cs_gui_util.cpp File Reference
#include <stdarg.h>
#include <fcntl.h>
#include <unistd.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_mem.h"
#include "base/cs_tree.h"
#include "gui/cs_tree_xml.h"
#include "gui/cs_gui_util.h"
+ Include dependency graph for cs_gui_util.cpp:
int cs_gui_load_file (const char *filename)
 Load the XML file in memory. More...
void cs_gui_check_version (void)
 Check the XML file version. More...
int cs_gui_characters_number (int num)
int cs_gui_strcmp (const char *s1, const char *s2)
int cs_gui_is_equal_real (cs_real_t v1, cs_real_t v2)
void cs_gui_node_get_int (cs_tree_node_t *node, int *value)
 Update an integer value based on a tree node. More...
void cs_gui_node_get_real (cs_tree_node_t *node, cs_real_t *value)
 Update an real value based on a tree node. More...
void cs_gui_node_get_status_int (cs_tree_node_t *node, int *status)
 Update an integer-valued status value based on a node's status tag. More...
void cs_gui_node_get_status_bool (cs_tree_node_t *node, bool *status)
 Update an bool-valued status value based on a node's status tag. More...
const char * cs_gui_node_get_tag (cs_tree_node_t *node, const char *tag_name)
 Return a string value associated with a "tag" child node and whose presence should be guaranteed. More...
void cs_gui_node_get_child_int (cs_tree_node_t *node, const char *child_name, int *value)
 Update an integer value based on a tree's child node. More...
void cs_gui_node_get_child_real (cs_tree_node_t *node, const char *child_name, cs_real_t *value)
void cs_gui_node_get_child_status_int (cs_tree_node_t *node, const char *child_name, int *status)
 Update an integer-valued status value based on a node child's status tag. More...
void cs_gui_node_get_child_status_bool (cs_tree_node_t *node, const char *child_name, bool *status)
 Update a bool-valued status value based on a node child's status tag. More...
void cs_gui_add_mei_time (double t)
double cs_gui_get_mei_times (void)
◆ cs_gui_add_mei_time()
void cs_gui_add_mei_time ( double  t)
◆ cs_gui_characters_number()
int cs_gui_characters_number ( int  num)
◆ cs_gui_check_version()
void cs_gui_check_version ( void  )
◆ cs_gui_get_mei_times()
double cs_gui_get_mei_times ( void  )
◆ cs_gui_is_equal_real()
int cs_gui_is_equal_real ( cs_real_t  v1,
cs_real_t  v2
◆ cs_gui_load_file()
int cs_gui_load_file ( const char *  filename)
[in]filenameXML file containing the parameters
error code (0 in case of success)
◆ cs_gui_node_get_child_int()
void cs_gui_node_get_child_int ( cs_tree_node_t *  node,
const char *  child_name,
int *  value
If no node is present, the initial value is unchanged. If the node is present but the value missing, an error is returned.
[in]nodenode whose value is queried
[in]child_namename of child node
[in,out]valuequeried value
◆ cs_gui_node_get_child_real()
void cs_gui_node_get_child_real ( cs_tree_node_t *  node,
cs_real_t *  value
◆ cs_gui_node_get_child_status_bool()
void cs_gui_node_get_child_status_bool ( cs_tree_node_t *  node,
bool *  status
The status is defined in a string-valued child (tag) node. If no such child and tag is present, the initial status is unchanged.
[in,out]statusqueried value
◆ cs_gui_node_get_child_status_int()
void cs_gui_node_get_child_status_int ( cs_tree_node_t *  node,
int *  status
◆ cs_gui_node_get_int()
void cs_gui_node_get_int ( cs_tree_node_t *  node,
int *  value
◆ cs_gui_node_get_real()
void cs_gui_node_get_real ( cs_tree_node_t *  node,
cs_real_t *  value
◆ cs_gui_node_get_status_bool()
void cs_gui_node_get_status_bool ( cs_tree_node_t *  node,
bool *  status
The status is defined in a string-valued child (tag) node. If no such tag is present, the initial status is unchanged.
[in]nodenode whose status is queried
[in,out]statusstatus value (0 or 1)
◆ cs_gui_node_get_status_int()
void cs_gui_node_get_status_int ( cs_tree_node_t *  node,
int *  status
◆ cs_gui_node_get_tag()
const char * cs_gui_node_get_tag ( cs_tree_node_t *  node,
const char *  tag_name
If the matching child node is not present, an error is produced
[in]nodetree node which should have a "tag" child
[in]tag_namename of tag child node
pointer to matching child string
◆ cs_gui_strcmp()
int cs_gui_strcmp ( const char *  s1,
const char *  s2
