cs_mesh_adjacencies.h File Reference
#include "base/cs_base.h"
#include "base/cs_base_accel.h"
#include "base/cs_halo.h"
#include "mesh/cs_mesh.h"
+ Include dependency graph for cs_mesh_adjacencies.h:
Classes
struct  cs_adjacency_t
struct  cs_mesh_adjacencies_t
Macros
#define CS_ADJACENCY_SHARED   (1 << 0)
#define CS_ADJACENCY_STRIDE   (1 << 1)
#define CS_ADJACENCY_SIGNED   (1 << 2)
cs_mesh_adjacencies_t * cs_mesh_adjacencies_get_global (void)
 Get non-const pointer to cs_glob_mesh_adacencies. More...
void cs_mesh_adjacencies_initialize (void)
 Initialize mesh adjacencies helper API. More...
void cs_mesh_adjacencies_finalize (void)
 Finalize mesh adjacencies helper API. More...
void cs_mesh_adjacencies_update_mesh (void)
 Update mesh adjacencies helper API relative to mesh. More...
void cs_mesh_adjacencies_update_cell_cells_e (void)
 Update extended cell -> cell connectivites in mesh adjacencies helper API relative to mesh. More...
void cs_mesh_adjacencies_update_cell_i_faces (void)
 Ensure presence of cell -> interior face connectivites in mesh adjacencies helper API relative to mesh. More...
void cs_mesh_adjacencies_update_cell_b_faces (void)
 Update cells -> boundary faces connectivity. More...
void cs_mesh_adjacencies_update_device (cs_alloc_mode_t alloc_mode)
 Map some global mesh adjacency arrays for use on device. More...
const cs_adjacency_t * cs_mesh_adjacencies_cell_faces (void)
 Return cell -> face connectivites in mesh adjacencies helper API relative to mesh. More...
const cs_adjacency_t * cs_mesh_adjacencies_cell_vertices (void)
 Return cell -> vertex connectivites in mesh adjacencies helper API relative to mesh. More...
cs_adjacency_t * cs_adjacency_create (cs_flag_t flag, int stride, cs_lnum_t n_elts)
 Create a cs_adjacency_t structure of size n_elts. More...
cs_adjacency_t * cs_adjacency_create_from_s_arrays (cs_lnum_t n_elts, int stride, cs_lnum_t *ids, short int *sgn)
 Create a cs_adjacency_t structure sharing arrays scanned with a stride. More...
cs_adjacency_t * cs_adjacency_create_from_i_arrays (cs_lnum_t n_elts, cs_lnum_t *idx, cs_lnum_t *ids, short int *sgn)
 Create a cs_adjacency_t structure sharing arrays scanned with an index. More...
void cs_adjacency_destroy (cs_adjacency_t **p_adj)
 Destroy a cs_adjacency_t structure. More...
cs_adjacency_t * cs_adjacency_compose (int n_c_elts, const cs_adjacency_t *a2b, const cs_adjacency_t *b2c)
 Create a new cs_adjacency_t structure from the composition of two cs_adjacency_t structures: (1) A -> B and (2) B -> C The resulting structure describes A -> C. It does not rely on a stride and has no sgn member. More...
cs_adjacency_t * cs_adjacency_concatenate (const cs_adjacency_t *a2b_1, const cs_adjacency_t *a2b_2)
 Create a new cs_adjacency_t structure from the concatenation of two cs_adjacency_t structures: A -> B created by two different compositions: (1) A -> B = A -> C + C -> B (2) A -> B = A -> D + D -> B. More...
cs_adjacency_t * cs_adjacency_difference (const cs_adjacency_t *a2b_1, const cs_adjacency_t *a2b_2)
 Create a new cs_adjacency_t structure from the difference of two cs_adjacency_t structures: A -> B created by two different compositions: (1) A -> B = A -> C + C -> B (2) A -> B = A -> D + D -> B. More...
cs_adjacency_t * cs_adjacency_transpose (int n_b_elts, const cs_adjacency_t *a2b)
 Create a new cs_adjacency_t structure from a one corresponding to A -> B. The resulting structure deals with B -> A. More...
void cs_adjacency_sort (cs_adjacency_t *adj)
 Sort each sub-list related to an entry in a cs_adjacency_t structure. More...
void cs_adjacency_remove_self_entries (cs_adjacency_t *adj)
 In an indexed list, remove id(s) corresponding to the current index. Useful for instance in order to prepare a matrix structure in MSR storage. More...
void cs_adjacency_dump (const char *name, FILE *_f, cs_adjacency_t *adj)
 Dump a cs_adjacency_t structure to a file or into the standard output. More...
cs_adjacency_t * cs_mesh_adjacency_c2f (const cs_mesh_t *m, int boundary_order)
 Build a cells to faces adjacency structure. More...
cs_adjacency_t * cs_mesh_adjacency_c2f_lower (const cs_mesh_t *m, int boundary_order)
 Build a partial cells to faces adjacency structure. More...
cs_adjacency_t * cs_mesh_adjacency_c2f_boundary (const cs_mesh_t *m)
 Build a cells to boundary faces adjacency structure. More...
cs_adjacency_t * cs_mesh_adjacency_v2v (const cs_mesh_t *m)
 Allocate and define a cs_adjacency_t structure related to the connectivity vertex to vertices through edges. More...
const cs_mesh_adjacencies_t * cs_glob_mesh_adjacencies
◆ cs_adjacency_compose()
cs_adjacency_t * cs_adjacency_compose ( int  n_c_elts,
const cs_adjacency_t *  a2b,
const cs_adjacency_t *  b2c
[in]n_c_eltsnumber of elements in C set
[in]a2badjacency A -> B
[in]b2cadjacency B -> C
a pointer to the cs_adjacency_t structure A -> C
◆ cs_adjacency_concatenate()
cs_adjacency_t * cs_adjacency_concatenate ( const cs_adjacency_t *  a2b_1,
const cs_adjacency_t *  a2b_2
The resulting structure describes A -> B. It does not rely on a stride and has no sgn member and duplicated elements are removed
[in]a2b_1adjacency A -> B (1)
[in]a2b_2adjacency A -> B (2)
a pointer to the cs_adjacency_t structure A -> B
◆ cs_adjacency_create()
cs_adjacency_t * cs_adjacency_create ( cs_flag_t  flag,
int  stride,
cs_lnum_t  n_elts
[in]flagmetadata related to the new cs_adjacency to create
[in]stride> 0 if useful otherwise ignored
[in]n_eltsnumber of entries of the indexed list
a pointer to a new allocated cs_adjacency_t structure
◆ cs_adjacency_create_from_i_arrays()
cs_adjacency_t * cs_adjacency_create_from_i_arrays ( cs_lnum_t  n_elts,
cs_lnum_t *  idx,
cs_lnum_t *  ids,
short int *  sgn
[in]n_eltsnumber of elements
[in]idxarray of size n_elts + 1
[in]idsarray of element ids (size = idx[n_elts])
[in]sgnarray storing the orientation (may be NULL)
[in]sgnarray storing the orientation (may be nullptr)
◆ cs_adjacency_create_from_s_arrays()
cs_adjacency_t * cs_adjacency_create_from_s_arrays ( cs_lnum_t  n_elts,
int  stride,
cs_lnum_t *  ids,
short int *  sgn
[in]stridevalue of the stride
[in]idsarray of element ids (size = stride * n_elts)
◆ cs_adjacency_destroy()
void cs_adjacency_destroy ( cs_adjacency_t **  p_adj)
[in,out]p_adjpointer of pointer to a cs_adjacency_t structure
◆ cs_adjacency_difference()
cs_adjacency_t * cs_adjacency_difference ( const cs_adjacency_t *  a2b_1,
The resulting structure describes (1)(2). It does not rely on a stride and has no sgn member and duplicated elements are removed
◆ cs_adjacency_dump()
void cs_adjacency_dump ( const char *  name,
FILE *  _f,
cs_adjacency_t *  adj
[in]namename of the dump file. Can be set to NULL
[in]_fpointer to a FILE structure. Can be set to NULL.
[in]adjpointer to a cs_adjacency_t structure
[in]namename of the dump file. Can be set to nullptr
[in]_fpointer to a FILE structure. Can be set to nullptr.
◆ cs_adjacency_remove_self_entries()
void cs_adjacency_remove_self_entries ( cs_adjacency_t *  adj)
[in,out]adjpointer to the cs_adjacency_t structure to update
◆ cs_adjacency_sort()
void cs_adjacency_sort ( cs_adjacency_t *  adj)
◆ cs_adjacency_transpose()
cs_adjacency_t * cs_adjacency_transpose ( int  n_b_elts,
[in]n_b_eltssize of the set of B elements
[in]a2bpointer to the A -> B cs_adjacency_t structure
a new pointer to the cs_adjacency_t structure B -> A
◆ cs_mesh_adjacencies_cell_faces()
const cs_adjacency_t * cs_mesh_adjacencies_cell_faces ( void  )
Boundary faces appear first, interior faces second.
This connectivity is built only when first requested, then updated later if needed.
◆ cs_mesh_adjacencies_cell_vertices()
const cs_adjacency_t * cs_mesh_adjacencies_cell_vertices ( void  )
◆ cs_mesh_adjacencies_finalize()
void cs_mesh_adjacencies_finalize ( void  )
◆ cs_mesh_adjacencies_get_global()
cs_mesh_adjacencies_t * cs_mesh_adjacencies_get_global ( void  )
◆ cs_mesh_adjacencies_initialize()
void cs_mesh_adjacencies_initialize ( void  )
◆ cs_mesh_adjacencies_update_cell_b_faces()
void cs_mesh_adjacencies_update_cell_b_faces ( void  )
◆ cs_mesh_adjacencies_update_cell_cells_e()
void cs_mesh_adjacencies_update_cell_cells_e ( void  )
◆ cs_mesh_adjacencies_update_cell_i_faces()
void cs_mesh_adjacencies_update_cell_i_faces ( void  )
◆ cs_mesh_adjacencies_update_device()
void cs_mesh_adjacencies_update_device ( cs_alloc_mode_t  alloc_mode)
More elements may be mapped dependin on which arrays are used in accelerated algorithms.
[in]alloc_modechosen allocation mode
◆ cs_mesh_adjacencies_update_mesh()
void cs_mesh_adjacencies_update_mesh ( void  )
◆ cs_mesh_adjacency_c2f()
cs_adjacency_t * cs_mesh_adjacency_c2f ( const cs_mesh_t *  m,
int  boundary_order
With the boundary_order option set to 0, boundary faces come first, so interior face ids are shifted by the number of boundary faces. With boundary_order set to 1, boundary faces come last, so face ids are shifted by the number of interior faces.
[in]mpointer to a cs_mesh_t structure
[in]boundary_orderboundaries first (0) or last (1)
◆ cs_mesh_adjacency_c2f_boundary()
cs_adjacency_t * cs_mesh_adjacency_c2f_boundary ( const cs_mesh_t *  m)
By construction, face ids adjacent to each cell are ordered.
◆ cs_mesh_adjacency_c2f_lower()
cs_adjacency_t * cs_mesh_adjacency_c2f_lower ( const cs_mesh_t *  m,
int  boundary_order
With the boundary_order option set to 0, boundary faces come first, so interior face ids are shifted by the number of boundary faces. With boundary_order set to 1, boundary faces come last, so face ids are shifted by the number of interior faces. With boundary order set to -1, boundary faces are ignored.
Only internal faces as seen from the cell with lowest cell id (out of 2 cells adjacent to that face) are added to the structure, so each face appears only once, not twice. In other words, only the lower part of the corresponding cell-cells adjacency matrix is built.
[in]boundary_orderboundaries first (0), last (1), or ignored (-1)
◆ cs_mesh_adjacency_v2v()
cs_adjacency_t * cs_mesh_adjacency_v2v ( const cs_mesh_t *  m)
Adjacent vertices are accessed based on the vertex with lowest id. Another v2v connectivity through cells is possible. Please read the cs_cdo_connect.cpp source code if interested
◆ cs_glob_mesh_adjacencies
const cs_mesh_adjacencies_t* cs_glob_mesh_adjacencies
extern
