cs_param_amg.cpp File Reference
#include "bft/bft_error.h"
#include "base/cs_base.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "alge/cs_param_amg.h"
+ Include dependency graph for cs_param_amg.cpp:
const char * cs_param_amg_get_type_name (cs_param_amg_type_t type)
 Get the name of the type of algebraic multigrid (AMG) More...
cs_param_solver_class_t cs_param_amg_get_class (cs_param_amg_type_t amg_type)
 Retrieve the related solver class from the amg type. More...
cs_param_amg_boomer_t * cs_param_amg_boomer_create (void)
 Create a new structure storing a set of parameters used when calling boomerAMG. Set default values for all parameters. More...
cs_param_amg_boomer_t * cs_param_amg_boomer_copy (const cs_param_amg_boomer_t *bamgp)
 Copy the given set of parameters used when calling boomerAMG into a new structure. More...
const char * cs_param_amg_get_boomer_smoother_name (cs_param_amg_boomer_smoother_t smoother)
 Get the name of the smoother used with BoomerAMG (HYPRE library) More...
void cs_param_amg_boomer_log (const char *name, const cs_param_amg_boomer_t *bamgp)
 Log the set of parameters used for setting BoomerAMG. More...
cs_param_amg_gamg_t * cs_param_amg_gamg_create (void)
 Create a new structure storing a set of parameters used when calling GAMG. Set default values for all parameters. More...
cs_param_amg_gamg_t * cs_param_amg_gamg_copy (const cs_param_amg_gamg_t *gamgp)
 Copy the given set of parameters used when calling GAMG into a new structure. More...
const char * cs_param_amg_get_gamg_smoother_name (cs_param_amg_gamg_smoother_t smoother)
 Get the name of the smoother used with GAMG (PETSc library) More...
const char * cs_param_amg_get_gamg_coarse_solver_name (cs_param_amg_gamg_coarse_solver_t coarse)
void cs_param_amg_gamg_log (const char *name, const cs_param_amg_gamg_t *gamgp)
 Log the set of parameters used for setting GAMG. More...
cs_param_amg_hmg_t * cs_param_amg_hmg_create (void)
 Create a new structure storing a set of parameters used when calling HMG. Set all parameters at their default value. More...
cs_param_amg_hmg_t * cs_param_amg_hmg_copy (const cs_param_amg_hmg_t *hmgp)
 Copy the given set of parameters used when calling HMG into a new structure. More...
void cs_param_amg_hmg_log (const char *name, const cs_param_amg_hmg_t *hmgp)
 Log the set of parameters used for setting HMG. More...
cs_param_amg_inhouse_t * cs_param_amg_inhouse_create (bool used_as_solver, bool used_as_k_cycle)
 Create a new structure storing a set of parameters used when calling the in-house AMG algo. Set default values for all parameters. More...
cs_param_amg_inhouse_t * cs_param_amg_inhouse_copy (const cs_param_amg_inhouse_t *amgp)
 Copy the given set of parameters used when calling in-house AMG algo. into a new structure. More...
const char * cs_param_amg_get_inhouse_solver_name (cs_param_amg_inhouse_solver_t solver)
 Get the name of the solver used with in-house AMG algo. More...
void cs_param_amg_inhouse_log (const char *name, const cs_param_amg_inhouse_t *amgp)
 Log the set of parameters used for setting in-house AMG algorithms. More...
◆ cs_param_amg_boomer_copy()
cs_param_amg_boomer_t * cs_param_amg_boomer_copy ( const cs_param_amg_boomer_t *  bamgp)
[in]bamgpreference set of boomerAMG parameters
a pointer to a new set of boomerAMG parameters
◆ cs_param_amg_boomer_create()
cs_param_amg_boomer_t * cs_param_amg_boomer_create ( void  )
◆ cs_param_amg_boomer_log()
void cs_param_amg_boomer_log ( const char *  name,
[in]namename related to the current SLES
[in]bamgpset of boomerAMG parameters
◆ cs_param_amg_gamg_copy()
cs_param_amg_gamg_t * cs_param_amg_gamg_copy ( const cs_param_amg_gamg_t *  gamgp)
[in]gamgpreference set of GAMG parameters
a pointer to a new set of GAMG parameters
◆ cs_param_amg_gamg_create()
cs_param_amg_gamg_t * cs_param_amg_gamg_create ( void  )
◆ cs_param_amg_gamg_log()
void cs_param_amg_gamg_log ( const char *  name,
[in]gamgpset of gamgAMG parameters
◆ cs_param_amg_get_boomer_smoother_name()
const char * cs_param_amg_get_boomer_smoother_name ( cs_param_amg_boomer_smoother_t  smoother)
[in]smoothersmoother type
name of the given smoother type
◆ cs_param_amg_get_class()
cs_param_solver_class_t cs_param_amg_get_class ( cs_param_amg_type_t  amg_type)
[in]amg_typetype of AMG to consider
the related solver class or CS_PARAM_SOLVER_CLASS_CS
◆ cs_param_amg_get_gamg_coarse_solver_name()
const char * cs_param_amg_get_gamg_coarse_solver_name ( cs_param_amg_gamg_coarse_solver_t  coarse)
[in]coarsetype of predefined coarse solver
name of the given type of coarse solver
◆ cs_param_amg_get_gamg_smoother_name()
const char * cs_param_amg_get_gamg_smoother_name ( cs_param_amg_gamg_smoother_t  smoother)
◆ cs_param_amg_get_inhouse_solver_name()
const char * cs_param_amg_get_inhouse_solver_name ( cs_param_amg_inhouse_solver_t  solver)
[in]solversolver type
name of the given solver type
◆ cs_param_amg_get_type_name()
const char * cs_param_amg_get_type_name ( cs_param_amg_type_t  type)
[in]typetype of AMG
the associated type name
◆ cs_param_amg_hmg_copy()
cs_param_amg_hmg_t * cs_param_amg_hmg_copy ( const cs_param_amg_hmg_t *  hmgp)
[in]hmgpreference set of HMG parameters
a pointer to a new set of HMG parameters
◆ cs_param_amg_hmg_create()
cs_param_amg_hmg_t * cs_param_amg_hmg_create ( void  )
◆ cs_param_amg_hmg_log()
void cs_param_amg_hmg_log ( const char *  name,
[in]hmgpset of hmgAMG parameters
◆ cs_param_amg_inhouse_copy()
cs_param_amg_inhouse_t * cs_param_amg_inhouse_copy ( const cs_param_amg_inhouse_t *  amgp)
[in]amgpreference set of in-house AMG parameters
a pointer to a new set of in-house AMG parameters
◆ cs_param_amg_inhouse_create()
cs_param_amg_inhouse_t * cs_param_amg_inhouse_create ( bool  used_as_solver,
[in]used_as_solvertrue or false
[in]used_as_k_cycletrue or false
a pointer to a new set of parameters
◆ cs_param_amg_inhouse_log()
void cs_param_amg_inhouse_log ( const char *  name,
[in]amgpset of in-house AMG parameters
