cs_mesh.h File Reference
#include "fvm/fvm_group.h"
#include "fvm/fvm_selector.h"
#include "fvm/fvm_periodicity.h"
#include "base/cs_base.h"
#include "base/cs_halo.h"
#include "base/cs_interface.h"
#include "base/cs_numbering.h"
#include "base/cs_parall.h"
#include "base/cs_range_set.h"
#include "mesh/cs_mesh_builder.h"
+ Include dependency graph for cs_mesh.h:
Classes
struct  cs_mesh_t
Macros
#define CS_MESH_MODIFIED   (1 << 0)
#define CS_MESH_MODIFIED_BALANCE   (1 << 1)
Enumerations
enum  cs_mesh_time_dep_t { CS_MESH_FIXED , CS_MESH_TRANSIENT_COORDS , CS_MESH_TRANSIENT_CONNECT }
cs_mesh_t * cs_mesh_create (void)
cs_mesh_t * cs_mesh_destroy (cs_mesh_t *mesh)
void cs_mesh_reinit (cs_mesh_t *mesh)
cs_gnum_t cs_mesh_compact_gnum (cs_lnum_t n_elts, cs_gnum_t *elt_gnum)
void cs_mesh_free_rebuildable (cs_mesh_t *mesh, bool free_halos)
void cs_mesh_free_b_rebuildable (cs_mesh_t *mesh)
void cs_mesh_discard_free_faces (cs_mesh_t *mesh)
void cs_mesh_discard_free_vertices (cs_mesh_t *mesh)
void cs_mesh_discard_refinement_info (cs_mesh_t *mesh)
 Discard mesh refinement info. More...
void cs_mesh_update_b_cells (cs_mesh_t *mesh)
void cs_mesh_update_auxiliary (cs_mesh_t *mesh)
void cs_mesh_init_interfaces (cs_mesh_t *mesh, cs_mesh_builder_t *mb)
void cs_mesh_init_halo (cs_mesh_t *mesh, cs_mesh_builder_t *mb, cs_halo_type_t halo_type, int verbosity, bool rebuild_vtx_interace)
cs_gnum_t cs_mesh_n_g_ghost_cells (cs_mesh_t *mesh)
void cs_mesh_sync_var_scal (cs_real_t *var)
void cs_mesh_clean_families (cs_mesh_t *mesh)
fvm_group_class_set_t * cs_mesh_create_group_classes (cs_mesh_t *mesh)
void cs_mesh_init_group_classes (cs_mesh_t *mesh)
void cs_mesh_init_selectors (void)
void cs_mesh_init_cell_selector (void)
void cs_mesh_init_b_selector (void)
void cs_mesh_init_i_selector (void)
void cs_mesh_update_selectors (cs_mesh_t *mesh)
void cs_mesh_get_perio_faces (const cs_mesh_t *mesh, cs_lnum_t **n_perio_face_couples, cs_gnum_t ***perio_face_couples)
cs_gnum_t * cs_mesh_get_cell_gnum (const cs_mesh_t *mesh, int blank_perio)
void cs_mesh_get_face_perio_num (const cs_mesh_t *mesh, int perio_num[])
void cs_mesh_tag_boundary_cells (cs_mesh_t *mesh, int cell_b_flag[])
 Mark cells adjacent to boundary, through faces or vertices. More...
void cs_mesh_print_info (const cs_mesh_t *mesh, const char *name)
void cs_mesh_print_element_counts (const cs_mesh_t *mesh, const char *name)
void cs_mesh_g_face_vertices_sizes (const cs_mesh_t *mesh, cs_gnum_t *g_i_face_vertices_size, cs_gnum_t *g_b_face_vertices_size)
void cs_mesh_selector_stats (cs_mesh_t *mesh)
void cs_mesh_dump (const cs_mesh_t *mesh)
void cs_mesh_i_faces_thread_block_count (const cs_mesh_t *m, const cs_e2n_sum_t e2n, int block_size, int *n_groups, int *n_blocks)
 Determine number of blocks and associated groups to be used for loops on interior faces. More...
void cs_mesh_i_faces_thread_block_range (const cs_mesh_t *m, const cs_e2n_sum_t e2n, int group_id, int block_id, int block_count, int block_size, cs_lnum_t *s_id, cs_lnum_t *e_id)
 Compute array index bounds for a block of interior faces associated to a thread or task. More...
cs_mesh_t * cs_glob_mesh
◆ CS_MESH_MODIFIED
Any type of mesh modification
◆ CS_MESH_MODIFIED_BALANCE
Mesh modification has changed mesh distribution balance
◆ cs_mesh_time_dep_t
Mesh time dependency
Enumerator
CS_MESH_FIXED
Mesh definitions do not change with time
Vertex coordinates may change with time
Mesh connectivity may change with time
◆ cs_mesh_clean_families()
void cs_mesh_clean_families ( cs_mesh_t *  mesh)
◆ cs_mesh_compact_gnum()
cs_gnum_t cs_mesh_compact_gnum ( cs_lnum_t  n_elts,
cs_gnum_t *  elt_gnum
◆ cs_mesh_create()
cs_mesh_t * cs_mesh_create ( void  )
◆ cs_mesh_create_group_classes()
fvm_group_class_set_t * cs_mesh_create_group_classes ( cs_mesh_t *  mesh)
◆ cs_mesh_destroy()
cs_mesh_t * cs_mesh_destroy ( cs_mesh_t *  mesh)
◆ cs_mesh_discard_free_faces()
void cs_mesh_discard_free_faces ( cs_mesh_t *  mesh)
◆ cs_mesh_discard_free_vertices()
void cs_mesh_discard_free_vertices ( cs_mesh_t *  mesh)
◆ cs_mesh_discard_refinement_info()
void cs_mesh_discard_refinement_info ( cs_mesh_t *  mesh)
This information is used only for mesh coarsening or post-processing output of the refinement level, so can be discarded in other cases.
[in,out]meshpointer to mesh structure
◆ cs_mesh_dump()
void cs_mesh_dump ( const cs_mesh_t *  mesh)
◆ cs_mesh_free_b_rebuildable()
void cs_mesh_free_b_rebuildable ( cs_mesh_t *  mesh)
◆ cs_mesh_free_rebuildable()
void cs_mesh_free_rebuildable ( cs_mesh_t *  mesh,
bool  free_halos
◆ cs_mesh_g_face_vertices_sizes()
void cs_mesh_g_face_vertices_sizes ( const cs_mesh_t *  mesh,
cs_gnum_t *  g_i_face_vertices_size,
cs_gnum_t *  g_b_face_vertices_size
◆ cs_mesh_get_cell_gnum()
cs_gnum_t * cs_mesh_get_cell_gnum ( const cs_mesh_t *  mesh,
int  blank_perio
◆ cs_mesh_get_face_perio_num()
void cs_mesh_get_face_perio_num ( const cs_mesh_t *  mesh,
int  perio_num[]
◆ cs_mesh_get_perio_faces()
void cs_mesh_get_perio_faces ( const cs_mesh_t *  mesh,
cs_lnum_t **  n_perio_face_couples,
cs_gnum_t ***  perio_face_couples
◆ cs_mesh_i_faces_thread_block_count()
void cs_mesh_i_faces_thread_block_count ( const cs_mesh_t *  m,
int  block_size,
int *  n_groups,
int *  n_blocks
Blocks from a same group may be processed in parallel, while blocks from separate groups must not run simultaneously to avoid race conditions.
[in]mpointer to mesh
[in]e2nassociated indexed sum algorithm type.
[in]block_sizesize of thread blocks (chunks) if > 0, ignored (recomputed) if 0.
[out]n_groupsnumber of associated block groups
[out]n_blocksnumber of associated blocks
◆ cs_mesh_i_faces_thread_block_range()
void cs_mesh_i_faces_thread_block_range ( const cs_mesh_t *  m,
int  group_id,
int  block_id,
int  block_count,
int  block_size,
cs_lnum_t *  s_id,
cs_lnum_t *  e_id
When the CS_E2N_SUM_SCATTER indexed sum algorithmm is used and mesh interior faces are renumbered for threads, the bounds provided are those based on the matching group and thread.
In other cases, if block_size < 1 (i.e. not specified), the start and past-the-end indexes are defined so as to evenly distribute values to threads, in a manner similar to OpenMP schedule(static). With a block size larger than zero, indexes will be simply based on the block's start and past-the end index.
[in]group_idgroup id
[in]block_idblock id (relative to group)
[in]block_countnumber of blocks
[in]block_sizesize of blocks (chunks) if > 0, ignored (recomputed) if 0
[in,out]s_idstart index for the current block
[in,out]e_idpast-the-end index for the current block
◆ cs_mesh_init_b_selector()
void cs_mesh_init_b_selector ( void  )
◆ cs_mesh_init_cell_selector()
void cs_mesh_init_cell_selector ( void  )
◆ cs_mesh_init_group_classes()
void cs_mesh_init_group_classes ( cs_mesh_t *  mesh)
◆ cs_mesh_init_halo()
void cs_mesh_init_halo ( cs_mesh_t *  mesh,
cs_mesh_builder_t *  mb,
int  verbosity,
bool  rebuild_vtx_interface
Creation and initialization of halo structures.
Treatment of parallel and/or periodic halos for standard and extended ghost cells according to halo type requested by global options.
[in,out]mbpointer to mesh builder (for periodicity)
[in]halo_typetype of halo (standard or extended)
[in]verbosityverbosity
[in]rebuild_vtx_interfacealso rebuild vertex interfaces ?
◆ cs_mesh_init_i_selector()
void cs_mesh_init_i_selector ( void  )
◆ cs_mesh_init_interfaces()
void cs_mesh_init_interfaces ( cs_mesh_t *  mesh,
◆ cs_mesh_init_selectors()
void cs_mesh_init_selectors ( void  )
◆ cs_mesh_n_g_ghost_cells()
cs_gnum_t cs_mesh_n_g_ghost_cells ( cs_mesh_t *  mesh)
◆ cs_mesh_print_element_counts()
void cs_mesh_print_element_counts ( const cs_mesh_t *  mesh,
const char *  name
◆ cs_mesh_print_info()
void cs_mesh_print_info ( const cs_mesh_t *  mesh,
const char *  name
◆ cs_mesh_reinit()
void cs_mesh_reinit ( cs_mesh_t *  mesh)
◆ cs_mesh_selector_stats()
void cs_mesh_selector_stats ( cs_mesh_t *  mesh)
◆ cs_mesh_sync_var_scal()
void cs_mesh_sync_var_scal ( cs_real_t *  var)
◆ cs_mesh_tag_boundary_cells()
void cs_mesh_tag_boundary_cells ( cs_mesh_t *  mesh,
int  cell_b_flag[]
Note that cells adjacent through a boundary face can be accessed directly through the mesh->b_cells member, but the set of cells flagged by this function is more complete.
[in]meshpointer to a mesh structure
[out]cell_b_flag1 for cells adjacent to boundary, 0 for others
◆ cs_mesh_update_auxiliary()
void cs_mesh_update_auxiliary ( cs_mesh_t *  mesh)
◆ cs_mesh_update_b_cells()
void cs_mesh_update_b_cells ( cs_mesh_t *  mesh)
◆ cs_mesh_update_selectors()
void cs_mesh_update_selectors ( cs_mesh_t *  mesh)
◆ cs_glob_mesh
cs_mesh_t* cs_glob_mesh
extern
