cs_medcoupling_intersector.h File Reference
#include "fvm/fvm_writer.h"
+ Include dependency graph for cs_medcoupling_intersector.h:
Enumerations
enum  cs_medcpl_intersect_type_t {
  CS_MEDCPL_INTERSECT_SURF , CS_MEDCPL_INTERSECT_VOL , CS_MEDCPL_INTERSECT_VOL_SURF , CS_MEDCPL_N_INTERSECT_TYPES ,
  CS_MEDCPL_INTERSECT_UKNOWN
enum  cs_medcpl_mesh_type_t { CS_MEDCPL_MESH_FROM_FILE , CS_MEDCPL_MESH_FROM_PRIMITIVE , CS_MEDCPL_N_MESH_TYPES , CS_MEDCPL_MESH_UKNOWN }
void cs_medcoupling_intersector_add_vol (const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
 Add a volume MEDCoupling intersector. More...
void cs_medcoupling_intersector_add_surf (const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
 Add a surface MEDCoupling intersector. More...
void cs_medcoupling_intersector_add_vol_surf (const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
 Add a surface in volume MEDCoupling intersector. More...
void cs_medcoupling_intersector_destroy (cs_medcoupling_intersector_t *mi)
 Destroy a given MEDCoupling intersector. More...
void cs_medcoupling_intersector_destroy_all (void)
 Free all allocated intersectors. More...
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_id (int id)
 Get a MEDCoupling intersector using its id. More...
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_name (const char *name)
 Get a MEDCoupling intersector by name. More...
cs_real_t * cs_medcoupling_intersect_volumes (cs_medcoupling_intersector_t *mi)
 Compute the intersection volumes between the source mesh and code mesh. More...
cs_real_t * cs_medcoupling_intersect_surfaces (cs_medcoupling_intersector_t *mi)
 Compute the intersection surfaces between the source mesh and code mesh. More...
cs_real_t * cs_medcoupling_intersect_volume_and_surfaces (cs_medcoupling_intersector_t *mi)
void cs_medcoupling_intersector_translate (cs_medcoupling_intersector_t *mi, cs_real_t translation[3])
 translate the mesh using a given vector More...
void cs_medcoupling_intersector_rotate (cs_medcoupling_intersector_t *mi, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
 rotate the mesh More...
void cs_medcoupling_intersector_scale_auto (cs_medcoupling_intersector_t *mi, cs_real_t factor)
 Scale a mesh using a factor based on the current mesh center position. More...
void cs_medcoupling_intersector_transform_from_init (cs_medcoupling_intersector_t *mi, cs_real_t matrix[3][4])
 Transform a mesh, but takes as input the initial position of the mesh. More...
void cs_medcoupling_intersector_dump_mesh (cs_medcoupling_intersector_t *mi, const char *prefix)
void cs_medcoupling_intersector_print_mesh_info (cs_medcoupling_intersector_t *mi)
 print mesh information to log file. More...
int cs_mi_post_get_writer_id (void)
 Return writer id used for medcoupling meshes, 0 means unused. More...
void cs_mi_post_init_writer (const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int frequency_n, double frequency_t)
 Create a new writer that will contains the boundary MED mesh added. More...
void cs_mi_post_add_mesh (cs_medcoupling_intersector_t *mi)
 Associate a Medcoupling mesh to the default writer. More...
◆ cs_medcpl_intersect_type_t
Enumerator
Surface intersection
Volume intersection
Surface intersecting a volume
Number of intersection options
Uknown flag
◆ cs_medcpl_mesh_type_t
Enumerator
◆ cs_medcoupling_intersect_surfaces()
cs_real_t * cs_medcoupling_intersect_surfaces ( cs_medcoupling_intersector_t *  mi)
[in]mipointer to the cs_medcoupling_intersector_t struct
a pointer to the array containing the intersected volume of each cell
◆ cs_medcoupling_intersect_volume_and_surfaces()
cs_real_t * cs_medcoupling_intersect_volume_and_surfaces ( cs_medcoupling_intersector_t *  mi)
◆ cs_medcoupling_intersect_volumes()
cs_real_t * cs_medcoupling_intersect_volumes ( cs_medcoupling_intersector_t *  mi)
◆ cs_medcoupling_intersector_add_surf()
void cs_medcoupling_intersector_add_surf ( const char *  name,
const char *  medfile_path,
const char *  interp_method,
const char *  select_criteria
[in]namename of the intersector
[in]medfile_pathpath to the MED file
[in]interp_methodinterpolation method (P0P0, P1P0, ..)
[in]select_criteriaselection criteria
◆ cs_medcoupling_intersector_add_vol()
void cs_medcoupling_intersector_add_vol ( const char *  name,
◆ cs_medcoupling_intersector_add_vol_surf()
void cs_medcoupling_intersector_add_vol_surf ( const char *  name,
◆ cs_medcoupling_intersector_by_id()
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_id ( int  id)
[in]idid of the intersector
pointer to the cs_medcoupling_intersector_t or NULL if not found
pointer to the cs_medcoupling_intersector_t or null if not found
◆ cs_medcoupling_intersector_by_name()
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_name ( const char *  name)
◆ cs_medcoupling_intersector_destroy()
void cs_medcoupling_intersector_destroy ( cs_medcoupling_intersector_t *  mi)
◆ cs_medcoupling_intersector_destroy_all()
void cs_medcoupling_intersector_destroy_all ( void  )
◆ cs_medcoupling_intersector_dump_mesh()
void cs_medcoupling_intersector_dump_mesh ( cs_medcoupling_intersector_t *  mi,
const char *  prefix
[in]prefixsubdir prefix
◆ cs_medcoupling_intersector_print_mesh_info()
void cs_medcoupling_intersector_print_mesh_info ( cs_medcoupling_intersector_t *  mi)
◆ cs_medcoupling_intersector_rotate()
void cs_medcoupling_intersector_rotate ( cs_medcoupling_intersector_t *  mi,
cs_real_t  axis[3],
cs_real_t  angle
rotate the mesh
[in]invariantInvariant point
[in]axisRotation axis
[in]angleangle (in radians)
◆ cs_medcoupling_intersector_scale_auto()
void cs_medcoupling_intersector_scale_auto ( cs_medcoupling_intersector_t *  mi,
cs_real_t  factor
[in]factorscaling factor (cs_real_t)
◆ cs_medcoupling_intersector_transform_from_init()
void cs_medcoupling_intersector_transform_from_init ( cs_medcoupling_intersector_t *  mi,
[in]matrixtransformation matrix
Transformation is thus applied on the initial coordiantes and the
mesh is modified accordingly.
◆ cs_medcoupling_intersector_translate()
void cs_medcoupling_intersector_translate ( cs_medcoupling_intersector_t *  mi,
[in]translationtranslation vector
◆ cs_mi_post_add_mesh()
void cs_mi_post_add_mesh ( cs_medcoupling_intersector_t *  mi)
[in]mipointer to the associated MedCoupling intersector structure
◆ cs_mi_post_get_writer_id()
int cs_mi_post_get_writer_id ( void  )
◆ cs_mi_post_init_writer()
void cs_mi_post_init_writer ( const char *  case_name,
const char *  dir_name,
const char *  fmt_name,
const char *  fmt_opts,
bool  output_at_end,
int  frequency_n,
double  frequency_t
by the user. The writer_id is stored locally..
[in]time_dep> 1 if the writer is transient, else writer is fixed
