cs_gui_boundary_conditions.cpp File Reference
#include <fcntl.h>
#include <unistd.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "fvm/fvm_selector.h"
#include "base/cs_ale.h"
#include "atmo/cs_atmo.h"
#include "base/cs_base.h"
#include "base/cs_boundary.h"
#include "base/cs_boundary_conditions_priv.h"
#include "cfbl/cs_cf_thermo.h"
#include "comb/cs_coal_boundary_conditions.h"
#include "cogz/cs_combustion_boundary_conditions.h"
#include "pprt/cs_combustion_model.h"
#include "cdo/cs_equation_param.h"
#include "gui/cs_gui_util.h"
#include "gui/cs_gui.h"
#include "gui/cs_gui_specific_physics.h"
#include "base/cs_ht_convert.h"
#include "meg/cs_meg_prototypes.h"
#include "meg/cs_meg_xdef_wrapper.h"
#include "mesh/cs_mesh.h"
#include "base/cs_field.h"
#include "base/cs_mem.h"
#include "cdo/cs_thermal_system.h"
#include "base/cs_timer.h"
#include "base/cs_tree.h"
#include "turb/cs_turbulence_bc.h"
#include "base/cs_parall.h"
#include "elec/cs_elec_model.h"
#include "base/cs_vof.h"
#include "base/cs_wall_functions.h"
#include "gui/cs_gui_boundary_conditions.h"
+ Include dependency graph for cs_gui_boundary_conditions.cpp:
void cs_gui_boundary_conditions_processing (int *itypfb)
void cs_gui_boundary_conditions_verify (void)
void cs_gui_boundary_conditions_define (cs_boundary_t *bdy)
 Define boundary conditions based on setup file. More...
void cs_gui_boundary_conditions_free_memory (void)
 Free GUI boundary condition structures. More...
cs_gui_boundary_meg_context_t * cs_gui_boundary_add_meg_context (const cs_zone_t *zone, const char *name, const char *condition, int dim)
 Add new MEG-based cs_dof_func_t context info. More...
void cs_gui_boundary_conditions_dof_func_meg (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
 cs_dof_func_t function to compute boundary condition values using a MEG generated function. More...
◆ cs_gui_boundary_add_meg_context()
cs_gui_boundary_meg_context_t * cs_gui_boundary_add_meg_context ( const cs_zone_t *  zone,
const char *  name,
const char *  condition,
int  dim
[in]zonepointer to associated zone
[in]namename of associated field or array
[in]conditionassociated condition type
[in]dimassociated dimension
: pointer to cs_dof_func_t context info
◆ cs_gui_boundary_conditions_define()
void cs_gui_boundary_conditions_define ( cs_boundary_t *  bdy)
[in,out]bdyboundaries structure to update (if nullptr, default to cs_glob_domain->boundaries)
◆ cs_gui_boundary_conditions_dof_func_meg()
void cs_gui_boundary_conditions_dof_func_meg ( cs_lnum_t  n_elts,
const cs_lnum_t *  elt_ids,
bool  dense_output,
void *  input,
cs_real_t *  retval
cs_dof_func_t function to compute a boundary profiles using a MEG generated function.
For the calling function, elt_ids is optional. If non-null, array(s) should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false. In the current case, retval is allocated to mesh->n_b_faces
[in]n_eltsnumber of elements to consider
[in]elt_idslist of elements ids
[in]dense_outputperform an indirection in retval or not
[in]inputnullptr or pointer to a structure cast on-the-fly
[in,out]retvalresulting value(s). Must be allocated.
◆ cs_gui_boundary_conditions_free_memory()
void cs_gui_boundary_conditions_free_memory ( void  )
◆ cs_gui_boundary_conditions_processing()
void cs_gui_boundary_conditions_processing ( int *  itypfb)
◆ cs_gui_boundary_conditions_verify()
void cs_gui_boundary_conditions_verify ( void  )
