cs_ext_neighborhood.cpp File Reference
#include <errno.h>
#include <stdarg.h>
#include <float.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_halo.h"
#include "base/cs_halo_perio.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_adjacencies.h"
#include "base/cs_parall.h"
#include "base/cs_sort.h"
#include "fvm/fvm_defs.h"
#include "base/cs_ext_neighborhood.h"
+ Include dependency graph for cs_ext_neighborhood.cpp:
cs_ext_neighborhood_type_t cs_ext_neighborhood_get_type (void)
 Get the extended neighborhood type. More...
void cs_ext_neighborhood_set_type (cs_ext_neighborhood_type_t enh_type)
 Set the extended neighborhood type. More...
bool cs_ext_neighborhood_get_boundary_complete (void)
 Query whether full extended neighborhood should be kept at boundaries. More...
void cs_ext_neighborhood_set_boundary_complete (bool keep)
cs_real_t cs_ext_neighborhood_get_non_ortho_max (void)
 Get the non_orthogonality threshold (in degrees) associated with the CS_EXT_NEIGHBORHOOD_NON_ORTHO_MAX neighborhood type. More...
void cs_ext_neighborhood_set_non_ortho_max (cs_real_t non_ortho_max)
 Set the non_orthogonality threshold (in degrees) associated with the CS_EXT_NEIGHBORHOOD_NON_ORTHO_MAX neighborhood type. More...
void cs_ext_neighborhood_reduce (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
 Reduce the "cell -> cells" connectivity for the extended neighborhood using a non-orthogonality criterion. More...
void cs_ext_neighborhood_define (cs_mesh_t *mesh)
 Create the "cell -> cells" connectivity. More...
Extended cell neighborhood.
◆ cs_ext_neighborhood_define()
void cs_ext_neighborhood_define ( cs_mesh_t *  mesh)
[in,out]meshpointer to a mesh structure
◆ cs_ext_neighborhood_get_boundary_complete()
bool cs_ext_neighborhood_get_boundary_complete ( void  )
◆ cs_ext_neighborhood_get_non_ortho_max()
cs_real_t cs_ext_neighborhood_get_non_ortho_max ( void  )
non-orthogonality threshold
◆ cs_ext_neighborhood_get_type()
cs_ext_neighborhood_type_t cs_ext_neighborhood_get_type ( void  )
◆ cs_ext_neighborhood_reduce()
void cs_ext_neighborhood_reduce ( cs_mesh_t *  mesh,
cs_mesh_quantities_t *  mesh_quantities
Note: Only cells sharing only a vertex or vertices (not a face) belong to the "cell -> cells" connectivity.
[in]meshpointer to mesh structure
[in]mesh_quantitiesassociated mesh quantities
◆ cs_ext_neighborhood_set_boundary_complete()
void cs_ext_neighborhood_set_boundary_complete ( bool  keep)
[in]keeptrue if full extended neighborhood should be maintained at boundary
◆ cs_ext_neighborhood_set_non_ortho_max()
void cs_ext_neighborhood_set_non_ortho_max ( cs_real_t  non_ortho_max)
[in]non_ortho_maxnon-orthogonality threshold
◆ cs_ext_neighborhood_set_type()
void cs_ext_neighborhood_set_type ( cs_ext_neighborhood_type_t  enh_type)
[in]enh_typeextended neighborhood type
