cs_les_balance.cpp File Reference
#include <stddef.h>
#include <ctype.h>
#include <float.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "base/cs_base.h"
#include "base/cs_file.h"
#include "mesh/cs_mesh.h"
#include "base/cs_boundary_conditions_set_coeffs.h"
#include "alge/cs_divergence.h"
#include "alge/cs_face_viscosity.h"
#include "alge/cs_convection_diffusion.h"
#include "base/cs_field.h"
#include "base/cs_mem.h"
#include "mesh/cs_geom.h"
#include "alge/cs_gradient.h"
#include "base/cs_halo.h"
#include "base/cs_math.h"
#include "base/cs_parall.h"
#include "base/cs_physical_properties.h"
#include "base/cs_restart.h"
#include "base/cs_time_moment.h"
#include "turb/cs_les_balance.h"
+ Include dependency graph for cs_les_balance.cpp:
void cs_les_balance_create_fields (void)
cs_les_balance_t * cs_get_glob_les_balance (void)
 Provide access to cs_glob_les_balance. More...
void cs_les_balance_create (void)
 Create a LES balance descriptor. More...
void cs_les_balance_update_gradients (void)
 Update gradients needed in LES balance. More...
void cs_les_balance_compute_rij (void)
 Compute Rij LES balance. More...
void cs_les_balance_compute_tui (void)
 Compute Tui LES balance. More...
void cs_les_balance_write_restart (void)
 Write the LES balance structure in the LES balance restart file. More...
void cs_les_balance_finalize (void)
 Destroy the LES balance structure. More...
void cs_les_balance_activate (int type_flag, int frequency_n)
 Active the LES balance module. More...
void cs_les_balance_compute (void)
 Compute the LES balance for Tui or Rij. More...
cs_les_balance_t * cs_glob_les_balance = &_les_balance
LES balance computation and related data.
◆ cs_get_glob_les_balance()
cs_les_balance_t * cs_get_glob_les_balance ( void  )
pointer to LES balance global structure
◆ cs_les_balance_activate()
void cs_les_balance_activate ( int  type_flag,
int  frequency_n
[in]type_flagmask of LES balance type
[in]frequency_nbalance computing frequency in time-steps
◆ cs_les_balance_compute()
void cs_les_balance_compute ( void  )
◆ cs_les_balance_compute_rij()
void cs_les_balance_compute_rij ( void  )
◆ cs_les_balance_compute_tui()
void cs_les_balance_compute_tui ( void  )
◆ cs_les_balance_create()
void cs_les_balance_create ( void  )
◆ cs_les_balance_create_fields()
void cs_les_balance_create_fields ( void  )
◆ cs_les_balance_finalize()
void cs_les_balance_finalize ( void  )
◆ cs_les_balance_update_gradients()
void cs_les_balance_update_gradients ( void  )
◆ cs_les_balance_write_restart()
void cs_les_balance_write_restart ( void  )
◆ cs_glob_les_balance
cs_les_balance_t* cs_glob_les_balance = &_les_balance
