cs_les_balance.h File Reference
#include "base/cs_base.h"
+ Include dependency graph for cs_les_balance.h:
Classes
struct  cs_les_balance_rij_t
 Reynolds tensor (Rij) LES balance descriptor. More...
struct  cs_les_balance_tui_t
 Turbulent thermal flux vector (Tui) LES balance descriptor. More...
 LES balance general options descriptor. More...
Macros
#define CS_LES_BALANCE_RIJ   (1 << 0)
#define CS_LES_BALANCE_RIJ_BASE   (1 << 1)
#define CS_LES_BALANCE_RIJ_FULL   (1 << 2)
#define CS_LES_BALANCE_TUI   (1 << 3)
#define CS_LES_BALANCE_TUI_BASE   (1 << 4)
#define CS_LES_BALANCE_TUI_FULL   (1 << 5)
void cs_les_balance_create_fields (void)
cs_les_balance_t * cs_get_glob_les_balance (void)
 Provide access to cs_glob_les_balance. More...
void cs_les_balance_create (void)
 Create a LES balance descriptor. More...
void cs_les_balance_update_gradients (void)
 Update gradients needed in LES balance. More...
void cs_les_balance_compute_rij (void)
 Compute Rij LES balance. More...
void cs_les_balance_compute_tui (void)
 Compute Tui LES balance. More...
void cs_les_balance_write_restart (void)
 Write the LES balance structure in the LES balance restart file. More...
void cs_les_balance_finalize (void)
 Destroy the LES balance structure. More...
void cs_les_balance_activate (int type_flag, int frequency_n)
 Active the LES balance module. More...
void cs_les_balance_compute (void)
 Compute the LES balance for Tui or Rij. More...
cs_les_balance_t * cs_glob_les_balance
◆ CS_LES_BALANCE_RIJ
Active LES Rij balance
◆ CS_LES_BALANCE_RIJ_BASE
basic LES Rij balance
◆ CS_LES_BALANCE_RIJ_FULL
full LES Rij balance
◆ CS_LES_BALANCE_TUI
Active LES Tui balance
◆ CS_LES_BALANCE_TUI_BASE
basic LES Tui balance
◆ CS_LES_BALANCE_TUI_FULL
full LES Tui balance
◆ cs_get_glob_les_balance()
cs_les_balance_t * cs_get_glob_les_balance ( void  )
pointer to LES balance global structure
◆ cs_les_balance_activate()
void cs_les_balance_activate ( int  type_flag,
int  frequency_n
[in]type_flagmask of LES balance type
[in]frequency_nbalance computing frequency in time-steps
◆ cs_les_balance_compute()
void cs_les_balance_compute ( void  )
◆ cs_les_balance_compute_rij()
void cs_les_balance_compute_rij ( void  )
◆ cs_les_balance_compute_tui()
void cs_les_balance_compute_tui ( void  )
◆ cs_les_balance_create()
void cs_les_balance_create ( void  )
◆ cs_les_balance_create_fields()
void cs_les_balance_create_fields ( void  )
◆ cs_les_balance_finalize()
void cs_les_balance_finalize ( void  )
◆ cs_les_balance_update_gradients()
void cs_les_balance_update_gradients ( void  )
◆ cs_les_balance_write_restart()
void cs_les_balance_write_restart ( void  )
◆ cs_glob_les_balance
cs_les_balance_t* cs_glob_les_balance
extern
