cs_hodge.h File Reference
#include "cdo/cs_cdo_local.h"
#include "cdo/cs_cdo_quantities.h"
#include "cdo/cs_param_cdo.h"
#include "cdo/cs_property.h"
#include "cdo/cs_sdm.h"
+ Include dependency graph for cs_hodge.h:
Classes
struct  cs_hodge_param_t
 Structure storing all metadata/parameters related to the usage of a discrete Hodge operator. More...
struct  cs_hodge_t
 Structure associated to a discrete Hodge operator *. More...
Typedefs
typedef bool() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell. The discrete Hodge operator is stored in hodge->matrix whereas the associated operator is stored in cb->loc One checks if something has to be computed. One skips the computation if the value of the associated property is equal to zero. More...
Enumerations
enum  cs_hodge_type_t {
  CS_HODGE_TYPE_VPCD , CS_HODGE_TYPE_EPFD , CS_HODGE_TYPE_FPED , CS_HODGE_TYPE_EDFP ,
  CS_HODGE_TYPE_CPVD , CS_HODGE_TYPE_VDCP , CS_HODGE_TYPE_FB , CS_HODGE_TYPE_VC ,
  CS_HODGE_N_TYPES
 Type of discrete Hodge operators. More...
enum  cs_hodge_algo_t {
  CS_HODGE_ALGO_VORONOI , CS_HODGE_ALGO_WBS , CS_HODGE_ALGO_COST , CS_HODGE_ALGO_BUBBLE ,
  CS_HODGE_ALGO_AUTO , CS_HODGE_N_ALGOS
 Type of algorithm to build a discrete Hodge operator. More...
static bool cs_hodge_param_is_similar (const cs_hodge_param_t h1_info, const cs_hodge_param_t h2_info)
 Check if two sets of parameters related to how build a discrete Hodge operator are similar. More...
cs_hodge_t * cs_hodge_create (const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen)
 Create and initialize a pointer to a cs_hodge_t structure. More...
cs_hodge_t ** cs_hodge_init_context (const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen)
 Create and initialize an array of pointers to a cs_hodge_t structures. This array is of size the number of OpenMP threads. Only the one associated to the current thread is set. More...
void cs_hodge_free (cs_hodge_t **p_hodge)
 Free a cs_hodge_t structure. More...
void cs_hodge_free_context (cs_hodge_t ***p_hodges)
 Free a set of cs_hodge_t structures. More...
cs_hodge_compute_t * cs_hodge_get_func (const char *calling_func, const cs_hodge_param_t hp)
 Retrieve a function pointer to compute a discrete Hodge operator. More...
cs_hodge_algo_t cs_hodge_set_mass_algo (const char *eqname, cs_hodge_algo_t reac_algo, cs_hodge_algo_t time_algo)
 Check the consistency of the settings between terms related to a mass matrix and define the common algorithm to use. If a term should not be considered, set the algorithm to CS_HODGE_N_ALGOS. More...
void cs_hodge_param_log (const char *prefix, const cs_property_t *property, const cs_hodge_param_t hp)
 Output the settings related to a cs_hodge_param_t structure. More...
void cs_hodge_copy_parameters (const cs_hodge_param_t *h_ref, cs_hodge_param_t *h_cpy)
 Copy the set of parameters associated to a discrete Hodge operator to another one. More...
void cs_hodge_evaluate_property (const cs_lnum_t c_id, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge)
 Set the property value (scalar- or tensor-valued) related to a discrete Hodge operator inside a cell and if needed other related quantities. More...
void cs_hodge_evaluate_property_cw (const cs_cell_mesh_t *cm, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge)
 Set the property value (scalar- or tensor-valued) related to a discrete Hodge operator inside a cell and if needed ohter related quantities. Cell-wise variant (usage of cs_cell_mesh_t structure) More...
bool cs_hodge_fb_cost_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More...
bool cs_hodge_fb_bubble_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic COST algo. with the usage of bubble stabilization. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More...
bool cs_hodge_fb_voro_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More...
bool cs_hodge_vb_cost_get_iso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and an isotropic property. More...
bool cs_hodge_vb_cost_get_aniso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and an anistropic property. More...
bool cs_hodge_vb_bubble_get_iso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic Bubble algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and isotropic material property. More...
bool cs_hodge_vb_bubble_get_aniso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic Bubble algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and anisotropic material property. More...
bool cs_hodge_vb_cost_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes. More...
bool cs_hodge_vb_voro_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes. More...
bool cs_hodge_vb_wbs_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic WBS algo. WBS means for Whitney Barycentric Subdivision (WBS) algo. The computed matrix is stored in cb->loc. More...
bool cs_hodge_vcb_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local stiffness matrix using the generic WBS algo. WBS means Whitney Barycentric Subdivision (WBS) algo. The computed matrix is stored in cb->loc. More...
bool cs_hodge_fb_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator on a given cell which is equivalent of a mass matrix. It relies on a CO+ST algo. and is specific to CDO-Fb schemes. The discrete Hodge operator is stored in hodge->matrix. More...
bool cs_hodge_vcb_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using the Voronoi algo. This leads to a diagonal operator. This function is specific for vertex+cell-based schemes The discrete Hodge operator is stored in hodge->matrix. More...
bool cs_hodge_vcb_wbs_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using the WBS algo. This function is specific for vertex+cell-based schemes The discrete Hodge operator is stored in hodge->matrix. More...
bool cs_hodge_vpcd_wbs_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using WBS algo. Hodge op. from primal vertices to dual cells. This function is specific for vertex-based schemes The discrete Hodge operator is stored in hodge->matrix. More...
bool cs_hodge_vpcd_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal vertices to dual cells. This function is specific for vertex-based schemes The discrete Hodge operator is stored in hodge->matrix. More...
bool cs_hodge_epfd_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal edges to dual faces. The discrete Hodge operator is stored in hodge->matrix This function is specific for vertex-based schemes. More...
bool cs_hodge_epfd_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal edges to dual faces. The discrete Hodge operator is stored in hodge->matrix This function is specific for vertex-based schemes. More...
bool cs_hodge_epfd_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using the COST algo. with a bubble stabilization. The discrete Hodge operator is stored in hodge->matrix Hodge op. from primal edges to dual faces. This function is specific for vertex-based schemes. More...
bool cs_hodge_fped_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More...
bool cs_hodge_fped_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More...
bool cs_hodge_fped_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More...
bool cs_hodge_edfp_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from dual edges to primal faces. The discrete Hodge operator is stored in hodge->matrix This function is related to face-based schemes. More...
bool cs_hodge_edfp_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using the COST algo. Hodge op. from dual edges to primal faces. This function is related to face-based schemes. More...
bool cs_hodge_edfp_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
 Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from dual edges to primal faces. The discrete Hodge operator is stored in hodge->matrix This function is related to face-based schemes. More...
bool cs_hodge_edfp_cost_get_opt (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
void cs_hodge_matvec (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t in_vals[], cs_real_t t_eval, cs_real_t result[])
 Compute cellwise a discrete hodge operator and multiple it with a vector. More...
void cs_hodge_circulation_from_flux (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t flux[], cs_real_t circul[])
 Compute cellwise a discrete hodge operator in order to define a circulation array from a flux array. More...
void cs_hodge_compute_wbs_surfacic (const cs_face_mesh_t *fm, cs_sdm_t *hf)
 Compute the hodge operator related to a face (i.e. a mass matrix with unity property) using a Whitney Barycentric Subdivision (WBS) algorithm. More...
Typedef Documentation
◆ cs_hodge_compute_t
[in]cmpointer to a cs_cell_mesh_t struct.
[in,out]hodgepointer to a cs_hodge_t structure
true if something has been computed or false otherwise.
◆ cs_hodge_algo_t
Enumerator
This algorithm assumes that an orthogonality condition holds between geometrical entities (e.g. the face normal/dual edge or the primal edge/dual face normal). This algorithm leads to a diagonal discrete Hodge operator (and is related to a two-point flux approximation). Be aware that using this technique on a non-orthogonal mesh leads to a consistency error which does not decrease when refining the mesh.
CS_HODGE_ALGO_WBS
WBS means "Whitney Barycentric Subdivision". This algorithm relies on a subdivision into tetrahedra of each polyhedral cell and then applies algorithms on this subdivision shape functions close to what exists in the Finite Element litterature
CS_HODGE_ALGO_COST
Orthogonal decomposition between the consistency (CO) and the stabilization (ST) parts. Several discretizations share this way to build discrete Hodge operators like SUSHI, DGA and GCR (these discretizations only differ from the scaling coefficient in front of the stabilization term)
This algorithm also relies on an orthogonal decomposition between the consistency (CO) and the stabilization (ST) parts but the stabilization part relies on a bubble function (similar to what can be found in the Finite Element literature)
CS_HODGE_ALGO_AUTO
Automatic switch between the above-mentioned algorithms (not used for the moment).
CS_HODGE_N_ALGOS
◆ cs_hodge_type_t
Enumerator
CS_HODGE_TYPE_VPCD
Hodge operator from primal vertices to dual cells. This operator is also equivalent to a mass matrix for vertex-based schemes
CS_HODGE_TYPE_EPFD
Hodge operator from primal edges to dual faces
CS_HODGE_TYPE_FPED
Hodge operator from primal faces to dual edges
CS_HODGE_TYPE_EDFP
Hodge operator from dual edges to primal faces
CS_HODGE_TYPE_CPVD
Hodge operator from primal cells to dual vertices
CS_HODGE_TYPE_VDCP
Hodge operator from dual vertices to primal cells
CS_HODGE_TYPE_FB
Hodge operator playing the role of mass matrix for face-based schemes. This operator deals with a hybrid space of degrees of freedom (faces and cells)
CS_HODGE_TYPE_VC
Hodge operator playing the role of mass matrix for vertex+cell-based schemes. This operator deals with a hybrid space of degrees of freedom (vertices and cells)
CS_HODGE_N_TYPES
◆ cs_hodge_circulation_from_flux()
void cs_hodge_circulation_from_flux ( const cs_cdo_connect_t *  connect,
cs_real_t  t_eval,
const cs_property_t *  pty,
cs_real_t  circul[]
[in]hodgepcs_hodge_param_t structure
[in]ptypointer to a cs_property_t structure or null
[in]fluxvector to multiply with the discrete Hodge op.
[in,out]circularray storing the resulting matrix-vector product
[in]ptypointer to a cs_property_t structure or nullptr
◆ cs_hodge_compute_wbs_surfacic()
void cs_hodge_compute_wbs_surfacic ( const cs_face_mesh_t *  fm,
cs_sdm_t *  hf
[in]fmpointer to a cs_face_mesh_t structure
[in,out]hfpointer to a cs_sdm_t structure to define
◆ cs_hodge_copy_parameters()
void cs_hodge_copy_parameters ( const cs_hodge_param_t *  h_ref,
cs_hodge_param_t *  h_cpy
[in]h_refreference set of parameters
[in,out]h_cpyset of parameters to update
◆ cs_hodge_create()
cs_hodge_t * cs_hodge_create ( const cs_cdo_connect_t *  connect,
const cs_property_t *  property,
const cs_hodge_param_t *  hp,
bool  need_tensor,
bool  need_eigen
[in]connectpointer to cs_cdo_connect_t structure
[in]propertypointer to a property structure
[in]hppointer to a cs_hodge_param_t structure
[in]need_tensortrue if one needs a tensor otherwise false
[in]need_eigentrue if one needs to compute eigen valuese
a pointer to the new allocated cs_hodge_t structure
◆ cs_hodge_edfp_bubble_get()
bool cs_hodge_edfp_bubble_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
cs_cell_builder_t *  cb
◆ cs_hodge_edfp_cost_get()
bool cs_hodge_edfp_cost_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_edfp_cost_get_opt()
bool cs_hodge_edfp_cost_get_opt ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_edfp_voro_get()
bool cs_hodge_edfp_voro_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_epfd_bubble_get()
bool cs_hodge_epfd_bubble_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_epfd_cost_get()
bool cs_hodge_epfd_cost_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_epfd_voro_get()
bool cs_hodge_epfd_voro_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_evaluate_property()
void cs_hodge_evaluate_property ( const cs_lnum_t  c_id,
cs_hodge_t *  hodge
[in]c_idid of the cell to deal with
[in]c_flagflag related to this cell
◆ cs_hodge_evaluate_property_cw()
void cs_hodge_evaluate_property_cw ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge
◆ cs_hodge_fb_bubble_get_stiffness()
bool cs_hodge_fb_bubble_get_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_fb_cost_get_stiffness()
bool cs_hodge_fb_cost_get_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_fb_get()
bool cs_hodge_fb_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_fb_voro_get_stiffness()
bool cs_hodge_fb_voro_get_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_fped_bubble_get()
bool cs_hodge_fped_bubble_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_fped_cost_get()
bool cs_hodge_fped_cost_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_fped_voro_get()
bool cs_hodge_fped_voro_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_free()
void cs_hodge_free ( cs_hodge_t **  p_hodge)
[in,out]p_hodgedouble pointer to a cs_hodge_t structure
◆ cs_hodge_free_context()
void cs_hodge_free_context ( cs_hodge_t ***  p_hodges)
[in,out]p_hodgestriple pointer to cs_hodge_t structures
◆ cs_hodge_get_func()
cs_hodge_compute_t * cs_hodge_get_func ( const char *  calling_func,
[in]calling_funcname of the calling function
[in]hpa cs_hodge_param_t structure
a pointer to the corresponding function
◆ cs_hodge_init_context()
cs_hodge_t ** cs_hodge_init_context ( const cs_cdo_connect_t *  connect,
bool  need_tensor,
bool  need_eigen
an array of pointers of cs_hodge_t structures
◆ cs_hodge_matvec()
void cs_hodge_matvec ( const cs_cdo_connect_t *  connect,
cs_real_t  t_eval,
cs_real_t  result[]
[in]in_valsvector to multiply with the discrete Hodge op.
[in,out]resultarray storing the resulting matrix-vector product
◆ cs_hodge_param_is_similar()
static bool cs_hodge_param_is_similar ( const cs_hodge_param_t  h1_info,
inlinestatic
[in]h1_infopointer to a first cs_hodge_param_t structure
[in]h2_infopointer to a second cs_hodge_param_t structure
true or false
◆ cs_hodge_param_log()
void cs_hodge_param_log ( const char *  prefix,
[in]prefixoptional string
[in]propertyoptional pointer to a property structure
◆ cs_hodge_set_mass_algo()
cs_hodge_algo_t cs_hodge_set_mass_algo ( const char *  eqname,
[in]eqnamename of the equation to check
[in]reac_algooptional algo. used for the reaction term
[in]time_algooptional algo. used for the unsteady term
◆ cs_hodge_vb_bubble_get_aniso_stiffness()
bool cs_hodge_vb_bubble_get_aniso_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vb_bubble_get_iso_stiffness()
bool cs_hodge_vb_bubble_get_iso_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vb_cost_get_aniso_stiffness()
bool cs_hodge_vb_cost_get_aniso_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vb_cost_get_iso_stiffness()
bool cs_hodge_vb_cost_get_iso_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vb_cost_get_stiffness()
bool cs_hodge_vb_cost_get_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vb_voro_get_stiffness()
bool cs_hodge_vb_voro_get_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vb_wbs_get_stiffness()
bool cs_hodge_vb_wbs_get_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vcb_get_stiffness()
bool cs_hodge_vcb_get_stiffness ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vcb_voro_get()
bool cs_hodge_vcb_voro_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vcb_wbs_get()
bool cs_hodge_vcb_wbs_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vpcd_voro_get()
bool cs_hodge_vpcd_voro_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
◆ cs_hodge_vpcd_wbs_get()
bool cs_hodge_vpcd_wbs_get ( const cs_cell_mesh_t *  cm,
cs_hodge_t *  hodge,
