cs_lagr_particle.cpp File Reference
#include <limits.h>
#include <stddef.h>
#include <ctype.h>
#include <float.h>
#include "bft/bft_printf.h"
#include "bft/bft_error.h"
#include "fvm/fvm_periodicity.h"
#include "base/cs_base.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_order.h"
#include "base/cs_parall.h"
#include "base/cs_random.h"
#include "base/cs_timer_stats.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_post.h"
#include "lagr/cs_lagr_clogging.h"
#include "lagr/cs_lagr_roughness.h"
#include "lagr/cs_lagr_dlvo.h"
#include "lagr/cs_lagr_particle.h"
+ Include dependency graph for cs_lagr_particle.cpp:
void cs_lagr_particle_attr_initialize (void)
 Define particle map based on defined options. More...
const cs_lagr_attribute_map_t * cs_lagr_particle_get_attr_map (void)
 Return const pointer to the main particle attribute map structure. More...
void cs_lagr_particle_set_create (void)
void cs_lagr_particle_finalize (void)
 Destroy main particle set and map if they exist. More...
void cs_lagr_part_copy (cs_lnum_t dest, cs_lnum_t src)
 Copy attributes from one particle to another. More...
void cs_lagr_get_attr_info (const cs_lagr_particle_set_t *particles, int time_id, cs_lagr_attribute_t attr, size_t *extents, size_t *size, ptrdiff_t *displ, cs_datatype_t *datatype, int *count)
 Get data extents for a given particle attribute. More...
int cs_lagr_check_attr_query (const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id)
 Check that query for a given particle attribute is valid. More...
void cs_lagr_particle_attr_in_range (int attr)
 Check if a particle attribute is in a valid range. More...
cs_lagr_particle_set_t * cs_lagr_get_particle_set (void)
 Return pointer to the main cs_lagr_particle_set_t structure. More...
int cs_lagr_particle_set_resize (cs_lnum_t n_min_particles)
 Resize particle set buffers if needed. More...
void cs_lagr_set_reallocation_factor (double f)
 Set reallocation factor for particle sets. More...
unsigned long long cs_lagr_get_n_g_particles_max (void)
 Get global maximum number of particles. More...
void cs_lagr_set_n_g_particles_max (unsigned long long n_g_particles_max)
 Set global maximum number of particles. More...
void cs_lagr_particles_current_to_previous (cs_lagr_particle_set_t *particles, cs_lnum_t particle_id)
 Copy current attributes to previous attributes. More...
void cs_lagr_particle_set_dump (const cs_lagr_particle_set_t *particles)
 Dump a cs_lagr_particle_set_t structure. More...
void cs_lagr_set_n_user_variables (int n_user_variables)
 Set number of user particle variables. More...
Particle structure.
◆ cs_lagr_check_attr_query()
int cs_lagr_check_attr_query ( const cs_lagr_particle_set_t *  particles,
int  stride,
int  component_id
[in]particlesassociated particle set
[in]attrattribute whose values are required
[in]datatypeassociated value type
[in]stridenumber of values per particle
[in]component_idif -1 : extract the whole attribute if >0 : id of the component to extract
0 in case of success, 1 in case of error
◆ cs_lagr_get_attr_info()
void cs_lagr_get_attr_info ( const cs_lagr_particle_set_t *  particles,
int  time_id,
size_t *  extents,
size_t *  size,
ptrdiff_t *  displ,
cs_datatype_t *  datatype,
int *  count
For attributes not currently present, the displacement and data size should be -1 and 0 respectively.
[in]time_idassociated time id (0: current, 1: previous)
[in]attrparticle attribute
[out]extentssize (in bytes) of particle structure, or nullptr
[out]sizesize (in bytes) of attribute in particle structure, or nullptr
[out]displdisplacement (in bytes) in particle structure, or nullptr
[out]datatypedatatype of associated attribute, or nullptr
[out]countnumber of type values associated with attribute, or nullptr
◆ cs_lagr_get_n_g_particles_max()
unsigned long long cs_lagr_get_n_g_particles_max ( void  )
By default, the number is limited only by local cs_lnum_t and global cs_gnum_t data representation limits.
◆ cs_lagr_get_particle_set()
cs_lagr_particle_set_t * cs_lagr_get_particle_set ( void  )
pointer to current particle set, or nullptr
◆ cs_lagr_part_copy()
void cs_lagr_part_copy ( cs_lnum_t  dest,
cs_lnum_t  src
The random value associated with the particle is modified.
destid (0-based) of destination particle
srcid (0-based) of source particle
◆ cs_lagr_particle_attr_in_range()
void cs_lagr_particle_attr_in_range ( int  attr)
If this is not the case, a fatal error is provoked.
◆ cs_lagr_particle_attr_initialize()
void cs_lagr_particle_attr_initialize ( void  )
◆ cs_lagr_particle_finalize()
void cs_lagr_particle_finalize ( void  )
◆ cs_lagr_particle_get_attr_map()
const cs_lagr_attribute_map_t * cs_lagr_particle_get_attr_map ( void  )
pointer to current particle attribute map, or nullptr
◆ cs_lagr_particle_set_create()
void cs_lagr_particle_set_create ( void  )
Allocate main cs_lagr_particle_set_t structure.
◆ cs_lagr_particle_set_dump()
void cs_lagr_particle_set_dump ( const cs_lagr_particle_set_t *  particles)
[in]particlescs_lagr_particle_t structure to dump
◆ cs_lagr_particle_set_resize()
int cs_lagr_particle_set_resize ( cs_lnum_t  n_min_particles)
By default, the total number of particles is not limited. A global limit may be set using cs_lagr_set_n_g_particles_max.
[in]n_min_particlesminimum number of particles required
1 if resizing was required, -1 if the global minimum number of particles would exceed the global limit, 0 otherwise.
◆ cs_lagr_particles_current_to_previous()
void cs_lagr_particles_current_to_previous ( cs_lagr_particle_set_t *  particles,
[in,out]particlesassociated particle set
[in]particle_idid of particle
◆ cs_lagr_set_n_g_particles_max()
void cs_lagr_set_n_g_particles_max ( unsigned long long  n_g_particles_max)
[in]n_g_particles_maxglobal maximum number of particles
◆ cs_lagr_set_n_user_variables()
void cs_lagr_set_n_user_variables ( int  n_user_variables)
[in]n_user_variablesnumber of user variables
◆ cs_lagr_set_reallocation_factor()
void cs_lagr_set_reallocation_factor ( double  f)
This factor determines the multiplier used for reallocations when the particle set's buffers are too small to handle the new number of particles.
[in]freallocation size multiplier
