cs_gradient.cpp File Reference
Gradient reconstruction. More...
#include <algorithm>
#include <cmath>
#include <chrono>
#include <errno.h>
#include <stdarg.h>
#include <float.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "base/cs_array_reduce.h"
#include "alge/cs_bad_cells_regularisation.h"
#include "alge/cs_blas.h"
#include "alge/cs_cell_to_vertex.h"
#include "base/cs_dispatch.h"
#include "base/cs_ext_neighborhood.h"
#include "base/cs_field.h"
#include "alge/cs_gradient_boundary.h"
#include "base/cs_halo.h"
#include "base/cs_halo_perio.h"
#include "base/cs_internal_coupling.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_adjacencies.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "base/cs_timer.h"
#include "base/cs_timer_stats.h"
#include "alge/cs_gradient.h"
#include "alge/cs_gradient_priv.h"
+ Include dependency graph for cs_gradient.cpp:
void cs_gradient_initialize (void)
 Initialize gradient computation API. More...
void cs_gradient_finalize (void)
 Finalize gradient computation API. More...
void cs_gradient_free_quantities (void)
 Free saved gradient quantities. More...
void cs_gradient_scalar (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_3_t f_ext[], const cs_field_bc_coeffs_t *bc_coeffs, cs_real_t var[], cs_real_t *c_weight, const cs_internal_coupling_t *cpl, cs_real_t(*restrict grad)[3])
 Compute cell gradient of scalar field or component of vector or tensor field. More...
void cs_gradient_vector (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_v, cs_real_t var[][3], cs_real_t *restrict c_weight, const cs_internal_coupling_t *cpl, cs_real_t gradv[][3][3])
 Compute cell gradient of vector field. More...
void cs_gradient_tensor (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_ts, cs_real_6_t *restrict var, cs_real_63_t *restrict grad)
 Compute cell gradient of tensor. More...
void cs_gradient_scalar_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_t f_ext[][3], const cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t var[], const cs_real_t val_f[], const cs_real_t c_weight[], cs_real_t grad[][3])
void cs_gradient_vector_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_v, const cs_real_t var[][3], const cs_real_t val_f[][3], const cs_real_t c_weight[], cs_real_t grad[][3][3])
void cs_gradient_tensor_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_field_bc_coeffs_t *bc_coeffs_ts, const cs_real_t var[][6], const cs_real_t val_f[][6], cs_real_63_t *grad)
void cs_gradient_scalar_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t var[], const cs_real_t c_weight[], cs_real_t grad[3])
 Compute the gradient of a scalar field at a given cell using least-squares reconstruction. More...
void cs_gradient_vector_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_field_bc_coeffs_t *bc_coeffs_v, const cs_real_t var[][3], const cs_real_t c_weight[], cs_real_t grad[3][3])
 Compute the gradient of a vector field at a given cell using least-squares reconstruction. More...
void cs_gradient_tensor_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_field_bc_coeffs_t *bc_coeffs_ts, const cs_real_t var[][6], const cs_real_t c_weight[], cs_real_t grad[6][3])
 Compute the gradient of a tensor field at a given cell using least-squares reconstruction. More...
void cs_gradient_type_by_imrgra (int imrgra, cs_gradient_type_t *gradient_type, cs_halo_type_t *halo_type)
void cs_gradient_porosity_balance (int inc)
 compute the steady balance due to porous modelling for the pressure gradient. More...
Please refer to the gradient reconstruction section of the theory guide for more informations.
◆ cs_gradient_finalize()
void cs_gradient_finalize ( void  )
◆ cs_gradient_free_quantities()
void cs_gradient_free_quantities ( void  )
◆ cs_gradient_initialize()
void cs_gradient_initialize ( void  )
◆ cs_gradient_porosity_balance()
void cs_gradient_porosity_balance ( int  inc)
[in]incif 0, solve on increment; 1 otherwise
◆ cs_gradient_scalar()
void cs_gradient_scalar ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  hyd_p_flag,
int  w_stride,
int  verbosity,
double  epsilon,
double  clip_coeff,
const cs_field_bc_coeffs_t *  bc_coeffs,
cs_real_t  var[],
cs_real_t *  c_weight,
const cs_internal_coupling_t *  cpl,
cs_real_t(*)  grad[3]
[in]var_namevariable name
[in]gradient_typegradient type
[in]halo_typehalo type
[in]n_r_sweepsif > 1, number of reconstruction sweeps (only used by CS_GRADIENT_GREEN_ITER)
[in]hyd_p_flagflag for hydrostatic pressure
[in]w_stridestride for weighting coefficient
[in]verbosityverbosity level
[in]clip_modeclipping mode
[in]epsilonprecision for iterative gradient calculation
[in]clip_coeffclipping coefficient
[in]f_extexterior force generating the hydrostatic pressure
[in]bc_coeffsboundary condition structure
[in,out]vargradient's base variable
[in,out]c_weightcell variable weight, or nullptr
[in]cplassociated internal coupling, or nullptr
[out]gradgradient
◆ cs_gradient_scalar_cell()
void cs_gradient_scalar_cell ( const cs_mesh_t *  m,
const cs_mesh_quantities_t *  fvq,
cs_lnum_t  c_id,
cs_real_t  grad[3]
When boundary conditions are provided, both the bc_coeff_a and bc_coeff_b arrays must be given. If boundary values are known, bc_coeff_a can point to the boundary values array, and bc_coeff_b set to nullptr. If bc_coeff_a is nullptr, bc_coeff_b is ignored.
[in]mpointer to associated mesh structure
[in]fvqpointer to associated finite volume quantities
[in]c_idcell id
[in]vargradient's base variable
[in]c_weightcell variable weight, or nullptr
[out]gradgradient
◆ cs_gradient_scalar_synced_input()
void cs_gradient_scalar_synced_input ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  hyd_p_flag,
int  w_stride,
int  verbosity,
double  epsilon,
double  clip_coeff,
cs_real_t  grad[][3]
This variant of the cs_gradient_scalar function assumes ghost cell values for input arrays (var and optionally c_weight) have already been synchronized.
[in]val_fboundary face value
[out]gradgradient
◆ cs_gradient_tensor()
void cs_gradient_tensor ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  verbosity,
double  epsilon,
double  clip_coeff,
const cs_field_bc_coeffs_t *  bc_coeffs_ts,
[in]bc_coeffs_tsboundary condition structure
[out]gradgradient ( $ \der{t_ij}{x_k} $ is grad[][ij][k])
◆ cs_gradient_tensor_cell()
void cs_gradient_tensor_cell ( const cs_mesh_t *  m,
cs_lnum_t  c_id,
[in]c_idcell id
[out]gradgradient
◆ cs_gradient_tensor_synced_input()
void cs_gradient_tensor_synced_input ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  verbosity,
double  epsilon,
double  clip_coeff,
cs_real_63_t *  grad
◆ cs_gradient_type_by_imrgra()
void cs_gradient_type_by_imrgra ( int  imrgra,
cs_gradient_type_t *  gradient_type,
cs_halo_type_t *  halo_type
◆ cs_gradient_vector()
void cs_gradient_vector ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  verbosity,
double  epsilon,
double  clip_coeff,
const cs_field_bc_coeffs_t *  bc_coeffs_v,
cs_real_t  var[][3],
[in]bc_coeffs_vboundary condition structure
[out]gradvgradient ( $ \der{u_i}{x_j} $ is gradv[][i][j])
◆ cs_gradient_vector_cell()
void cs_gradient_vector_cell ( const cs_mesh_t *  m,
cs_lnum_t  c_id,
[in]c_idcell id
[out]gradgradient
◆ cs_gradient_vector_synced_input()
void cs_gradient_vector_synced_input ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  verbosity,
double  epsilon,
double  clip_coeff,
[out]gradgradient ( $ \der{u_i}{x_j} $ is gradv[][i][j])
