cs_param_sles_setup.h File Reference
Routines to handle the setup of SLES relying on a cs_param_sles_t structure. More...
+ Include dependency graph for cs_param_sles_setup.h:
int cs_param_sles_setup (bool use_field_id, cs_param_sles_t *slesp)
 Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Sparse Linear Equation Solver) More...
void cs_param_sles_setup_cvg_param (bool use_field_id, const cs_param_sles_t *slesp)
 Update the settings associated to a cs_sles_t structure and apply those defined in the given cs_param_sles_t structure. This function is used only when a first setup has been performed. More...
◆ cs_param_sles_setup()
int cs_param_sles_setup ( bool  use_field_id,
cs_param_sles_t *  slesp
[in]use_field_idif false use system name to define a SLES
[in,out]slesppointer to a cs_param_sles_t structure
an error code (-1 if a problem is encountered, 0 otherwise)
◆ cs_param_sles_setup_cvg_param()
void cs_param_sles_setup_cvg_param ( bool  use_field_id,
const cs_param_sles_t *  slesp
One modifies only some specific options like the max. number of iterations or the relative tolerance
[in]use_field_idif false use a name to retrieve the cs_sles_t struc.
[in]slesppointer to a cs_param_sles_t structure
