cs_join_post.cpp File Reference
#include "bft/bft_error.h"
#include "fvm/fvm_nodal.h"
#include "fvm/fvm_nodal_order.h"
#include "fvm/fvm_nodal_from_desc.h"
#include "fvm/fvm_writer.h"
#include "base/cs_file.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh_connect.h"
#include "base/cs_post.h"
#include "base/cs_timer_stats.h"
#include "mesh/cs_join_post.h"
+ Include dependency graph for cs_join_post.cpp:
void cs_join_post_init (void)
void cs_join_post_mesh (const char *mesh_name, const cs_join_mesh_t *join_mesh)
void cs_join_post_faces_subset (const char *mesh_name, const cs_join_mesh_t *parent_mesh, cs_lnum_t n_select_faces, const cs_lnum_t selected_faces[])
void cs_join_post_after_merge (cs_join_param_t join_param, const cs_join_select_t *join_select)
void cs_join_post_after_split (cs_lnum_t n_old_i_faces, cs_lnum_t n_old_b_faces, cs_gnum_t n_g_new_b_faces, cs_lnum_t n_select_faces, const cs_mesh_t *mesh, cs_join_param_t join_param)
void cs_join_post_cleaned_faces (cs_lnum_t n_i_clean_faces, cs_lnum_t i_clean_faces[], cs_lnum_t n_b_clean_faces, cs_lnum_t b_clean_faces[], cs_join_param_t param)
void cs_join_post_dump_mesh (const char *basename, const cs_join_mesh_t *mesh, cs_join_param_t param)
◆ cs_join_post_after_merge()
void cs_join_post_after_merge ( cs_join_param_t  join_param,
const cs_join_select_t *  join_select
◆ cs_join_post_after_split()
void cs_join_post_after_split ( cs_lnum_t  n_old_i_faces,
const cs_mesh_t *  mesh,
◆ cs_join_post_cleaned_faces()
void cs_join_post_cleaned_faces ( cs_lnum_t  n_i_clean_faces,
◆ cs_join_post_dump_mesh()
void cs_join_post_dump_mesh ( const char *  basename,
const cs_join_mesh_t *  mesh,
◆ cs_join_post_faces_subset()
void cs_join_post_faces_subset ( const char *  mesh_name,
const cs_join_mesh_t *  parent_mesh,
◆ cs_join_post_init()
void cs_join_post_init ( void  )
◆ cs_join_post_mesh()
void cs_join_post_mesh ( const char *  mesh_name,
const cs_join_mesh_t *  join_mesh
