in]rpointer to cs_paramedmem_remapper_t struct
[in]field_namename of the field to remap from the file
[in]default_valdefault value for unmapped elements
[in]time_choiceChoice of the time interpolation. 0: Value of field interpolated at t=tval from the med file. 1: Returns field values for the first time step in the file. tval is then ignored. 2: Returns field values for the last time step in the file. tval is then ignored.
[in]tvalrequested time instant. If time choice is 0 and tval outside of the file time bounds, return value will be at the the first time step (if tval < tmin) or last time step (if tval > tmax)
cs_real_t pointer containing the new values on target mesh
◆ cs_paramedmem_remap_field_one_time()
cs_real_t * cs_paramedmem_remap_field_one_time ( cs_paramedmem_remapper_t *  r,
char *  field_name,
int  dt,
int  it
[in]dttime value to use from the file
[in]ittime iteration to use from the file
◆ cs_paramedmem_remapper_by_name_try()
cs_paramedmem_remapper_t * cs_paramedmem_remapper_by_name_try ( const char *  name)
[in]namename of the remapper
◆ cs_paramedmem_remapper_create()
cs_paramedmem_remapper_t * cs_paramedmem_remapper_create ( char *  name,
const char *  sel_criteria,
char *  file_name,
char *  mesh_name,
cs_real_t  radius
[in]sel_criteriacells selection criteria
[in]file_namemed file name
[in]mesh_namename of the mesh in the med file
[in]centercenter of bounding sphere
[in]radiusradius of bounding sphere
◆ cs_paramedmem_remapper_destroy_all()
void cs_paramedmem_remapper_destroy_all ( void  )
◆ cs_paramedmem_remapper_rotate()
void cs_paramedmem_remapper_rotate ( cs_paramedmem_remapper_t *  r,
cs_real_t  axis[3],
cs_real_t  angle
[in]rpointer to the cs_paramedmem_remapper_t struct
[in]invariantcoordinates of the invariant point
[in]axisrotation axis vector
[in]anglerotation angle in radians
◆ cs_paramedmem_remapper_translate()
void cs_paramedmem_remapper_translate ( cs_paramedmem_remapper_t *  r,
[in]translationtranslation vector
