cs_mesh_boundary.cpp File Reference
#include <limits.h>
#include "base/cs_mem.h"
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "fvm/fvm_io_num.h"
#include "mesh/cs_mesh_builder.h"
#include "mesh/cs_mesh_connect.h"
#include "mesh/cs_mesh_group.h"
#include "base/cs_parall.h"
#include "base/cs_sort.h"
#include "mesh/cs_mesh_boundary.h"
+ Include dependency graph for cs_mesh_boundary.cpp:
void cs_mesh_boundary_insert (cs_mesh_t *mesh, cs_lnum_t n_faces, cs_lnum_t face_id[])
 Insert boundary into the mesh. More...
void cs_mesh_boundary_insert_with_shared_vertices (cs_mesh_t *mesh, cs_lnum_t n_faces, cs_lnum_t face_id[])
 Insert boundary into the mesh, sharing vertices on both sides. More...
void cs_mesh_boundary_insert_separating_cells (cs_mesh_t *mesh, const char *group_name, cs_lnum_t n_cells, const cs_lnum_t cell_id[])
 Insert a boundary into the mesh between a given set of cells and the the others. More...
void cs_mesh_boundary_remove_periodicity (cs_mesh_t *mesh)
 Remove periodicity information from a mesh. More...
◆ cs_mesh_boundary_insert()
void cs_mesh_boundary_insert ( cs_mesh_t *  mesh,
cs_lnum_t  n_faces,
cs_lnum_t  face_id[]
This is done by transforming interior faces into boundary faces.
Note that the ids of selected faces are sorted by this function.
[in,out]meshpointer to mesh structure to modify
[in]n_facesnumber of selected (interior) faces
[in,out]face_idlist of selected (interior) faces (0 to n-1)
◆ cs_mesh_boundary_insert_separating_cells()
void cs_mesh_boundary_insert_separating_cells ( cs_mesh_t *  mesh,
const char *  group_name,
cs_lnum_t  n_cells,
An optional group name may be assigned to newly created boundary faces.
Note that the list of selected faces is sorted by this function.
[in]group_namegroup name to assign to newly created boundary faces, or nullptr
[in]n_cellsnumber of separated cells
[in]cell_idseparated cell ids
◆ cs_mesh_boundary_insert_with_shared_vertices()
void cs_mesh_boundary_insert_with_shared_vertices ( cs_mesh_t *  mesh,
cs_lnum_t  n_faces,
cs_lnum_t  face_id[]
This function should be used with caution, as sharing vertices may cause issues with vertex-based values, gradient extended neighborhoods, and some visualization operations.
◆ cs_mesh_boundary_remove_periodicity()
void cs_mesh_boundary_remove_periodicity ( cs_mesh_t *  mesh)
Periodic interior faces are transformed into boundary faces.
