cs_equation_system_param.h File Reference
+ Include dependency graph for cs_equation_system_param.h:
Classes
struct  cs_equation_system_param_t
 Main structure storing the parameter settings. More...
Enumerations
enum  cs_equation_system_sles_strategy_t { CS_EQUATION_SYSTEM_SLES_MUMPS , CS_EQUATION_SYSTEM_N_SLES_TYPES }
 High-level information about the way of solving the system of equations. More...
enum  cs_equation_system_key_t {
  CS_SYSKEY_INCR_SOLVE , CS_SYSKEY_LINEAR_SOLVER_ATOL , CS_SYSKEY_LINEAR_SOLVER_DTOL , CS_SYSKEY_LINEAR_SOLVER_RTOL ,
  CS_SYSKEY_LINEAR_SOLVER_MAX_ITER , CS_SYSKEY_SLES_STRATEGY , CS_SYSKEY_VERBOSITY , CS_SYSKEY_N_KEYS
 List of available keys for setting the parameters of a system of equations. More...
cs_equation_system_param_t * cs_equation_system_param_create (const char *name, int block_var_dim)
 Create and initialize a new cs_equation_system_param_t structure. More...
cs_equation_system_param_t * cs_equation_system_param_free (cs_equation_system_param_t *sysp)
 Free a cs_equation_system_param_t structure. More...
void cs_equation_system_param_log (const cs_equation_system_param_t *sysp)
 Log the setup gathered in the structure cs_equation_system_param_t. More...
void cs_equation_system_param_set (cs_equation_system_param_t *sysp, cs_equation_system_key_t key, const char *keyval)
 Set a parameter related to a keyname in a cs_equation_system_param_t structure. More...
◆ cs_equation_system_key_t
Enumerator
Incremental solve tag
Absolute tolerance for which the (main) linear solver stops iterating
Divergence tolerance for which the (main) linear solver stops iterating
Relative tolerance for which the (main) linear solver stops iterating
Maximal number of iterations for the (main) linear solver
Strategy for solving the linear system arising from the discretization of the system of equations
CS_SYSKEY_VERBOSITY
Level of verbosity related to the system of equations (a specific verbosity is available for the linear algebra; cf. CS_SYSKEY_LINEAR_SOLVER_VERBOSITY)
CS_SYSKEY_N_KEYS
◆ cs_equation_system_sles_strategy_t
Enumerator
Associated keyword: "mumps" Direct solver to solve the full (coupled) system
◆ cs_equation_system_param_create()
cs_equation_system_param_t * cs_equation_system_param_create ( const char *  name,
int  block_var_dim
[in]namename of system of equations
[in]block_var_dimdimension of the variable in each block
a pointer to a newly initialized cs_equation_system_param_t
◆ cs_equation_system_param_free()
cs_equation_system_param_t * cs_equation_system_param_free ( cs_equation_system_param_t *  sysp)
[in,out]sysppointer to the structure to free
a null pointer
◆ cs_equation_system_param_log()
void cs_equation_system_param_log ( const cs_equation_system_param_t *  sysp)
[in]sysppointer to a parameter structure to log
◆ cs_equation_system_param_set()
void cs_equation_system_param_set ( cs_equation_system_param_t *  sysp,
const char *  keyval
[in,out]sysppointer to a parameter structure to set
[in]keykey related to the member of eq to set
[in]keyvalaccessor to the value to set
