cs_medcoupling_mesh.hxx File Reference
#include <stdarg.h>
#include <string>
#include "mesh/cs_mesh.h"
+ Include dependency graph for cs_medcoupling_mesh.hxx:
Classes
struct  cs_medcoupling_mesh_t
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_base (cs_mesh_t *csmesh, const char *name, const char *selection_criteria, int elt_dim, int use_bbox)
 create a new cs_medcoupling_mesh_t instance based on cs_mesh_t More...
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_ids (cs_mesh_t *csmesh, const char *name, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int elt_dim, int use_bbox)
void cs_medcoupling_mesh_destroy (cs_medcoupling_mesh_t *mesh)
 Destroy a cs_medcoupling_mesh_t. More...
void cs_medcoupling_mesh_destroy_all (void)
 Destroy all cs_medcoupling_mesh_t instances. More...
int cs_medcoupling_mesh_get_dim (cs_medcoupling_mesh_t *m)
 Return a cs_medcoupling_mesh_t structure's spatial dimension. More...
cs_lnum_t cs_medcoupling_mesh_get_n_elts (cs_medcoupling_mesh_t *m)
 Return a cs_medcoupling_mesh_t structure's number of elements. More...
const cs_lnum_t * cs_medcoupling_mesh_get_elt_list (cs_medcoupling_mesh_t *m)
 Return a cs_medcoupling_mesh_t structure's (parent) elements list. More...
cs_lnum_t cs_medcoupling_mesh_get_n_vertices (cs_medcoupling_mesh_t *m)
 Return a cs_medcoupling_mesh_t structure's number of vertices. More...
const cs_lnum_t * cs_medcoupling_mesh_get_vertex_list (cs_medcoupling_mesh_t *m)
 Return a cs_medcoupling_mesh_t structure's (parent) vertices list. More...
const cs_lnum_t * cs_medcoupling_mesh_get_connectivity (cs_medcoupling_mesh_t *m)
void cs_medcoupling_mesh_export (cs_medcoupling_mesh_t *m, const std::string name)
 Export a medcoupling_mesh. More...
void * cs_medcoupling_create_plane_mesh (const cs_real_t origin[], const cs_real_t normal[], const cs_real_t length1, const cs_real_t length2)
 Returns a pointer to a MEDCouplingUMesh of a plane. More...
void * cs_medcoupling_create_disc_mesh (const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius, const int n_sectors)
 Returns a pointer to a MEDCouplingUMesh of a disc. More...
void * cs_medcoupling_create_annulus_mesh (const cs_real_t origin[], const cs_real_t normal[], const cs_real_t radius1, const cs_real_t radius2, const int n_sectors)
 Returns a pointer to a MEDCouplingUMesh of an annulus. More...
◆ cs_medcoupling_create_annulus_mesh()
void * cs_medcoupling_create_annulus_mesh ( const cs_real_t  origin[],
const int  n_sectors
[in]originAnnulus origin coordinates
[in]normalAnnulus normal vector
[in]radius1Annulus inner radius
[in]radius2Annulus outer radius
[in]n_sectorsNumber of sectors for discretization. If negative, default value of 36 is taken.
pointer to the MEDCouplingUMesh structure.
◆ cs_medcoupling_create_disc_mesh()
void * cs_medcoupling_create_disc_mesh ( const cs_real_t  origin[],
const int  n_sectors
[in]originDisc origin coordinates
[in]normalDisc normal vector
[in]radiusDisc radius
◆ cs_medcoupling_create_plane_mesh()
void * cs_medcoupling_create_plane_mesh ( const cs_real_t  origin[],
[in]originPlane origin coordinates
[in]normalPlane normal vector
[in]length1Plane's edge length along first axis
[in]length2Plane's edge length along second axis
◆ cs_medcoupling_mesh_destroy()
void cs_medcoupling_mesh_destroy ( cs_medcoupling_mesh_t *  mesh)
[in]meshcs_medcoupling_mesh_t pointer
◆ cs_medcoupling_mesh_destroy_all()
void cs_medcoupling_mesh_destroy_all ( void  )
◆ cs_medcoupling_mesh_export()
void cs_medcoupling_mesh_export ( cs_medcoupling_mesh_t *  m,
[in]namename of the file
◆ cs_medcoupling_mesh_from_base()
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_base ( cs_mesh_t *  csmesh,
const char *  name,
const char *  selection_criteria,
int  elt_dim,
int  use_bbox
[in]csmeshpointer to cs_mesh_t instance
[in]namename of the mesh
[in]selection_criteriaselection criteria string
[in]elt_dimdimension of elements (2: faces, 3: cells)
[in]use_bboxUse a reduced bounding box
pointer to the newly created cs_medcoupling_mesh_t struct
◆ cs_medcoupling_mesh_from_ids()
cs_medcoupling_mesh_t * cs_medcoupling_mesh_from_ids ( cs_mesh_t *  csmesh,
const char *  name,
cs_lnum_t  n_elts,
int  elt_dim,
int  use_bbox
[in]n_eltslocal number of elements
[in]elt_idslist of local elements
[in]use_bboxuse a reduced bounding box
◆ cs_medcoupling_mesh_get_connectivity()
const cs_lnum_t * cs_medcoupling_mesh_get_connectivity ( cs_medcoupling_mesh_t *  m)
ids of associated elements, or NULL
ids of associated elements, or nullptr
◆ cs_medcoupling_mesh_get_dim()
int cs_medcoupling_mesh_get_dim ( cs_medcoupling_mesh_t *  m)
associated spatial dimension
◆ cs_medcoupling_mesh_get_elt_list()
const cs_lnum_t * cs_medcoupling_mesh_get_elt_list ( cs_medcoupling_mesh_t *  m)
◆ cs_medcoupling_mesh_get_n_elts()
cs_lnum_t cs_medcoupling_mesh_get_n_elts ( cs_medcoupling_mesh_t *  m)
associated number of elements
◆ cs_medcoupling_mesh_get_n_vertices()
cs_lnum_t cs_medcoupling_mesh_get_n_vertices ( cs_medcoupling_mesh_t *  m)
associated number of vertices
◆ cs_medcoupling_mesh_get_vertex_list()
const cs_lnum_t * cs_medcoupling_mesh_get_vertex_list ( cs_medcoupling_mesh_t *  m)
ids of associated vertices, or NULL if all or no local vertices o parent mesh are present.
ids of associated vertices, or null if all or no local vertices of parent mesh are present.
