cs_medcoupling_postprocess.cxx File Reference
#include <vector>
#include <string>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "base/cs_function.h"
#include "base/cs_halo.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_medcoupling_utils.h"
#include "cs_medcoupling_mesh.hxx"
#include "base/cs_post.h"
#include "base/cs_medcoupling_postprocess.h"
+ Include dependency graph for cs_medcoupling_postprocess.cxx:
Enumerations
enum  cs_medcoupling_int_weight_t {
  CS_MEDCPL_INT_WEIGHT_NONE , CS_MEDCPL_INT_WEIGHT_SCALAR , CS_MEDCPL_INT_WEIGHT_VECTOR , CS_MEDCPL_INT_WEIGHT_SCALAR_VECTOR ,
  CS_MEDCPL_INT_WEIGHT_N_TYPES
cs_medcoupling_slice_t * cs_medcoupling_slice_by_id (int id)
 Get pointer to a slice based on id. More...
cs_medcoupling_slice_t * cs_medcoupling_slice_by_name (const char *name)
 Get pointer to slice based on name, raises an error if not found. More...
cs_medcoupling_slice_t * cs_medcoupling_slice_by_name_try (const char *name)
 Get pointer to slice based on name. Returns nullptr if not found. More...
void cs_medcoupling_postprocess_add_plane_slice (const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t length1, const cs_real_t length2)
 Add a slice based on a plane. More...
void cs_medcoupling_postprocess_add_disc_slice (const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius, const int n_sectors)
 Add a slice based on a disc. More...
void cs_medcoupling_postprocess_add_annulus_slice (const char *name, const char *selection_criteria, const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius1, const cs_real_t radius2, const int n_sectors)
 Add a slice based on an annulus. More...
cs_lnum_t cs_medcoupling_slice_get_n_elts (const char *name)
 Get number cells that may be intersected by the slice. More...
cs_lnum_t * cs_medcoupling_slice_get_elt_ids (const char *name)
 Get list of ids of the elements which may be intersected. More...
cs_real_t * cs_medcoupling_slice_get_surfaces (const char *name)
 Get list of intersection surfaces for each cell intersected. More...
cs_real_t cs_medcoupling_slice_get_total_surface (const char *name)
 Get total intersection surface between a slice and volume mesh. More...
void cs_medcoupling_slice_activate_postprocess (const char *name)
 Activate postprocessing of intersected cells. More...
cs_real_t cs_medcoupling_slice_scalar_integral (const char *name, const cs_real_t *scalar)
 Compute integral of a scalar over a slice. More...
cs_real_t cs_medcoupling_slice_scalar_mean (const char *name, const cs_real_t *scalar)
 Compute mean value of a scalar over a slice. More...
cs_real_t cs_medcoupling_slice_scalar_integral_weighted (const char *name, const cs_real_t *scalar, const cs_real_t *weight_s, const cs_real_3_t *weight_v)
 Compute integral of a scalar over a slice using a scalar and/or vectorial weights. If nullptr is provided for both weights, the non-weighted function is called. More...
cs_real_t cs_medcoupling_slice_scalar_mean_weighted (const char *name, const cs_real_t *scalar, const cs_real_t *weight_s, const cs_real_3_t *weight_v)
 Compute mean of a scalar over a slice using a scalar and/or vectorial weights. If nullptr is provided for both weights, the non-weighted function is called. More...
void cs_medcoupling_slice_destroy_all (void)
 Destroy all slices. More...
static int _n_slices = 0
static cs_medcoupling_slice_t ** _slices = nullptr
◆ cs_medcoupling_int_weight_t
Enumerator
◆ cs_medcoupling_postprocess_add_annulus_slice()
void cs_medcoupling_postprocess_add_annulus_slice ( const char *  name,
const char *  selection_criteria,
const int  n_sectors
[in]namename of the slice
[in]selection_criteriaselection criteria for cells
[in]origincoordinates of slice's origin point
[in]normalnormal vector of the slice
[in]radius1inner disc's radius
[in]radius2outer disc's radius
[in]n_sectorsnumber of sectors for discretization. if negative, default value (36) is used.
◆ cs_medcoupling_postprocess_add_disc_slice()
void cs_medcoupling_postprocess_add_disc_slice ( const char *  name,
const int  n_sectors
[in]nameName of the slice
[in]selection_criteriaSelection criteria for cells to intersect
[in]originCoordinates of origin point of slice
[in]normalNormal vector of the slice
[in]radiusRadius of the disc
[in]n_sectorsNumber of sectors for discretization. If negative default value (36) is used.
[in]radiusdisc's radius
◆ cs_medcoupling_postprocess_add_plane_slice()
void cs_medcoupling_postprocess_add_plane_slice ( const char *  name,
[in]length1length along the plane's first axis
[in]length2length along the plane's second axis
◆ cs_medcoupling_slice_activate_postprocess()
void cs_medcoupling_slice_activate_postprocess ( const char *  name)
◆ cs_medcoupling_slice_by_id()
cs_medcoupling_slice_t * cs_medcoupling_slice_by_id ( int  id)
pointer to slice. Raises an error if index is out of bounds.
[in]idindex of the slice
◆ cs_medcoupling_slice_by_name()
cs_medcoupling_slice_t * cs_medcoupling_slice_by_name ( const char *  name)
pointer to slice, raises error if not found.
◆ cs_medcoupling_slice_by_name_try()
cs_medcoupling_slice_t * cs_medcoupling_slice_by_name_try ( const char *  name)
pointer to slice, nullptr if not found.
◆ cs_medcoupling_slice_destroy_all()
void cs_medcoupling_slice_destroy_all ( void  )
Destroy all slices.
◆ cs_medcoupling_slice_get_elt_ids()
cs_lnum_t * cs_medcoupling_slice_get_elt_ids ( const char *  name)
Pointer to list of ids (cs_lnum_t *). Do not deallocate!
◆ cs_medcoupling_slice_get_n_elts()
cs_lnum_t cs_medcoupling_slice_get_n_elts ( const char *  name)
Number of elements
◆ cs_medcoupling_slice_get_surfaces()
cs_real_t * cs_medcoupling_slice_get_surfaces ( const char *  name)
Pointer to list of intersection surfaces (cs_real_t *)
◆ cs_medcoupling_slice_get_total_surface()
cs_real_t cs_medcoupling_slice_get_total_surface ( const char *  name)
Value of total intersection surface
◆ cs_medcoupling_slice_scalar_integral()
cs_real_t cs_medcoupling_slice_scalar_integral ( const char *  name,
const cs_real_t *  scalar
Global integrated value. A cs_parall_sum is used.
[in]scalararray of scalar values (size n_cells)
◆ cs_medcoupling_slice_scalar_integral_weighted()
cs_real_t cs_medcoupling_slice_scalar_integral_weighted ( const char *  name,
const cs_real_t *  scalar,
const cs_real_t *  weight_s,
const cs_real_3_t *  weight_v
Computed integral value over entire slice (parallel)
[in]weight_sscalar weight array (n_cells)
[in]weight_vvectorial weight array (n_cells)
◆ cs_medcoupling_slice_scalar_mean()
cs_real_t cs_medcoupling_slice_scalar_mean ( const char *  name,
◆ cs_medcoupling_slice_scalar_mean_weighted()
cs_real_t cs_medcoupling_slice_scalar_mean_weighted ( const char *  name,
Computed mean value over entire slice (parallel)
◆ _n_slices
int _n_slices = 0
static
◆ _slices
cs_medcoupling_slice_t** _slices = nullptr
static
