cs_hho_builder.h File Reference
#include "base/cs_base.h"
#include "cdo/cs_basis_func.h"
#include "cdo/cs_property.h"
#include "cdo/cs_sdm.h"
#include "cdo/cs_xdef.h"
+ Include dependency graph for cs_hho_builder.h:
Classes
struct  cs_hho_builder_t
cs_hho_builder_t * cs_hho_builder_create (int order, int n_fc)
 Allocate a cs_hho_builder_t structure. More...
void cs_hho_builder_free (cs_hho_builder_t **p_builder)
 Free a cs_hho_builder_t structure. More...
void cs_hho_builder_cellwise_setup (const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Set-up the basis functions related to a cell, its gradient and to the faces of this cell. Compute cell and face projection and its related modified Cholesky factorization. More...
static void cs_hho_builder_cellbasis_setup (const cs_cell_mesh_t *cm, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Set-up the basis functions related to a cell only. More...
void cs_hho_builder_compute_grad_reco (const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Compute the gradient operator stemming from the relation stiffness * grad_op = rhs where stiffness is a square matrix of size grd_size rhs is matrix of size (n_fc*f_size + c_size) * grd_size Hence, grad_op a matrix grd_size * (n_fc*f_size + c_size) More...
void cs_hho_builder_diffusion (const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_cell_builder_t *cb, cs_hho_builder_t *hhob)
 Compute the diffusion operator. The gradient reconstruction operator has to be built just before this call (cb->aux stores the rhs) More...
void cs_hho_builder_reduction_from_analytic (const cs_xdef_t *def, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t red[])
 Compute the reduction onto the polynomial spaces (cell and faces) of a function defined by an analytical expression depending on the location and the current time red array has to be allocated before calling this function. More...
void cs_hho_builder_reduction_from_analytic_v (const cs_xdef_t *def, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t red[])
 Compute the reduction onto the polynomial spaces (cell and faces) of a function defined by an analytical expression depending on the location and the current time This function handles the vector case. More...
void cs_hho_builder_compute_dirichlet (const cs_xdef_t *def, short int f, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t res[])
 Compute the projection of the Dirichlet boundary conditions onto the polynomial spaces on faces. More...
void cs_hho_builder_compute_dirichlet_v (const cs_xdef_t *def, short int f, const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_cell_builder_t *cb, cs_hho_builder_t *hhob, cs_real_t res[])
 Compute the projection of the Dirichlet boundary conditions onto the polynomial spaces on faces. Vector case. More...
◆ cs_hho_builder_cellbasis_setup()
static void cs_hho_builder_cellbasis_setup ( const cs_cell_mesh_t *  cm,
cs_cell_builder_t *  cb,
cs_hho_builder_t *  hhob
inlinestatic
[in]cbpointer to a cell builder_t structure
[in,out]hhobpointer to a cs_hho_builder_t structure
◆ cs_hho_builder_cellwise_setup()
void cs_hho_builder_cellwise_setup ( const cs_cell_mesh_t *  cm,
◆ cs_hho_builder_compute_dirichlet()
void cs_hho_builder_compute_dirichlet ( const cs_xdef_t *  def,
short int  f,
cs_real_t  t_eval,
cs_hho_builder_t *  hhob,
cs_real_t  res[]
[in]defpointer to a cs_xdef_t structure
[in]flocal face id in the cellwise view of the mesh
[in,out]cbpointer to a cell builder_t structure
[in,out]resvector containing the result
◆ cs_hho_builder_compute_dirichlet_v()
void cs_hho_builder_compute_dirichlet_v ( const cs_xdef_t *  def,
short int  f,
cs_real_t  t_eval,
cs_real_t  res[]
◆ cs_hho_builder_compute_grad_reco()
void cs_hho_builder_compute_grad_reco ( const cs_cell_mesh_t *  cm,
const cs_property_data_t *  diff_pty,
[in]diff_ptypointer to a cs_property_data_t structure
◆ cs_hho_builder_create()
cs_hho_builder_t * cs_hho_builder_create ( int  order,
int  n_fc
[in]orderorder of the polynomial basis function
[in]n_fcmax. number of faces in a cell
a pointer to a new allocated cs_hho_builder_t structure
◆ cs_hho_builder_diffusion()
void cs_hho_builder_diffusion ( const cs_cell_mesh_t *  cm,
◆ cs_hho_builder_free()
void cs_hho_builder_free ( cs_hho_builder_t **  p_builder)
[in,out]p_builderpointer of pointer on a cs_hho_builder_t struct.
◆ cs_hho_builder_reduction_from_analytic()
void cs_hho_builder_reduction_from_analytic ( const cs_xdef_t *  def,
cs_real_t  t_eval,
cs_real_t  red[]
[in,out]redvector containing the reduction
◆ cs_hho_builder_reduction_from_analytic_v()
void cs_hho_builder_reduction_from_analytic_v ( const cs_xdef_t *  def,
cs_real_t  t_eval,
cs_real_t  red[]
