cs_param_mumps.h File Reference
Routines and structure to handle the MUMPS setup. The structure is used as a context structure of a cs_param_sles_t structure. More...
Classes
struct  cs_param_mumps_t
 Set of parameters to specify additional options to MUMPS For more advanced settings, one has to use the cs_user_sles_mumps_hook function. Please also refer to the MUMPS user guide for more details. More...
Enumerations
enum  cs_param_mumps_facto_type_t { CS_PARAM_MUMPS_FACTO_LU , CS_PARAM_MUMPS_FACTO_LDLT_SYM , CS_PARAM_MUMPS_FACTO_LDLT_SPD , CS_PARAM_MUMPS_N_FACTO_TYPES }
 type of factorization to consider when using the MUMPS solver to solve a linear system More...
enum  cs_param_mumps_analysis_algo_t {
  CS_PARAM_MUMPS_ANALYSIS_AMD , CS_PARAM_MUMPS_ANALYSIS_QAMD , CS_PARAM_MUMPS_ANALYSIS_PORD , CS_PARAM_MUMPS_ANALYSIS_SCOTCH ,
  CS_PARAM_MUMPS_ANALYSIS_PTSCOTCH , CS_PARAM_MUMPS_ANALYSIS_METIS , CS_PARAM_MUMPS_ANALYSIS_PARMETIS , CS_PARAM_MUMPS_ANALYSIS_AUTO ,
  CS_PARAM_MUMPS_N_ANALYSIS_ALGOS
 Type of algorithm to consider when using the MUMPS solver to perform the analysis step (renumbering and graph manipulation). Please refer to the MUMPS user guide for more details about the following algorithms. AMD, QAMD and PORD are available with MUMPS without any prerequesite. More...
enum  cs_param_mumps_memory_usage_t { CS_PARAM_MUMPS_MEMORY_CONSTRAINED , CS_PARAM_MUMPS_MEMORY_AUTO , CS_PARAM_MUMPS_MEMORY_CPU_DRIVEN , CS_PARAM_MUMPS_N_MEMORY_USAGES }
 Strategy for the memory usage inside MUMPS. More...
cs_param_mumps_t * cs_param_mumps_create (void)
 Create and initialize with the default settings a new structure storing a set of parameters used when calling MUMPS. More...
cs_param_mumps_t * cs_param_mumps_copy (const cs_param_mumps_t *mumpsp)
 Copy into a new structure the given set of parameters used when calling MUMPS. More...
void cs_param_mumps_log (const char *name, const cs_param_mumps_t *mumpsp)
 Log the structure storing the set of parameters used with MUMPS. More...
◆ cs_param_mumps_analysis_algo_t
Enumerator
AMD is a sequential algorithm which is well-suited for 2D problem (for 3D problems it induces a higher memeory consumption).
QAMD is a sequential algorithm which is well-suited for 2D problem (for 3D problems it induces a higher memeory consumption).
PORD is a sequential algorithm which is a good trade-off when MUMPS is installed with no prerequisite such as METIS or Scotch.
SCOTCH is a sequential algorithm which delivers the very good performance with 3D meshes, generally, better than PORD and not as good as METIS
PTSCOTCH is a parallel version of the sequential SCOTCH algorithm
METIS is a sequential algorithm which delivers the best performance in case of 2D meshes.
PARMETIS is a parallel version of the sequential METIS algorithm
MUMPS decides what is the best choice among available algorithms. This is the default choice.
◆ cs_param_mumps_facto_type_t
Enumerator
LU factorization is the most generic factorization available with MUMPS. It can handle general matrices (block and/or unsymmetric matrices)
This factorization is a Cholesky factorization (L.D.Lt) for general symmetric matrices.
This factorization is devoted to SPD matrices and corresponds to a Cholesky factorization. This is more specific and thus more efficient than CS_PARAM_MUMPS_FACTO_LDLT_SYM.
◆ cs_param_mumps_memory_usage_t
Enumerator
Strategy aiming at limiting the memory usage
Strategy relying on the default settings
Strategy aiming at the best CPU time
◆ cs_param_mumps_copy()
cs_param_mumps_t * cs_param_mumps_copy ( const cs_param_mumps_t *  mumpsp)
[in]mumpspset of mumps parameters
a pointer to a new allocated structure
◆ cs_param_mumps_create()
cs_param_mumps_t * cs_param_mumps_create ( void  )
◆ cs_param_mumps_log()
void cs_param_mumps_log ( const char *  name,
[in]namename related to the current SLES
