cs_lagr_log.cpp File Reference
#include <limits.h>
#include <stddef.h>
#include <ctype.h>
#include <float.h>
#include "bft/bft_printf.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_field.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_particle.h"
#include "lagr/cs_lagr_tracking.h"
#include "lagr/cs_lagr_post.h"
#include "lagr/cs_lagr_stat.h"
#include "lagr/cs_lagr_prototypes.h"
#include "lagr/cs_lagr_log.h"
+ Include dependency graph for cs_lagr_log.cpp:
static const char * _status (int i)
 Return string indicating on/off depending on integer value. More...
static const char * _status_b (bool i)
 Return string indicating on/off depending on boolean value. More...
static void _lagr_min_max_boundary_stats (int s_id, cs_lnum_t *nbrfac, cs_real_t *gmin, cs_real_t *gmax)
 Computes min/max for boundary statistics. More...
static void _log_setup_injection (cs_log_t log)
 Log Lagrangian module injection info. More...
void cs_lagr_log_setup (void)
 Log Lagrangian module output in the setup file. More...
void cs_lagr_log_iteration (void)
 Log Lagrangian module output in the main log file. More...
◆ _lagr_min_max_boundary_stats()
static void _lagr_min_max_boundary_stats ( int  s_id,
cs_lnum_t *  nbrfac,
cs_real_t *  gmin,
cs_real_t *  gmax
static
Parameters:
[in]s_idstat id
[out]nbrfacnumber of particles used for the statistics
[out]gminmin value
[out]gmaxmax value
◆ _log_setup_injection()
static void _log_setup_injection ( cs_log_t  log)
static
[in]logassociated log file
◆ _status()
static const char * _status ( int  i)
static
iinput integer
status string, possibly translated
◆ _status_b()
static const char * _status_b ( bool  i)
static
binput bool
◆ cs_lagr_log_iteration()
void cs_lagr_log_iteration ( void  )
◆ cs_lagr_log_setup()
void cs_lagr_log_setup ( void  )
