cs_io.h File Reference
#include "base/cs_base.h"
#include "base/cs_file.h"
+ Include dependency graph for cs_io.h:
Classes
struct  cs_io_sec_header_t
Macros
#define CS_IO_NAME_LEN   32 /* Section header name length */
#define CS_IO_ECHO_NONE   -2 /* No verbosity at all */
#define CS_IO_ECHO_OPEN_CLOSE   -1 /* Echo open or close operations */
#define CS_IO_ECHO_HEADERS   0 /* Echo headers */
Typedefs
typedef struct _cs_io_t cs_io_t
Enumerations
enum  cs_io_mode_t { CS_IO_MODE_READ , CS_IO_MODE_WRITE }
cs_io_t * cs_io_initialize (const char *file_name, const char *magic_string, cs_io_mode_t mode, cs_file_access_t method, long echo)
cs_io_t * cs_io_initialize_with_index (const char *file_name, const char *magic_string, cs_file_access_t method, long echo)
cs_io_t * cs_io_initialize_with_index_from_mem (const char *file_name, const char *magic_string, cs_file_access_t method, long echo, size_t nb, void *data)
void cs_io_finalize (cs_io_t **pp_io)
const char * cs_io_get_name (const cs_io_t *pp_io)
size_t cs_io_get_index_size (const cs_io_t *inp)
const char * cs_io_get_indexed_sec_name (const cs_io_t *inp, size_t id)
cs_io_sec_header_t cs_io_get_indexed_sec_header (const cs_io_t *inp, size_t id)
size_t cs_io_get_echo (const cs_io_t *pp_io)
void cs_io_get_data_in_mem (const cs_io_t *pp_io, size_t *nb, void **data)
int cs_io_read_header (cs_io_t *inp, cs_io_sec_header_t *header)
int cs_io_set_indexed_position (cs_io_t *inp, cs_io_sec_header_t *header, size_t id)
void cs_io_set_int (cs_io_sec_header_t *header, const cs_io_t *cs_io)
void cs_io_set_cs_lnum (cs_io_sec_header_t *header, const cs_io_t *pp_io)
void cs_io_set_cs_gnum (cs_io_sec_header_t *header, const cs_io_t *pp_io)
void cs_io_assert_cs_real (const cs_io_sec_header_t *header, const cs_io_t *pp_io)
void * cs_io_read_global (const cs_io_sec_header_t *header, void *elts, cs_io_t *pp_io)
void * cs_io_read_block (const cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, void *elts, cs_io_t *pp_io)
void * cs_io_read_index_block (cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, cs_gnum_t *elts, cs_io_t *pp_io)
void cs_io_write_global (const char *sec_name, cs_gnum_t n_vals, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp)
void cs_io_write_block (const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp)
void cs_io_write_block_buffer (const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, void *elts, cs_io_t *outp)
void cs_io_skip (const cs_io_sec_header_t *header, cs_io_t *pp_io)
cs_file_off_t cs_io_get_offset (cs_io_t *inp)
void cs_io_set_offset (cs_io_t *inp, cs_file_off_t offset)
void cs_io_log_initialize (void)
void cs_io_log_finalize (void)
void cs_io_dump (const cs_io_t *cs_io)
int cs_glob_io_hints
◆ CS_IO_ECHO_HEADERS
◆ CS_IO_ECHO_NONE
◆ CS_IO_ECHO_OPEN_CLOSE
◆ CS_IO_NAME_LEN
Typedef Documentation
◆ cs_io_t
◆ cs_io_mode_t
Enumerator
CS_IO_MODE_READ
CS_IO_MODE_WRITE
◆ cs_io_assert_cs_real()
void cs_io_assert_cs_real ( const cs_io_sec_header_t *  header,
const cs_io_t *  pp_io
◆ cs_io_dump()
void cs_io_dump ( const cs_io_t *  cs_io)
◆ cs_io_finalize()
void cs_io_finalize ( cs_io_t **  pp_io)
◆ cs_io_get_data_in_mem()
void cs_io_get_data_in_mem ( const cs_io_t *  pp_io,
size_t *  nb,
void **  data
◆ cs_io_get_echo()
size_t cs_io_get_echo ( const cs_io_t *  pp_io)
◆ cs_io_get_index_size()
size_t cs_io_get_index_size ( const cs_io_t *  inp)
◆ cs_io_get_indexed_sec_header()
cs_io_sec_header_t cs_io_get_indexed_sec_header ( const cs_io_t *  inp,
size_t  id
◆ cs_io_get_indexed_sec_name()
const char * cs_io_get_indexed_sec_name ( const cs_io_t *  inp,
size_t  id
◆ cs_io_get_name()
const char * cs_io_get_name ( const cs_io_t *  pp_io)
◆ cs_io_get_offset()
cs_file_off_t cs_io_get_offset ( cs_io_t *  inp)
◆ cs_io_initialize()
cs_io_t * cs_io_initialize ( const char *  file_name,
const char *  magic_string,
cs_io_mode_t  mode,
long  echo
◆ cs_io_initialize_with_index()
cs_io_t * cs_io_initialize_with_index ( const char *  file_name,
long  echo
◆ cs_io_initialize_with_index_from_mem()
cs_io_t * cs_io_initialize_with_index_from_mem ( const char *  file_name,
long  echo,
size_t  nb,
void *  data
◆ cs_io_log_finalize()
void cs_io_log_finalize ( void  )
◆ cs_io_log_initialize()
void cs_io_log_initialize ( void  )
◆ cs_io_read_block()
void * cs_io_read_block ( const cs_io_sec_header_t *  header,
void *  elts,
cs_io_t *  pp_io
◆ cs_io_read_global()
void * cs_io_read_global ( const cs_io_sec_header_t *  header,
void *  elts,
cs_io_t *  pp_io
◆ cs_io_read_header()
int cs_io_read_header ( cs_io_t *  inp,
◆ cs_io_read_index_block()
void * cs_io_read_index_block ( cs_io_sec_header_t *  header,
cs_gnum_t *  elts,
cs_io_t *  pp_io
◆ cs_io_set_cs_gnum()
void cs_io_set_cs_gnum ( cs_io_sec_header_t *  header,
◆ cs_io_set_cs_lnum()
void cs_io_set_cs_lnum ( cs_io_sec_header_t *  header,
◆ cs_io_set_indexed_position()
int cs_io_set_indexed_position ( cs_io_t *  inp,
size_t  id
◆ cs_io_set_int()
void cs_io_set_int ( cs_io_sec_header_t *  header,
◆ cs_io_set_offset()
void cs_io_set_offset ( cs_io_t *  inp,
◆ cs_io_skip()
void cs_io_skip ( const cs_io_sec_header_t *  header,
cs_io_t *  pp_io
◆ cs_io_write_block()
void cs_io_write_block ( const char *  sec_name,
cs_gnum_t  n_g_elts,
size_t  location_id,
size_t  index_id,
const void *  elts,
cs_io_t *  outp
◆ cs_io_write_block_buffer()
void cs_io_write_block_buffer ( const char *  sec_name,
cs_gnum_t  n_g_elts,
size_t  location_id,
size_t  index_id,
void *  elts,
cs_io_t *  outp
◆ cs_io_write_global()
void cs_io_write_global ( const char *  sec_name,
cs_gnum_t  n_vals,
size_t  location_id,
size_t  index_id,
const void *  elts,
cs_io_t *  outp
◆ cs_glob_io_hints
extern
