cs_grid.h File Reference
#include "base/cs_base.h"
#include "base/cs_dispatch.h"
#include "base/cs_halo.h"
#include "alge/cs_matrix.h"
+ Include dependency graph for cs_grid.h:
Typedefs
typedef struct _cs_grid_t cs_grid_t
Enumerations
enum  cs_grid_coarsening_t {
  CS_GRID_COARSENING_DEFAULT , CS_GRID_COARSENING_SPD_DX , CS_GRID_COARSENING_SPD_MX , CS_GRID_COARSENING_SPD_PW ,
  CS_GRID_COARSENING_CONV_DIFF_DX
cs_grid_t * cs_grid_create_from_shared (cs_lnum_t n_faces, cs_lnum_t db_size, cs_lnum_t eb_size, const cs_lnum_2_t *face_cell, const cs_matrix_t *a, bool conv_diff)
cs_grid_t * cs_grid_create_from_parent (const cs_matrix_t *a, int n_ranks)
void cs_grid_destroy (cs_grid_t **grid)
void cs_grid_free_quantities (cs_grid_t *g)
void cs_grid_get_info (const cs_grid_t *g, int *level, bool *symmetric, cs_lnum_t *db_size, cs_lnum_t *eb_size, int *n_ranks, cs_lnum_t *n_rows, cs_lnum_t *n_cols_ext, cs_lnum_t *n_entries, cs_gnum_t *n_g_rows)
cs_alloc_mode_t cs_grid_get_alloc_mode (const cs_grid_t *g)
cs_lnum_t cs_grid_get_n_rows (const cs_grid_t *g)
cs_lnum_t cs_grid_get_n_cols_ext (const cs_grid_t *g)
cs_lnum_t cs_grid_get_n_cols_max (const cs_grid_t *g)
cs_gnum_t cs_grid_get_n_g_rows (const cs_grid_t *g)
const cs_matrix_t * cs_grid_get_matrix (const cs_grid_t *g)
cs_grid_t * cs_grid_coarsen (const cs_grid_t *f, cs_alloc_mode_t alloc_mode, cs_grid_coarsening_t coarsening_type, int aggregation_limit, int verbosity, int merge_stride, int merge_rows_mean_threshold, cs_gnum_t merge_rows_glob_threshold, double relaxation_parameter)
cs_grid_t * cs_grid_coarsen_to_single (const cs_grid_t *f, cs_alloc_mode_t alloc_mode, int merge_stride, int verbosity)
void cs_grid_merge_bottom (cs_grid_t *g, int verbosity, int n_max_ranks, float max_row_factor)
void cs_grid_project_row_num (const cs_grid_t *g, cs_lnum_t n_base_rows, int max_num, int c_row_num[])
void cs_grid_project_row_rank (const cs_grid_t *g, cs_lnum_t n_base_rows, int f_row_rank[])
void cs_grid_project_var (const cs_grid_t *g, cs_lnum_t n_base_rows, const cs_real_t c_var[], cs_real_t f_var[])
void cs_grid_project_diag_dom (const cs_grid_t *g, cs_lnum_t n_base_rows, cs_real_t diag_dom[])
void cs_grid_finalize (void)
void cs_grid_dump (const cs_grid_t *g)
void cs_grid_restrict_row_var (cs_dispatch_context &ctx, const cs_grid_t *f, const cs_grid_t *c, const cs_real_t *f_var, cs_real_t *c_var)
void cs_grid_prolong_row_var (cs_dispatch_context &ctx, const cs_grid_t *c, const cs_grid_t *f, bool increment, cs_real_t *c_var, cs_real_t *f_var)
void cs_grid_set_matrix_tuning (cs_matrix_fill_type_t fill_type, int max_level)
 Set matrix tuning behavior for multigrid coarse meshes. More...
const char * cs_grid_coarsening_type_name []
Typedef Documentation
◆ cs_grid_t
◆ cs_grid_coarsening_t
Enumerator
default among following choices
SPD, diag/extradiag ratio based
SPD, max extradiag ratio based
SPD, pairwise aggregation
convection+diffusion, diag/extradiag ratio based
◆ cs_grid_coarsen()
cs_grid_t * cs_grid_coarsen ( const cs_grid_t *  f,
int  verbosity,
int  merge_stride,
◆ cs_grid_coarsen_to_single()
cs_grid_t * cs_grid_coarsen_to_single ( const cs_grid_t *  f,
int  merge_stride,
int  verbosity
◆ cs_grid_create_from_parent()
cs_grid_t * cs_grid_create_from_parent ( const cs_matrix_t *  a,
int  n_ranks
◆ cs_grid_create_from_shared()
cs_grid_t * cs_grid_create_from_shared ( cs_lnum_t  n_faces,
cs_lnum_t  db_size,
cs_lnum_t  eb_size,
const cs_lnum_2_t *  face_cell,
bool  conv_diff
◆ cs_grid_destroy()
void cs_grid_destroy ( cs_grid_t **  grid)
◆ cs_grid_dump()
void cs_grid_dump ( const cs_grid_t *  g)
◆ cs_grid_finalize()
void cs_grid_finalize ( void  )
◆ cs_grid_free_quantities()
void cs_grid_free_quantities ( cs_grid_t *  g)
◆ cs_grid_get_alloc_mode()
cs_alloc_mode_t cs_grid_get_alloc_mode ( const cs_grid_t *  g)
◆ cs_grid_get_info()
void cs_grid_get_info ( const cs_grid_t *  g,
int *  level,
bool *  symmetric,
cs_lnum_t *  db_size,
cs_lnum_t *  eb_size,
int *  n_ranks,
cs_lnum_t *  n_rows,
cs_lnum_t *  n_cols_ext,
cs_lnum_t *  n_entries,
cs_gnum_t *  n_g_rows
◆ cs_grid_get_matrix()
const cs_matrix_t * cs_grid_get_matrix ( const cs_grid_t *  g)
◆ cs_grid_get_n_cols_ext()
cs_lnum_t cs_grid_get_n_cols_ext ( const cs_grid_t *  g)
◆ cs_grid_get_n_cols_max()
cs_lnum_t cs_grid_get_n_cols_max ( const cs_grid_t *  g)
◆ cs_grid_get_n_g_rows()
cs_gnum_t cs_grid_get_n_g_rows ( const cs_grid_t *  g)
◆ cs_grid_get_n_rows()
cs_lnum_t cs_grid_get_n_rows ( const cs_grid_t *  g)
◆ cs_grid_merge_bottom()
void cs_grid_merge_bottom ( cs_grid_t *  g,
int  verbosity,
int  n_max_ranks,
◆ cs_grid_project_diag_dom()
void cs_grid_project_diag_dom ( const cs_grid_t *  g,
◆ cs_grid_project_row_num()
void cs_grid_project_row_num ( const cs_grid_t *  g,
int  max_num,
int  c_row_num[]
◆ cs_grid_project_row_rank()
void cs_grid_project_row_rank ( const cs_grid_t *  g,
int  f_row_rank[]
◆ cs_grid_project_var()
void cs_grid_project_var ( const cs_grid_t *  g,
cs_real_t  f_var[]
◆ cs_grid_prolong_row_var()
void cs_grid_prolong_row_var ( cs_dispatch_context &  ctx,
const cs_grid_t *  c,
bool  increment,
cs_real_t *  c_var,
cs_real_t *  f_var
◆ cs_grid_restrict_row_var()
void cs_grid_restrict_row_var ( cs_dispatch_context &  ctx,
const cs_real_t *  f_var,
cs_real_t *  c_var
◆ cs_grid_set_matrix_tuning()
void cs_grid_set_matrix_tuning ( cs_matrix_fill_type_t  fill_type,
int  max_level
The finest mesh (level 0) is handled by the default tuning options, so only coarser meshes are considered here.
[in]fill_typeassociated matrix fill type
[in]max_levelmaximum level for which tuning is active
◆ cs_grid_coarsening_type_name
const char* cs_grid_coarsening_type_name[]
extern
