cs_mesh_location.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "fvm/fvm_selector.h"
#include "base/cs_halo.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "mesh/cs_mesh.h"
#include "base/cs_sort.h"
+ Include dependency graph for cs_mesh_location.cpp:
static cs_mesh_location_t * _mesh_location_by_id (int id)
static const cs_mesh_location_t * _const_mesh_location_by_id (int id)
static int _find_id_by_name (const char *ref_name)
 Find the related location id from the location name. More...
static int _mesh_location_define (const char *name, cs_mesh_location_type_t type)
static void _build_by_ml_ids (cs_mesh_location_t *ml)
int cs_mesh_location_n_locations (void)
 Return number of mesh locations defined. More...
void cs_mesh_location_initialize (void)
 Initialize mesh location API. More...
void cs_mesh_location_finalize (void)
 Finalize mesh location API. More...
void cs_mesh_location_build (cs_mesh_t *mesh, int id)
 Associate mesh locations with a mesh. More...
int cs_mesh_location_add (const char *name, cs_mesh_location_type_t type, const char *criteria)
 Define a new mesh location. More...
int cs_mesh_location_add_by_func (const char *name, cs_mesh_location_type_t type, cs_mesh_location_select_t *func, void *input)
 Define a new mesh location with an associated selection function. More...
int cs_mesh_location_add_by_union (const char *name, cs_mesh_location_type_t type, int n_ml_ids, const int *ml_ids, bool complement)
int cs_mesh_location_get_id_by_name (const char *ref_name)
const char * cs_mesh_location_get_name (int id)
 Get a mesh location's name. More...
cs_mesh_location_type_t cs_mesh_location_get_type (int id)
 Get a mesh location's type. More...
const cs_lnum_t * cs_mesh_location_get_n_elts (int id)
 Get a mesh location's number of elements. More...
const cs_lnum_t * cs_mesh_location_get_elt_list (int id)
 Get a mesh location's elements list, if present. More...
const cs_lnum_t * cs_mesh_location_get_elt_ids_try (int id)
 Get a mesh location's element ids, if present. More...
const cs_lnum_t * cs_mesh_location_get_elt_ids (int id)
 Get a mesh location's element ids. More...
cs_mesh_location_def_t cs_mesh_location_get_definition_method (int id)
 Get a mesh location's definition method. More...
const char * cs_mesh_location_get_selection_string (int id)
 Get a mesh location's selection criteria string. More...
cs_mesh_location_select_t * cs_mesh_location_get_selection_function (int id)
 Get a mesh location's selection function pointer. More...
int cs_mesh_location_get_n_sub_ids (int id)
 Get a mesh location's number of sub ids. More...
int * cs_mesh_location_get_sub_ids (int id)
 Get a mesh location's list of sub ids. More...
bool cs_mesh_location_is_complement (int id)
 Check if a mesh location is built as a complement of other mesh locations. More...
bool cs_mesh_location_get_explicit_ids (int id)
 Check if cs_mesh_location_get_elt_ids always returns explicit element ids for a given mesh location type. More...
void cs_mesh_location_set_explicit_ids (int id, bool explicit_elt_ids)
 Set behavior of cs_mesh_location_get_elt_ids for mesh mesh location type. More...
◆ _build_by_ml_ids()
static void _build_by_ml_ids ( cs_mesh_location_t *  ml)
static
◆ _const_mesh_location_by_id()
static const cs_mesh_location_t * _const_mesh_location_by_id ( int  id)
static
◆ _find_id_by_name()
static int _find_id_by_name ( const char *  ref_name)
static
[in]ref_namename of the location to find
-1 if not found otherwise the associated id
◆ _mesh_location_by_id()
static cs_mesh_location_t * _mesh_location_by_id ( int  id)
static
◆ _mesh_location_define()
static int _mesh_location_define ( const char *  name,
static
◆ cs_mesh_location_add()
int cs_mesh_location_add ( const char *  name,
const char *  criteria
So as to define a subset of mesh entities of a given type, an optional selection criteria may be given.
[in]namename of location to define
[in]typetype of location to define
[in]criteriaselection criteria for associated elements, or nullptr
id of newly defined created mesh location
◆ cs_mesh_location_add_by_func()
int cs_mesh_location_add_by_func ( const char *  name,
cs_mesh_location_select_t *  func,
void *  input
[in]funcpointer to selection function for associated elements, or nullptr
[in,out]inputpointer to optional (untyped) value or structure.
◆ cs_mesh_location_add_by_union()
int cs_mesh_location_add_by_union ( const char *  name,
int  n_ml_ids,
const int *  ml_ids,
bool  complement
So as to define a subset of mesh entities of a given type, a list of ids related to existing mesh locations may be given
[in]n_ml_idsnumber of mesh location ids
[in]ml_idslist of mesh location ids
[in]complementtake the complement of the selected entities if true
id of newly created mesh location
◆ cs_mesh_location_build()
void cs_mesh_location_build ( cs_mesh_t *  mesh,
int  id
If mesh_id is negative, all defined mesh locations are associated (which is useful for the common case where only one mesh is present). If mesh_id is non-negative, only the location with the matching id is associated (which may be useful when multiple meshes are defined).
The number of elements are computed based on the underlying mesh, and element lists are built for mesh subset locations.
[in]meshpointer to associated mesh structure
[in]idid of mesh location
◆ cs_mesh_location_finalize()
void cs_mesh_location_finalize ( void  )
◆ cs_mesh_location_get_definition_method()
cs_mesh_location_def_t cs_mesh_location_get_definition_method ( int  id)
enum value corresponding to the definition method
◆ cs_mesh_location_get_elt_ids()
const cs_lnum_t * cs_mesh_location_get_elt_ids ( int  id)
This function may only be used with a given location if cs_mesh_location_set_explicit_ids has been used to indicate explicit ids are needed for this location type.
pointer to elements array (0 to n-1 numbering).
◆ cs_mesh_location_get_elt_ids_try()
const cs_lnum_t * cs_mesh_location_get_elt_ids_try ( int  id)
An array of element ids is returned if the location is a subset of a main main location type, and nullptr is returned when the id array would map to the identity function (i.e. {0, 1, 2, ..., n_elts-1}).
◆ cs_mesh_location_get_elt_list()
const cs_lnum_t * cs_mesh_location_get_elt_list ( int  id)
A list of elements is defined if the location is a subset of a main location type.
Deprecated:
Use cs_mesh_location_get_elt_ids_try or cs_mesh_location_get_elt_ids instead.
◆ cs_mesh_location_get_explicit_ids()
bool cs_mesh_location_get_explicit_ids ( int  id)
Check if cs_mesh_location_get_elt_ids always returns explicit element ids for a given mesh location.
[in]idid or type of location
true if explicit element ids are needed, false otherwise
◆ cs_mesh_location_get_id_by_name()
int cs_mesh_location_get_id_by_name ( const char *  ref_name)
◆ cs_mesh_location_get_n_elts()
const cs_lnum_t * cs_mesh_location_get_n_elts ( int  id)
A pointer to a array of 3 values is returned: 0: local number of elements 1: with standard ghost elements (if applicable) 2: with extended ghost elements (if applicable)
array of numbers of elements.
◆ cs_mesh_location_get_n_sub_ids()
int cs_mesh_location_get_n_sub_ids ( int  id)
integer value equal to the number of sub ids
◆ cs_mesh_location_get_name()
const char * cs_mesh_location_get_name ( int  id)
pointer to mesh location name
◆ cs_mesh_location_get_selection_function()
cs_mesh_location_select_t * cs_mesh_location_get_selection_function ( int  id)
pointer to mesh location selection function pointer, or nullptr
◆ cs_mesh_location_get_selection_string()
const char * cs_mesh_location_get_selection_string ( int  id)
pointer to mesh location selection criteria, or nullptr
◆ cs_mesh_location_get_sub_ids()
int * cs_mesh_location_get_sub_ids ( int  id)
pointer to the list of sub ids.
◆ cs_mesh_location_get_type()
cs_mesh_location_type_t cs_mesh_location_get_type ( int  id)
mesh location type
◆ cs_mesh_location_initialize()
void cs_mesh_location_initialize ( void  )
By default, 7 mesh locations are built, matching the 7 first values of the cs_mesh_location_type_t enum: CS_MESH_LOCATION_NONE for global values, CS_MESH_LOCATION_CELLS for the cells of the (default) global mesh, CS_MESH_LOCATION_INTERIOR_FACES and CS_MESH_LOCATION_BOUNDARY_FACES for its faces, and CS_MESH_LOCATION_VERTICES for its vertices. CS_MESH_LOCATION_FACES and a placeholder for CS_MESH_LOCATION_EDGES are also added for CDO discretizations.
Locations should then be built once the global mesh is complete, and its halo structures completed.
◆ cs_mesh_location_is_complement()
bool cs_mesh_location_is_complement ( int  id)
true if build method is a complement, false otherwise.
◆ cs_mesh_location_n_locations()
int cs_mesh_location_n_locations ( void  )
◆ cs_mesh_location_set_explicit_ids()
void cs_mesh_location_set_explicit_ids ( int  id,
Set behavior of cs_mesh_location_get_elt_ids for a given mesh location and locations based on it.
[in]explicit_elt_idsindicate if explicit element ids are needed
