cs_hho_scaleq.h File Reference
+ Include dependency graph for cs_hho_scaleq.h:
void cs_hho_scaleq_init_sharing (cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
 Allocate work buffer and general structures related to HHO schemes Set shared pointers. More...
void cs_hho_scaleq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
void cs_hho_scaleq_finalize_sharing (void)
 Free buffers and generic structures related to HHO schemes. More...
void * cs_hho_scaleq_init_context (cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a cs_hho_scaleq_t structure storing data useful for building and managing such a scheme. More...
void * cs_hho_scaleq_free_context (void *data)
 Destroy a cs_hho_scaleq_t structure. More...
void cs_hho_scaleq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued HHO schemes. More...
void cs_hho_scaleq_initialize_system (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_matrix_t **system_matrix, cs_real_t **system_rhs)
 Create the matrix of the current algebraic system. Allocate and initialize the right-hand side associated to the given data structure. More...
void cs_hho_scaleq_build_system (const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme. One works cellwise and then process to the assembly. More...
void cs_hho_scaleq_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
 Store solution(s) of the linear system into a field structure Update extra-field values required for hybrid discretization. More...
cs_real_t * cs_hho_scaleq_get_face_values (void *context, bool previous)
 Get the computed values at faces (DoF used in the linear system are located at primal faces) More...
cs_real_t * cs_hho_scaleq_get_cell_values (void *context, bool previous)
 Get the computed values at cells (DoF used in the linear system are located at primal faces) More...
void cs_hho_scaleq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_hho_scaleq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_hho_scaleq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
◆ cs_hho_scaleq_build_system()
void cs_hho_scaleq_build_system ( const cs_mesh_t *  mesh,
const cs_real_t *  field_val,
cs_equation_builder_t *  eqb,
void *  context
[in]field_valpointer to the current value of the field
[in,out]contextpointer to cs_hho_scaleq_t structure
◆ cs_hho_scaleq_extra_post()
void cs_hho_scaleq_extra_post ( const cs_equation_param_t *  eqp,
void *  context
◆ cs_hho_scaleq_finalize_sharing()
void cs_hho_scaleq_finalize_sharing ( void  )
◆ cs_hho_scaleq_free_context()
void * cs_hho_scaleq_free_context ( void *  data)
[in,out]datapointer to a cs_hho_scaleq_t structure
a null pointer
◆ cs_hho_scaleq_get()
void cs_hho_scaleq_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb,
cs_hho_builder_t **  hhob
[out]hhobpointer to a pointer on a cs_hho_builder_t structure
◆ cs_hho_scaleq_get_cell_values()
cs_real_t * cs_hho_scaleq_get_cell_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t
◆ cs_hho_scaleq_get_face_values()
cs_real_t * cs_hho_scaleq_get_face_values ( void *  context,
bool  previous
◆ cs_hho_scaleq_init_context()
void * cs_hho_scaleq_init_context ( cs_equation_param_t *  eqp,
int  var_id,
int  bflux_id,
a pointer to a new allocated cs_hho_scaleq_t structure
◆ cs_hho_scaleq_init_sharing()
void cs_hho_scaleq_init_sharing ( cs_flag_t  scheme_flag,
[in]scheme_flagflag to identify which kind of numerical scheme is requested to solve the computational domain
◆ cs_hho_scaleq_init_values()
void cs_hho_scaleq_init_values ( cs_real_t  t_eval,
const int  field_id,
void *  context
◆ cs_hho_scaleq_initialize_system()
void cs_hho_scaleq_initialize_system ( const cs_equation_param_t *  eqp,
void *  data,
cs_matrix_t **  system_matrix,
cs_real_t **  system_rhs
[in,out]datapointer to generic data structure
[in,out]system_matrixpointer of pointer to a cs_matrix_t struct.
[in,out]system_rhspointer of pointer to an array of cs_real_t
[in,out]system_rhspointer of pointer to an array of double
◆ cs_hho_scaleq_read_restart()
void cs_hho_scaleq_read_restart ( cs_restart_t *  restart,
const char *  eqname,
void *  scheme_context
◆ cs_hho_scaleq_update_field()
void cs_hho_scaleq_update_field ( const cs_real_t *  solu,
const cs_real_t *  rhs,
void *  data,
[in]solusolution array
[in]rhsrhs associated to this solution array
[in,out]datapointer to cs_hho_scaleq_t structure
[in,out]field_valpointer to the current value of the field
◆ cs_hho_scaleq_write_restart()
void cs_hho_scaleq_write_restart ( cs_restart_t *  restart,
