cs_measures_util.h File Reference
+ Include dependency graph for cs_measures_util.h:
Classes
struct  cs_measures_set_t
struct  cs_interpol_grid_t
void cs_interpol_field_on_grid_deprecated (cs_interpol_grid_t *ig, const cs_real_t *values_to_interpol, cs_real_t *interpoled_values)
void cs_interpol_field_on_grid (cs_interpol_grid_t *ig, const cs_real_t *values_to_interpol, cs_real_t *interpoled_values)
cs_interpol_grid_t * cs_interpol_grid_create (const char *name)
void cs_interpol_grid_init (cs_interpol_grid_t *ig, const cs_lnum_t nb_points, const cs_real_t *coords)
cs_measures_set_t * cs_measures_set_create (const char *name, int type_flag, int dim, bool interleaved)
void cs_measures_set_map_values (cs_measures_set_t *ms, const cs_lnum_t nb_measures, const int *is_cressman, const int *is_interpol, const cs_real_t *measures_coords, const cs_real_t *measures, const cs_real_t *influence_radius)
void cs_measures_set_add_values (cs_measures_set_t *ms, const cs_lnum_t nb_measures, const int *is_cressman, const int *is_interpol, const cs_real_t *measures_coords, const cs_real_t *measures, const cs_real_t *influence_radius)
void cs_cressman_interpol (cs_measures_set_t *ms, cs_real_t *interpolated_values, int id_type)
cs_measures_set_t * cs_measures_set_by_id (int id)
cs_interpol_grid_t * cs_interpol_grid_by_id (int id)
cs_measures_set_t * cs_measures_set_by_name (const char *name)
cs_interpol_grid_t * cs_interpol_grid_by_name (const char *name)
void cs_measures_sets_destroy (void)
void cs_interpol_grids_destroy (void)
◆ cs_cressman_interpol()
void cs_cressman_interpol ( cs_measures_set_t *  ms,
cs_real_t *  interpolated_values,
int  id_type
◆ cs_interpol_field_on_grid()
void cs_interpol_field_on_grid ( cs_interpol_grid_t *  ig,
const cs_real_t *  values_to_interpol,
cs_real_t *  interpoled_values
◆ cs_interpol_field_on_grid_deprecated()
void cs_interpol_field_on_grid_deprecated ( cs_interpol_grid_t *  ig,
◆ cs_interpol_grid_by_id()
cs_interpol_grid_t * cs_interpol_grid_by_id ( int  id)
◆ cs_interpol_grid_by_name()
cs_interpol_grid_t * cs_interpol_grid_by_name ( const char *  name)
◆ cs_interpol_grid_create()
cs_interpol_grid_t * cs_interpol_grid_create ( const char *  name)
◆ cs_interpol_grid_init()
void cs_interpol_grid_init ( cs_interpol_grid_t *  ig,
const cs_real_t *  coords
◆ cs_interpol_grids_destroy()
void cs_interpol_grids_destroy ( void  )
◆ cs_measures_set_add_values()
void cs_measures_set_add_values ( cs_measures_set_t *  ms,
const int *  is_cressman,
const int *  is_interpol,
const cs_real_t *  measures_coords,
const cs_real_t *  measures,
const cs_real_t *  influence_radius
◆ cs_measures_set_by_id()
cs_measures_set_t * cs_measures_set_by_id ( int  id)
◆ cs_measures_set_by_name()
cs_measures_set_t * cs_measures_set_by_name ( const char *  name)
◆ cs_measures_set_create()
cs_measures_set_t * cs_measures_set_create ( const char *  name,
int  type_flag,
int  dim,
bool  interleaved
◆ cs_measures_set_map_values()
void cs_measures_set_map_values ( cs_measures_set_t *  ms,
◆ cs_measures_sets_destroy()
void cs_measures_sets_destroy ( void  )
