cs_matrix.cpp File Reference
Sparse Matrix Representation and Operations. More...
#include <chrono>
#include <stdarg.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "alge/cs_blas.h"
#include "base/cs_dispatch.h"
#include "base/cs_halo.h"
#include "base/cs_halo_perio.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "base/cs_numbering.h"
#include "base/cs_sort.h"
#include "base/cs_timer.h"
#include "alge/cs_matrix.h"
#include "alge/cs_matrix_priv.h"
#include "alge/cs_matrix_spmv.h"
#include "alge/cs_matrix_spmv_cuda.h"
+ Include dependency graph for cs_matrix.cpp:
void cs_matrix_vector_multiply (cs_dispatch_context &ctx, const cs_matrix_t *matrix, cs_real_t x[], cs_real_t y[])
 Matrix.vector product y = A.x. More...
void cs_matrix_vector_multiply_partial (cs_dispatch_context &ctx, const cs_matrix_t *matrix, cs_matrix_spmv_type_t op_type, cs_real_t x[], cs_real_t y[])
 Partial matrix.vector product. More...
cs_matrix_structure_t * cs_matrix_structure_create (cs_matrix_type_t type, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, cs_lnum_t n_edges, const cs_lnum_2_t *restrict edges, const cs_halo_t *halo, const cs_numbering_t *numbering)
 Create a matrix structure. More...
cs_matrix_structure_t * cs_matrix_structure_create_msr (cs_matrix_type_t type, bool transfer, bool have_diag, bool ordered, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, cs_lnum_t **row_index, cs_lnum_t **col_id, const cs_halo_t *halo, const cs_numbering_t *numbering)
 Create a matrix structure based on a MSR connectivity definition. More...
cs_matrix_structure_t * cs_matrix_structure_create_msr_shared (bool direct_assembly, cs_lnum_t n_rows, cs_lnum_t n_cols_ext, const cs_lnum_t *row_index, const cs_lnum_t *col_id, const cs_halo_t *halo, const cs_numbering_t *numbering)
 Create an MSR matrix structure sharing an existing connectivity definition. More...
cs_matrix_structure_t * cs_matrix_structure_create_from_assembler (cs_matrix_type_t type, cs_matrix_assembler_t *ma)
 Create a matrix structure using a matrix assembler. More...
void cs_matrix_structure_destroy (cs_matrix_structure_t **ms)
 Destroy a matrix structure. More...
void cs_matrix_structure_release_msr_arrays (cs_matrix_structure_t *ms, cs_lnum_t **row_index, cs_lnum_t **col_id)
 Release arrays describing an MSR matrix structure. More...
cs_matrix_t * cs_matrix_create (const cs_matrix_structure_t *ms)
 Create a matrix container using a given structure. More...
cs_matrix_t * cs_matrix_create_from_assembler (cs_matrix_type_t type, cs_matrix_assembler_t *ma)
 Create a matrix directly from assembler. More...
cs_matrix_t * cs_matrix_create_by_copy (cs_matrix_t *src)
 Create a matrix container by copying another. More...
cs_matrix_t * cs_matrix_create_by_local_restrict (const cs_matrix_t *src)
 Create a matrix based on the local restriction of a base matrix. More...
void cs_matrix_destroy (cs_matrix_t **matrix)
cs_matrix_type_t cs_matrix_get_type (const cs_matrix_t *matrix)
 Return matrix type. More...
const char * cs_matrix_get_type_name (const cs_matrix_t *matrix)
const char * cs_matrix_get_type_fullname (const cs_matrix_t *matrix)
cs_lnum_t cs_matrix_get_n_columns (const cs_matrix_t *matrix)
 Return number of columns in a matrix. More...
cs_lnum_t cs_matrix_get_n_rows (const cs_matrix_t *matrix)
 Return the number of rows in matrix. More...
cs_lnum_t cs_matrix_get_n_entries (const cs_matrix_t *matrix)
 Return the number of entries in matrix. More...
cs_lnum_t cs_matrix_get_diag_block_size (const cs_matrix_t *matrix)
 Return the size of the diagonal block for the given matrix. More...
cs_lnum_t cs_matrix_get_extra_diag_block_size (const cs_matrix_t *matrix)
 Return the size of the extra-diagonal block for the given matrix. More...
const cs_matrix_assembler_t * cs_matrix_get_assembler (const cs_matrix_t *matrix)
 Return matrix assembler if present. More...
const cs_halo_t * cs_matrix_get_halo (const cs_matrix_t *matrix)
 Return the pointer to the halo structure for the given matrix. More...
const cs_gnum_t * cs_matrix_get_l_range (const cs_matrix_t *matrix)
 Return a pointer to local global row range associated with a matrix, if available. More...
cs_alloc_mode_t cs_matrix_get_alloc_mode (const cs_matrix_t *matrix)
 Query matrix allocation mode. More...
void cs_matrix_set_alloc_mode (cs_matrix_t *matrix, cs_alloc_mode_t alloc_mode)
 Set matrix allocation mode. More...
bool cs_matrix_get_need_xa (const cs_matrix_t *matrix)
void cs_matrix_set_need_xa (cs_matrix_t *matrix, bool need_xa)
 Indicate whether matrix will need xa coefficients. More...
cs_matrix_fill_type_t cs_matrix_get_fill_type (bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
 Get matrix fill type, depending on block sizes. More...
void cs_matrix_set_coefficients (cs_matrix_t *matrix, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_lnum_t n_edges, const cs_lnum_2_t edges[], const cs_real_t *da, const cs_real_t *xa)
 Set matrix coefficients defined relative to a "native" edge graph, sharing arrays with the caller when possible. More...
void cs_matrix_transfer_coefficients (cs_matrix_t *matrix, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_lnum_t n_edges, const cs_lnum_2_t edges[], cs_real_t **d_val, cs_real_t **x_val)
void cs_matrix_transfer_coefficients_msr (cs_matrix_t *matrix, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_lnum_t row_index[], const cs_lnum_t col_id[], cs_real_t **d_val, cs_real_t **x_val)
 Set matrix coefficients in an MSR format, transferring the property of those arrays to the matrix. More...
void cs_matrix_get_coefficients_msr_w (cs_matrix_t *matrix, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, cs_real_t **d_val, cs_real_t **e_val)
 Directly access matrix coefficients in an MSR format for writing. More...
void cs_matrix_release_coefficients (cs_matrix_t *matrix)
 Release shared matrix coefficients. More...
cs_matrix_assembler_values_t * cs_matrix_assembler_values_init (cs_matrix_t *matrix, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
 Create and initialize a CSR matrix assembler values structure. More...
void cs_matrix_copy_diagonal (const cs_matrix_t *matrix, cs_real_t *restrict da)
 Copy matrix diagonal values. More...
bool cs_matrix_is_symmetric (const cs_matrix_t *matrix)
 Query matrix coefficients symmetry. More...
bool cs_matrix_is_mapped_from_native (const cs_matrix_t *matrix)
 Indicate whether coefficients were mapped from native face-based arrays. More...
const cs_real_t * cs_matrix_get_diagonal (const cs_matrix_t *matrix)
 Get matrix diagonal values. More...
const cs_real_t * cs_matrix_get_extra_diagonal (const cs_matrix_t *matrix)
 Get pointer to matrix extra-diagonal values in "native" format. More...
void cs_matrix_row_init (cs_matrix_row_info_t *r)
 Initialize row info for a given matrix. More...
void cs_matrix_row_finalize (cs_matrix_row_info_t *r)
 Finalize row info for a given matrix. More...
void cs_matrix_get_row (const cs_matrix_t *matrix, const cs_lnum_t row_id, cs_matrix_row_info_t *r)
 Get row values for a given matrix. More...
void cs_matrix_get_native_arrays (const cs_matrix_t *matrix, bool *symmetric, cs_lnum_t *n_edges, const cs_lnum_2_t **edges, const cs_real_t **d_val, const cs_real_t **x_val)
 Get arrays describing a matrix in native format. More...
void cs_matrix_get_csr_arrays (const cs_matrix_t *matrix, const cs_lnum_t **row_index, const cs_lnum_t **col_id, const cs_real_t **val)
 Get arrays describing a matrix in CSR format. More...
void cs_matrix_get_msr_arrays (const cs_matrix_t *matrix, const cs_lnum_t **row_index, const cs_lnum_t **col_id, const cs_real_t **d_val, const cs_real_t **x_val)
 Get arrays describing a matrix in MSR format. More...
void cs_matrix_release_msr_arrays (cs_matrix_t *matrix, cs_lnum_t **row_index, cs_lnum_t **col_id, cs_real_t **d_val, cs_real_t **x_val)
 Release arrays describing a matrix in MSR format. More...
void cs_matrix_set_mesh_association (cs_matrix_t *matrix, const cs_lnum_t *c2f_idx, const cs_lnum_t *c2f, const short int *c2f_sgn, const cs_real_3_t *cell_cen, const cs_real_t *cell_vol, const cs_nreal_3_t *face_u_normal, const cs_real_t *face_surf)
 Associate mesh information with a matrix. More...
void cs_matrix_get_mesh_association (const cs_matrix_t *matrix, const cs_lnum_t **c2f_idx, const cs_lnum_t **c2f, const short int **c2f_sgn, const cs_real_3_t **cell_cen, const cs_real_t **cell_vol, const cs_nreal_3_t **face_u_normal, const cs_real_t **face_surf)
 Query mesh information that me be associated with a matrix. More...
void cs_matrix_vector_multiply (const cs_matrix_t *matrix, cs_real_t *restrict x, cs_real_t *restrict y)
void cs_matrix_vector_multiply_nosync (const cs_matrix_t *matrix, cs_real_t *restrict x, cs_real_t *restrict y)
 Matrix.vector product y = A.x with no prior halo update of x. More...
void cs_matrix_vector_multiply_partial (const cs_matrix_t *matrix, cs_matrix_spmv_type_t op_type, cs_real_t *restrict x, cs_real_t *restrict y)
cs_matrix_variant_t * cs_matrix_variant_create (cs_matrix_t *m)
 Build matrix variant. More...
void cs_matrix_variant_build_list (const cs_matrix_t *m, int *n_variants, cs_matrix_variant_t **m_variant)
 Build list of variants for tuning or testing. More...
void cs_matrix_variant_destroy (cs_matrix_variant_t **mv)
 Destroy a matrix variant structure. More...
void cs_matrix_variant_apply (cs_matrix_t *m, cs_matrix_variant_t *mv)
 Apply a variant to a given matrix. More...
void cs_matrix_variant_apply_tuned (cs_matrix_t *m, cs_matrix_variant_t *mv)
 Apply variants defined by tuning to a given matrix. More...
void cs_matrix_variant_set_func (cs_matrix_variant_t *mv, cs_matrix_fill_type_t fill_type, cs_matrix_spmv_type_t spmv_type, const cs_numbering_t *numbering, const char *func_name)
 Select the sparse matrix-vector product function to be used by a matrix variant for a given fill type. More...
cs_matrix_type_t cs_matrix_variant_type (const cs_matrix_variant_t *mv)
 Get the type associated with a matrix variant. More...
Notes:
The aim of these structures and associated functions is multiple:
  • Provide an "opaque" matrix object for linear solvers, allowing possible choice of the matrix type based on run-time tuning at code initialization (depending on matrix size, architecture, and compiler, the most efficient structure for matrix.vector products may vary).
  • Provide at least a CSR matrix structure in addition to the "native" matrix structure, as this may allow us to leverage existing libraries.
  • Provide C interface functions required for interfacing with external libraries.
Choice of a given matrix structure may be strongly related to the choice of linear solver or smoother:
Though many external libraries assume a classical CSR or block-CSR structure, separate storage of diagonal elements (a.k.a. MSR format) is very useful for Jacobi and Gauss-Seidel solvers and Jacobi or polynomial preconditioners, in which the diagonal elements need to be accessed and/or multiplied separately, so we select that approach.
In distributed parallel mode, some matrix entries reference distant rows (and ghost values). For a given local row i and column j, if j > n_local_rows, a_ij references a distant value. For the native (graph edge-based) format, symmetric storage is used, but for other (matrix row-based) formats, only local rows are stored (i.e.* a_ij is not stored if i is not in the local row range), so the matrix storage is locally rectangular, even for a logically square matrix.
An additional optimization (also used in some external libraries) is to store the matrix entries referencing distant rows (and ghost values) separately, to simplify handling of computation-communication overlap. The "distributed" format is thus a variation of the MSR format with separate distant elements.
The specific access requirements of Gauss-Seidel solvers and smoothers lead us to only consider the MSR format for their implementation. When requesting a Gauss-Seidel solver or smoother for another storage format, a Jacobi solver or smoother may be substituted.
Please refer to the matrix section of the theory guide for more informations.
◆ cs_matrix_assembler_values_init()
cs_matrix_assembler_values_t * cs_matrix_assembler_values_init ( cs_matrix_t *  matrix,
The associated matrix's structure must have been created using cs_matrix_structure_create_from_assembler.
[in,out]matrixpointer to matrix structure
[in]diag_block_sizeblock sizes for diagonal
[in]extra_diag_block_sizeblock sizes for extra diagonal
pointer to initialized matrix assembler values structure;
◆ cs_matrix_copy_diagonal()
void cs_matrix_copy_diagonal ( const cs_matrix_t *  matrix,
In case of matrixes with block diagonal coefficients, only the true diagonal values are copied.
[in]matrixpointer to matrix structure
[out]dadiagonal (pre-allocated, size: n_rows*block_size)
◆ cs_matrix_create()
cs_matrix_t * cs_matrix_create ( const cs_matrix_structure_t *  ms)
Note that the matrix container maps to the assigned structure, so it must be destroyed before that structure.
[in]msassociated matrix structure
pointer to created matrix structure;
◆ cs_matrix_create_by_copy()
cs_matrix_t * cs_matrix_create_by_copy ( cs_matrix_t *  src)
If assigned, coefficients are not copied.
[in]srcreference matrix structure
◆ cs_matrix_create_by_local_restrict()
cs_matrix_t * cs_matrix_create_by_local_restrict ( const cs_matrix_t *  src)
Coefficients are copied. Some coefficients may be shared with the parent matrix, so the base matrix must not be destroyed before the restriction matrix.
◆ cs_matrix_create_from_assembler()
cs_matrix_t * cs_matrix_create_from_assembler ( cs_matrix_type_t  type,
cs_matrix_assembler_t *  ma
Only CSR and MSR formats are handled.
[in]typetype of matrix considered
[in]mapointer to matrix assembler structure
a pointer to a created matrix structure
◆ cs_matrix_destroy()
void cs_matrix_destroy ( cs_matrix_t **  matrix)
◆ cs_matrix_get_alloc_mode()
cs_alloc_mode_t cs_matrix_get_alloc_mode ( const cs_matrix_t *  matrix)
host/device allocation mode
◆ cs_matrix_get_assembler()
const cs_matrix_assembler_t * cs_matrix_get_assembler ( const cs_matrix_t *  matrix)
◆ cs_matrix_get_coefficients_msr_w()
void cs_matrix_get_coefficients_msr_w ( cs_matrix_t *  matrix,
bool  symmetric,
cs_real_t **  d_val,
cs_real_t **  e_val
The matrix's fill type is also set by this function.
The associated matrix must be in MSR format, and the associated row index and column ids known.
[in]symmetricindicates if matrix coefficients are symmetric
[in,out]d_valdiagonal values (nullptr if zero)
[in,out]e_valextradiagonal values (nullptr if zero)
◆ cs_matrix_get_csr_arrays()
void cs_matrix_get_csr_arrays ( const cs_matrix_t *  matrix,
const cs_lnum_t **  row_index,
const cs_lnum_t **  col_id,
const cs_real_t **  val
This function only works for an CSR matrix (i.e. there is no automatic conversion from another matrix type).
Matrix block sizes can be obtained by cs_matrix_get_diag_block_size() and cs_matrix_get_extra_diag_block_size().
[out]row_indexCSR row index
[out]col_idCSR column id
[out]valvalues
◆ cs_matrix_get_diag_block_size()
cs_lnum_t cs_matrix_get_diag_block_size ( const cs_matrix_t *  matrix)
the of the diagonal block
◆ cs_matrix_get_diagonal()
const cs_real_t * cs_matrix_get_diagonal ( const cs_matrix_t *  matrix)
In case of matrixes with block diagonal coefficients, a pointer to the complete block diagonal is returned.
pointer to matrix diagonal array
◆ cs_matrix_get_extra_diag_block_size()
cs_lnum_t cs_matrix_get_extra_diag_block_size ( const cs_matrix_t *  matrix)
◆ cs_matrix_get_extra_diagonal()
const cs_real_t * cs_matrix_get_extra_diagonal ( const cs_matrix_t *  matrix)
Deprecated:
This function only functions if the coefficients were mapped from native coefficients using cs_matrix_set_coefficients(), in which case the pointer returned is the same as the one passed to that function.
It is used in the current multigrid code, but should be removed as soon as the dependency to the native format is removed.
◆ cs_matrix_get_fill_type()
cs_matrix_fill_type_t cs_matrix_get_fill_type ( bool  symmetric,
matrix fill type
◆ cs_matrix_get_halo()
const cs_halo_t * cs_matrix_get_halo ( const cs_matrix_t *  matrix)
pointer to the associated halo structure
◆ cs_matrix_get_l_range()
const cs_gnum_t * cs_matrix_get_l_range ( const cs_matrix_t *  matrix)
pointer to local range, or nullptr
◆ cs_matrix_get_mesh_association()
void cs_matrix_get_mesh_association ( const cs_matrix_t *  matrix,
const cs_lnum_t **  c2f_idx,
const cs_lnum_t **  c2f,
const short int **  c2f_sgn,
const cs_real_3_t **  cell_cen,
const cs_real_t **  cell_vol,
const cs_nreal_3_t **  face_u_normal,
const cs_real_t **  face_surf
This may be useful for multigrid smoothing.
[out]c2f_idxcell to faces index, or nullptr
[out]c2fcell to faces adjacency, or nullptr
[out]c2f_sgncell to faces adjacency sign, or nullptr
[out]cell_cencell center coordinates, or nullptr
[out]cell_volcell volumes, or nullptr
[out]face_u_normalface unit normal, or nullptr
[out]face_surfface surface, or nullptr
◆ cs_matrix_get_msr_arrays()
void cs_matrix_get_msr_arrays ( const cs_matrix_t *  matrix,
const cs_real_t **  d_val,
const cs_real_t **  x_val
This function only works for an MSR matrix (i.e. there is no automatic conversion from another matrix type).
[out]row_indexMSR row index
[out]col_idMSR column id
[out]d_valdiagonal values
[out]x_valextra-diagonal values
◆ cs_matrix_get_n_columns()
cs_lnum_t cs_matrix_get_n_columns ( const cs_matrix_t *  matrix)
the number of columns
◆ cs_matrix_get_n_entries()
cs_lnum_t cs_matrix_get_n_entries ( const cs_matrix_t *  matrix)
When the block size is > 1, the number reported is the number of entry blocks, not individual entries.
◆ cs_matrix_get_n_rows()
cs_lnum_t cs_matrix_get_n_rows ( const cs_matrix_t *  matrix)
the number of rows
◆ cs_matrix_get_native_arrays()
void cs_matrix_get_native_arrays ( const cs_matrix_t *  matrix,
bool *  symmetric,
cs_lnum_t *  n_edges,
const cs_lnum_2_t **  edges,
This function works for matrix in native format.
[out]symmetrictrue if symmetric
[out]n_edgesnumber of associated faces
[out]edgesedges (symmetric row <-> column) connectivity
◆ cs_matrix_get_need_xa()
bool cs_matrix_get_need_xa ( const cs_matrix_t *  matrix)
◆ cs_matrix_get_row()
void cs_matrix_get_row ( const cs_matrix_t *  matrix,
cs_matrix_row_info_t *  r
This function may not work for all matrix types.
In the case of blocked matrices, the true (non-blocked) values are returned.
The row information structure must have been previously initialized using cs_matrix_row_init, and should be finalized using using cs_matrix_row_finalize, so as to free buffers it may have built for certain matrix formats.
[in]row_idid of row to query
[in,out]rrow info structure
◆ cs_matrix_get_type()
cs_matrix_type_t cs_matrix_get_type ( const cs_matrix_t *  matrix)
Return matrix type.
◆ cs_matrix_get_type_fullname()
const char * cs_matrix_get_type_fullname ( const cs_matrix_t *  matrix)
◆ cs_matrix_get_type_name()
const char * cs_matrix_get_type_name ( const cs_matrix_t *  matrix)
◆ cs_matrix_is_mapped_from_native()
bool cs_matrix_is_mapped_from_native ( const cs_matrix_t *  matrix)
It is used in the current multgrid code, but should be removed as soon as the dependency to the native format is removed.
true if coefficients were mapped from native face-based arrays, false otherwise
◆ cs_matrix_is_symmetric()
bool cs_matrix_is_symmetric ( const cs_matrix_t *  matrix)
true if coefficients are symmetric, false otherwise
◆ cs_matrix_release_coefficients()
void cs_matrix_release_coefficients ( cs_matrix_t *  matrix)
Pointers to mapped coefficients are set to nullptr, while coefficient copies owned by the matrix are not modified.
This simply ensures the matrix does not maintain pointers to nonexistant data.
◆ cs_matrix_release_msr_arrays()
void cs_matrix_release_msr_arrays ( cs_matrix_t *  matrix,
cs_real_t **  d_val,
cs_real_t **  x_val
Ownership is provided back to the caller, if pointers are provided. If the matrix does not own a given array, a nullptr value is returned for that array.
[out]row_indexMSR row index, or null
[out]col_idMSR column id, or null
[out]d_valdiagonal values, or null
[out]x_valextra-diagonal values, or null
◆ cs_matrix_row_finalize()
void cs_matrix_row_finalize ( cs_matrix_row_info_t *  r)
◆ cs_matrix_row_init()
void cs_matrix_row_init ( cs_matrix_row_info_t *  r)
[out]rrow info structure
◆ cs_matrix_set_alloc_mode()
void cs_matrix_set_alloc_mode ( cs_matrix_t *  matrix,
When coefficients are already present, their allocation mode will be changed only when owned directly by this matrix, not shared with another. Also, a matrix's allocation mode should ne be changed if some of its coefficients are already shared by another.
[in]alloc_modehost/device allocation mode
◆ cs_matrix_set_coefficients()
void cs_matrix_set_coefficients ( cs_matrix_t *  matrix,
bool  symmetric,
const cs_real_t *  da,
const cs_real_t *  xa
With shared arrays, the matrix becomes unusable if the arrays passed as arguments are not be modified (its coefficients should be unset first to mark this).
Depending on current options and initialization, values will be copied or simply mapped.
[in]n_edgeslocal number of graph edges
[in]edgesedges (row <-> column) connectivity
[in]dadiagonal values (nullptr if zero)
[in]xaextradiagonal values (nullptr if zero) casts as: xa[n_edges] if symmetric, xa[n_edges][2] if non symmetric
◆ cs_matrix_set_mesh_association()
void cs_matrix_set_mesh_association ( cs_matrix_t *  matrix,
const cs_lnum_t *  c2f_idx,
const cs_lnum_t *  c2f,
const short int *  c2f_sgn,
const cs_real_3_t *  cell_cen,
const cs_real_t *  cell_vol,
const cs_nreal_3_t *  face_u_normal,
const cs_real_t *  face_surf
At least cell centers and volumes are needed for relaxation, and face adjacency and normals are needed for the "classical" option.
Note that cells and faces here do not need to be primary mesh elements, but could be dual mesh elements of some sort.
The arrays passed to the matrix are shared, so should have a lifetime at least as long as the matrix.
[in]c2f_idxcell to faces index, or nullptr
[in]c2fcell to faces adjacency, or nullptr
[in]c2f_sgncell to faces adjacency sign, or nullptr
[in]cell_cencell center coordinates
[in]cell_volcell volumes
[in]face_u_normalface unit normal, or nullptr
[in]face_surfface surface, or nullptr
◆ cs_matrix_set_need_xa()
void cs_matrix_set_need_xa ( cs_matrix_t *  matrix,
bool  need_xa
[in]need_xais thr face-based xa array needed ?
◆ cs_matrix_structure_create()
cs_matrix_structure_t * cs_matrix_structure_create ( cs_matrix_type_t  type,
cs_lnum_t  n_rows,
cs_lnum_t  n_edges,
const cs_halo_t *  halo,
const cs_numbering_t *  numbering
Note that the structure created usually maps to the given existing cell global number, face -> cell connectivity arrays, and cell halo structure, so it must be destroyed before they are freed (usually along with the code's main face -> cell structure).
Note that the resulting matrix structure will contain a full main main diagonal, and that the extra-diagonal structure is always symmetric (though the coefficients my not be, and we may choose a matrix format that does not exploit this symmetry). If the edges connectivity argument is nullptr, the matrix will be purely diagonal.
[in]n_rowslocal number of rows
[in]n_cols_extnumber of local + ghost columns
[in]n_edgeslocal number of (undirected) graph edges
[in]edgesedges (symmetric row <-> column) connectivity
[in]halohalo structure associated with cells, or nullptr
[in]numberingvectorization or thread-related numbering info, or nullptr
◆ cs_matrix_structure_create_from_assembler()
cs_matrix_structure_t * cs_matrix_structure_create_from_assembler ( cs_matrix_type_t  type,
◆ cs_matrix_structure_create_msr()
cs_matrix_structure_t * cs_matrix_structure_create_msr ( cs_matrix_type_t  type,
bool  transfer,
bool  have_diag,
bool  ordered,
cs_lnum_t  n_rows,
col_id is sorted row by row during the creation of this structure.
In case the property of the row index and col_id arrays are transferred to the structure, the arrays pointers passed as arguments are set to nullptr, to help ensure the caller does not use the original arrays directly after this call.
[in]transfertransfer property of row_index and col_id if true, map them otherwise
[in]have_diagindicates if the structure includes the diagonal (should be the same for all rows)
[in]orderedindicates if column ids are already ordered
[in]n_cols_extlocal number of columns + ghosts
[in]row_indexpointer to index on rows
[in,out]col_idpointer to array of column ids related to the row index
[in]halohalo structure for synchronization, or nullptr
◆ cs_matrix_structure_create_msr_shared()
cs_matrix_structure_t * cs_matrix_structure_create_msr_shared ( bool  direct_assembly,
cs_lnum_t  n_rows,
const cs_lnum_t *  row_index,
const cs_lnum_t *  col_id,
Note that as the structure created maps to the given existing cell global number, face -> cell connectivity arrays, and cell halo structure, it must be destroyed before they are freed (usually along with the code's main face -> cell structure).
[in]direct_assemblytrue if each value corresponds to a unique face
[in]row_indexindex on rows
[in]col_idarray of column ids related to the row index
◆ cs_matrix_structure_destroy()
void cs_matrix_structure_destroy ( cs_matrix_structure_t **  ms)
[in,out]mspointer to matrix structure pointer
◆ cs_matrix_structure_release_msr_arrays()
void cs_matrix_structure_release_msr_arrays ( cs_matrix_structure_t *  ms,
cs_lnum_t **  col_id
◆ cs_matrix_transfer_coefficients()
void cs_matrix_transfer_coefficients ( cs_matrix_t *  matrix,
bool  symmetric,
cs_real_t **  d_val,
cs_real_t **  x_val
◆ cs_matrix_transfer_coefficients_msr()
void cs_matrix_transfer_coefficients_msr ( cs_matrix_t *  matrix,
bool  symmetric,
cs_real_t **  d_val,
cs_real_t **  x_val
If the matrix is also in MSR format, this avoids an extra copy. If it is in a different format, values are copied to the structure, and the original arrays freed. In any case, the arrays pointers passed as arguments are set to nullptr, to help ensure the caller does not use the original arrays directly after this call.
[in]row_indexMSR row index (0 to n-1)
[in]col_idMSR column id (0 to n-1)
[in,out]x_valextradiagonal values (nullptr if zero)
◆ cs_matrix_variant_apply()
void cs_matrix_variant_apply ( cs_matrix_t *  m,
cs_matrix_variant_t *  mv
[in,out]mpointer to matrix
[in]mvpointer to matrix variant pointer
◆ cs_matrix_variant_apply_tuned()
void cs_matrix_variant_apply_tuned ( cs_matrix_t *  m,
◆ cs_matrix_variant_build_list()
void cs_matrix_variant_build_list ( const cs_matrix_t *  m,
int *  n_variants,
cs_matrix_variant_t **  m_variant
The matrix coefficients should be assigned, so the fill type can be determined.
[in]massociated matrix
[out]n_variantsnumber of variants
[out]m_variantarray of matrix variants
◆ cs_matrix_variant_create()
cs_matrix_variant_t * cs_matrix_variant_create ( cs_matrix_t *  m)
The variant will initially use default matrix-vector functions, which can be later modified using cs_matrix_variant_set_func().
[in]mpointer to matrix
◆ cs_matrix_variant_destroy()
void cs_matrix_variant_destroy ( cs_matrix_variant_t **  mv)
[in,out]mvpointer to matrix variant pointer
◆ cs_matrix_variant_set_func()
void cs_matrix_variant_set_func ( cs_matrix_variant_t *  mv,
const cs_numbering_t *  numbering,
const char *  func_name
Currently, possible variant functions are:
CS_MATRIX_NATIVE (all fill types) default baseline omp (for OpenMP with compatible numbering) omp_atomic (for OpenMP with atomics) vector (For vector machine with compatible numbering)
CS_MATRIX_CSR (for CS_MATRIX_SCALAR or CS_MATRIX_SCALAR_SYM) default mkl (with MKL)
CS_MATRIX_MSR (all fill types) default mkl (with MKL, for CS_MATRIX_SCALAR or CS_MATRIX_SCALAR_SYM) omp_sched (For OpenMP with scheduling)
parameters: mv <-> pointer to matrix variant numbering <– mesh numbering info, or nullptr fill type <– matrix fill type to merge from spmv_type <– SpMV operation type (full or sub-matrix) (all types if CS_MATRIX_SPMV_N_TYPES) func_name <– function type name
◆ cs_matrix_variant_type()
cs_matrix_type_t cs_matrix_variant_type ( const cs_matrix_variant_t *  mv)
[in]mvpointer to matrix variant structure
the type of matrix
◆ cs_matrix_vector_multiply() [1/2]
void cs_matrix_vector_multiply ( const cs_matrix_t *  matrix,
This function includes a halo update of x prior to multiplication by A.
[in,out]xmultiplying vector values (ghost values updated)
[out]yresulting vector
◆ cs_matrix_vector_multiply() [2/2]
void cs_matrix_vector_multiply ( cs_dispatch_context &  ctx,
cs_real_t  x[],
cs_real_t  y[]
[in,out]ctxreference to dispatch context
◆ cs_matrix_vector_multiply_nosync()
void cs_matrix_vector_multiply_nosync ( const cs_matrix_t *  matrix,
This function does not include a halo update of x prior to multiplication by A, so it should be called only when the halo of x is known to already be up to date (in which case we avoid the performance penalty of a redundant update by using this variant of the matrix.vector product).
[in]xmultiplying vector values
◆ cs_matrix_vector_multiply_partial() [1/2]
void cs_matrix_vector_multiply_partial ( const cs_matrix_t *  matrix,
This function includes a halo update of x prior to multiplication, except for the CS_MATRIX_SPMV_L operation type, which does not require it, as halo adjacencies are only present and useful in the upper-diagonal part..
[in]op_typeSpMV operation type
◆ cs_matrix_vector_multiply_partial() [2/2]
void cs_matrix_vector_multiply_partial ( cs_dispatch_context &  ctx,
cs_real_t  x[],
cs_real_t  y[]
